Tip & How-To about Microsoft Xbox 360 Console
How to fix the 3 red rings
Hello there
If you need to fix this problem or any other xbox problem like open/close tray error, disk read error, 2 lights error, all error messages, no display and son, if you want to fix this your self and save loads of cash on the way then you need a Good Xbox repair guide,
The Problem is caused by over heating and this causes the GPU and the CPU to lose connection with the motherboard, The heat actually melts the soldering that connects the chips to the motherboard.
The best advice i can give is as i say a really good xbox repair guide.
i use this website here to keep me updated with the best ones www.dr-xbox.tk
READ TIP ON XBOX REPAIR GUIDES
Thanks for using Fixya
Microsoft Xbox 360 Console Logo
repair guides
Hello, well rather than type out and try to explain the whole process, i will direct you to here and here. So much easier to "see" it than "read" it. The first link is for a tray that won't open. The second link is if the system actually says that it's reading the disk and the displays "tray open" message error. Both are common and very annoying. I have fixed many using both methods. If anyone is unfamiliar with how to open your xbox 360, you can watch how here. I hope this helps.
Dec 11, 2011 | Microsoft XBOX 360 ARCADE Console
how do i fix the disk drive on an xbox 360
http://www.pakgamers.com/forums/xbox-hardware-faq-guides/6157-how-fix-open-tray-error-another-solution.html
ezinearticles.com/?How-to-Fix-Xbox-360...Red...Error&id... -
forums.xbox-scene.com/index.php?showtopic=484726&st... -
OK use those links above i am sure you will find help there.
Mar 25, 2010 | Microsoft Xbox 360 Console
Xbox 360 disk tray wont stay shut
My 360 is/was having a similar problem...my 360 would say "reading disc" then "open tray". Well since my system is only about 8 months old...I opted to send it in for repair. Its under warranty. My system is in route to be fixed as we speak. I would advise you to get yours registered too.
May 28, 2009 | Microsoft Xbox 360 Console
xbox 360 open tray error
How I worked around the "Open Tray" problem, where the game discs were not being recognized:
1. Open tray
2. Unplug power cable while tray is open
3. Plug in power cable
4. Power on console - tray closes
5. Open tray
6. Insert disc
7. Try your game
Good luck! Source: Someone else mentioned this in a forum somewhere, however I don't recall who it was or which forum. I'm just trying to get the word out so people don't send in their XBOX for repair, or open the case and void the warranty if this workaround resolves the problem.
Mar 25, 2008 | Microsoft Xbox 360 Console
819 people viewed this tip
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
