Tip & How-To about Televison & Video
For all mains powered electronic gadgets
Make sure that the mains plug is intact and has a tight connection. this can surely help to eliminate intermitent connection which could result in many a failure of SMPS power sections which are found in all these appliances.
Disconnect mains power during a severe lightning as poor earthing could lead to damages by surges even if the appliance is switched off.
When you are away on long holidays kindly remove all such connections.,
Televison & Video Logo
spark intermitting on weed eater
This could be a long post but you can probably find a video on youtube. Many times it is a fouled or used up spark plug. Also check the plug wire. If connection is not tight or wire is cracked it will do this. Also check to make sure the fluwheel is on correctly an has not moved or keyway not broken. If all else fails check timing an make sure you have correct distance between mag an flywheel. Just some things to chwck
Jul 05, 2014 | Poulan 17" T&E Gas Trimmer
sudden loss of color
If you are sure your cables are tight and not defective, then your main board is defective or your signal source is defective.
Mar 15, 2013 | Emerson LC195EM9 19 in. LCD TV
kenmore thermal fuse keeps blowing and im getting a white powdery film
If the thermal fuse blows it is a direct result of heat. The most common place for the heat to be generated is the wire connections to the fuse, the wire connections on the main control board and the door switch.
The thermal fuse comes with a small wire kit, be sure you or the technician used that wire kit if not you will continue to have trouble. If you have then look the board over closely, especially the black plastic plugs, if you see any dark spots or loose connections make sure to tighten them up. Then check the wires to the door switches make sure they are tight connections. If all these are okay then check the gasket on the left side that surrounds the vent, if heat escapes this gasket it can migrate over toward that thermal fuse.
I hope this helps
Apr 25, 2010 | Kenmore 24 in. 16352 / 16354 / 16359...
No prower 2000 Oldsmobile Silhouette
Check all battery connections make sure they are tightly secured. Check for broken battery cables, if all are intact. Check battery/Main Fuse. contact if you need more help. Good Luck
Dec 27, 2008 | 2000 Oldsmobile Silhouette
92 Isuzu Rodeo Power loss
Do you have the v 6 or the 4 cyl.?
You may want to check the cap and rotor, and check to make sure all elctrical connections and vacuum hoses are tight and in good condition. Then go from there.
Jul 06, 2008 | 1992 Isuzu Rodeo
150 people viewed this tip
Top Televison & Video Experts
