Tip & How-To about Cell Phones
Soft & hard reset on Nokia phones
For soft reset enter this code *#7370#
For Hard reset simply enter *#7780#
Cell Phones Logo
i forget my security code and i want to recover
From howardforums.com posted by rambo47:
Nokia X2-01 Format and Factory Reset Code
1.Nokia X2-01Soft Reset
This will return back your X2-01 to its factory setting :
1. Dial or Key in *#7780#
2. Press Ok/Yes
This soft reset mode will not delete/harm your important data or applications, it simply restore the .ini files of the Nokia X2-01 ROM
2.Hard Reset Nokia X2-01:
1. Dial or Key in *#7370#
2. Press OK/Yes
3.Another alternative method you can try it if both method mentioned above not working. The method is pressing and holding down button *+3+Yes button right after your phone is turned on.
Sep 02, 2012 | Nokia X2-01 Black/grey Unlocked Phone
format1110i
There are two types of reformatting you can try Soft Format and Hard format.
Please see below instructions:
Press *# 7370 # Soft format: If the Handy (only telephone memory) formats, puts back the attitudes (see * to # 7780 #) and implements a software RESET. (however still another inquiry comes before.) NOTE! If the Akku to 75% are loaded at least, Akku do not only accomplish during the procedure under any circumstances remove! The procedure takes some minutes (approx. 3-4), is absolutely waiting! This is "only" a soft format... Hard format with "green, 3, *"... see below.
Hard format Green call button, *, 3 Hard format: If the Handy (only telephone memory) formats, puts back the attitudes (see * to # 7780 #) and implements a RESET. Also known as the "3-fingered salute".
Thank you for using fixya
Please rate me and give testimonials if ever to continue my assistance
A VERY HELPFUL RATING IS APPRECIATED, Thanks
Regards, Nerdierob
Jun 04, 2011 | Nokia 1110i Cellular Phone
When on line the other person can hear me talk but I do not hear the other person talk
power cycle. if same issue, remove the simcard and the battery, after 2 mins, insert it again. if same issue perform soft reset *#7780*. if still the same perform hard reset: *#7370* default is 12345. back up 1st data/files before doing the hard reset. your issue will be resolved.
IZNAVero_ako!
Apr 13, 2011 | Nokia 2730 Cell Phone
Please help me I have forgoten my cell lock code my IMEI:354199026531527 its a Nokia 6210 navigator and to reply please email nmgumbi@dla.gov.za
  • *#7370#Format phone (Soft Reset).
  • *#7780#NOKIA Factory Reset (Hard Reset).
  • To make a Hard Reset on a Nokia phone that is not willing to turn on, just press simultaneously these 3 buttons:
  • on/off + * + 3
    • Before making a Hard reset better backup all your important information
Jun 23, 2010 | Nokia N73 Cellular Phone
my nokia n95 would not turn on, placed it on a dry surface over night a, next morning would not turn on even when on the charger
Here are a couple of codes to soft/hard reset/format a Nokia N95 mobile device:Soft reset code *#7370#Hard reset code *#7780#If the hard format code mentioned above does not work, try the following manual method to hard reset/format Nokia N95:*Turn off the mobile device. Then press and hold "3", the "Green button" and "*" - Turn on and keep holding the keys until the mobile phone restarts and prompts you to enter detail
May 11, 2010 | Nokia N95 Cellular Phone
106 people viewed this tip
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
