Tip & How-To about Computers & Internet
How To Speed up your Internet Connection by 20% Using Windows Tweek
Here’s a great tip to increase your internet connection from your own windows settings using simple registry tricks. Do you know that by default windows reserve 20% of our bandwidth for Windows for updates and interrogating your computer? That’s right! That’s why, I will show you how to regain this reserved bandwidth and thru this post it will surely speed up your Internet connection.
Step 1. Go to Start and Open RUN or Press Window key +R for RUN
Step 2.On the Run box give the command GPEDIT.MSC
Step 3.Click OK Group Policy Object Editor window will open on that window Select the Administrative Templates under Local Computer Policy.
Step 4.On Administrative Templates you will find a container named Network under that select QoS Packet Scheduler there you will get the settings Limit reservable bandwidth Double click on that the window shown in the picture will pop up.
Step 5.Click Enable radio button, in the Bandwidth limit % key in 0 instead of 20, click Apply OK
Step 6.To Apply this Group Policy with out restarting your computer you have to take back RUN and key in the command GPUPDATE /FORCE
Computers & Internet Logo
SPEED UP INTERNET
Windows OS user can speed up internet up to 20%. Actually windows reserve this 20% speed for update and other purpose. You can get back this speed. To know more, visit : Increase your internet speed up to 20%
You may speed up internet using public DNS server. To more detail, visit : Speed up internet by DNS setup
To know more about computer, internet and mobile phone tips, visit : 001 Easy Tricks
Feb 01, 2013 | NetGear Computers & Internet
error 107
Try this tip:
Go to option ' proxy settings and the standard MSIE window will pop up. Then go to advanced tab and be sure to tick:
USE SSL 2.0
USE SSL 3.0
USE TSL 1.0
If problem still occurs then you need to fix internet connection and windows invalid registry entries.
Use system utility tool Intel Software Partner Reginout that will not only fix registry errors but will also Optimize Internet by running its Internet Optimizer feature.
Oct 03, 2012 | Mozilla Firefox
how to increase my internet/downloading speed?
More than likely, the 460.8 figure is in kiloBITS per second, which means your downloads measured in kiloBYTES per second will be at a maximum, 57.6, which is still obviously higher than you are getting. One thing to consider is that you might not be in an area that supports 3G. That will affect your speed. Also, on the windows end, you can try this little (free) utility that will optimize your TCP settings in the registry: http://www.speedguide.net/downloads.php
this utility is not a "speed optimizer" snake-oil program that just compresses images or something cheesy like that. It was actually mentioned on TechTV.
Jul 17, 2008 | Microsoft Windows XP Professional
156 people viewed this tip
David Payne
David Payne
