Tip & How-To about Computers & Internet
How Do I Correct the Error and Recover an Acer Computer hard drive?
In order to correct the hard drive partitions so the recovery program will work, you can use a variety of tools listed below.
1) Active@ KillDisk - Use their free killdisk program to wipe the hard drive clean off all partitions.
2) Ubuntu or another Linux alternative bootdisk. Create a boot disk for the Ubuntu Live CD and boot the computer from it. During the boot process it will ask to "Try Ubuntu without any change to your computer". This is the option you want. Once Ubuntu loads, find the partition editor program under the System, Administration menu..
To delete a partition, right click on the partition that you wish to delete and select "Delete" from the menu. Once you are sure that you've selected the correct partition, and are positive that you have backed up all the files or data that you wish to save from that partition, click the "Apply" button at the top of the Window, and the partition will be deleted.
3) Use the Acer Hard Drive Format Utility, on some versions of Acer computers when you have the option to create Recovery disks, the system creates a hard drive format utility CD as well. Boot from this CD and format the hard drive.
The utility will recreate 1 partition (C: drive), after the partition has been created, you'll be able to reload the HDD with the backup media. The file is an ISO image for CD media only (not compatible with floppy diskettes). Create a CD disc from the ISO image file using a CD writer program on another computer.
Once the hard drive partitions have been deleted by any of the utilities above, you can proceed with rebooting the computer using the Acer System CD and proceeding with the complete recovery of the system.
Computers & Internet Logo
I don't have recovery partition
follow this step and do it. God bless you
  • To create a partition from a new or newly formatted computer, make sure Windows is installed. Load any programs and drivers you would like to keep in case you need to back up to a previous version of your computer's settings.
  • 2
    Install your partition creation software; in this article we will use Norton Ghost. Before creating your partition, disable any anti virus and other scanning software.
  • 3
    Create your partition by going to your ms-dos prompt: from your Start menu, press "Run," and type "cmd" without quotations in the run dialog box. At the dos prompt, type "fdisk" without quotations, and choose option 1 (Create DOS partition or Logical DOS Drive). Set the partition size to 10 GB at press enter.
  • 4
    Open Norton Ghost and follow the instructions to create a recovery partition in the new partition you had just created. The process should take anywhere from one to three hours, depending on the size of the files you are going to back up.
  • 5
    Restart your computer. When done, open Norton Ghost to verify that the Recovery Partition was created.
  • Feb 28, 2013 | HEWLETT-PACKARD PZ531UA#ABA (DC7100 USDT)...
    sd card cannot recover pictures
    download this card recovery software which is one of the best photo recovery software, download the program from
    http://www.asoftech.com/apr/
    Jan 28, 2011 | SanDisk MobileMate SD Plus 5-in-1 Media...
    trying to install windows 7 retail 64 bit on Scorpio (was installed once already started getting wonky so decided to format reinstall) boot with usb dvd rom drive get to unpacking of windows files and get(windows cannot find locale error code 0x80fe0000 and install stops This is an HP Pavillion dv2 1044ca) which ran vista and the i got the retail upgrade from Microsoft.
    According to Microsoft, Windows 7 must be installed on a primary partition. This error code means the installer hasn't found a primary partition on the target drive. The primary partition must be on the first hard drive in the boot order, and if you have more than one user partition (not counting the small drive table partition), you must install to the first user partition. Unfortunately MS doesn't seem to have a clear, comprehensive answer to the issue. I've gleaned the following from various forum responses.
    For some reason the installer is date sensitive, so make sure the time and date are correct in the BIOS. Time your next install attempt so it will NOT go past midnight during the installation.
    Check your BIOS settings to make sure the drive is listed as a "primary" drive (drive 0, not drive 1) rather than a secondary.
    Some people have had problems with the Windows 7 installer on drives that have the Master Boot Record from previous installations. Try a FORMAT /MBR using the Windows 7 install CD. If this doesn't work,
    1. Use the partition command to remove the target partition from the drive to wipe this out
    2. Partition the now unused space and reformat (again!), and
    3. If the partition command or installer has an option to set a partition as primary (or something else), choose primary (disk 0) for the partition you want to use for Windows 7.
    If all else fails, use your HP Software Recovery CD to do a complete repartition and reformat. You could use the Windows 7 partition command to do the same thing, but then you would lose the HP System Recovery partition. However, if HP is marking the System Recovery partition as partition 0, it could be causing the problem. In that case, see if HP has an updated version of the CD that includes a fix for this, or do without it and turn it all over to Windows 7.
    Dec 26, 2010 | Western Digital WD Scorpio Black...
    say's it needs to initialize and comes up with eisa.
    The EISA partition is a partition that a computer manufacturer places on the disc to assist in recovery of that maker's files. It is not necessary to have this partition if you do not intend to perfrom a factory recovery. I will include a guide below to assist you in a deletion of that partition. To initialize a disc, it can be done ways, boot the computer and it will advise you the disc has not been initialized and will initiate a wizard to assist. I attach the hard drive to another computer using an EIDE/SATA to USB adapter, it will be recognized as an external drive but will not give it a drive letter because it is not initialized. You have to go to the control panel > administrator tools > computer management > disc management. Look in the right lower pane and it will show the drive with a grayed out box to the left, it may label the drive as drive 03 or 04 etc. Right click on the drive number and choose initiate. The computer will initiate the drive and give it a letter. It will also ask you if you want to initiate the drive as a bootable drive, choose yes. Below is the guide to delete that EISA partition so you can use the drive in any laptop you see fit.
    EISA Partition Delete
    1. Open a command prompt as administrator.
    2. Run Diskpart application by typing Diskpart in the command prompt.
    3. In the “Diskpart” prompt, enter rescan command and press Enter key to re-scan all partitions, volumes and drives available.
    4. Then type in list disk and press Enter key to show all hard disk drive available.
    5. Select the disk that contains the partition you want to remove. Normally, with just 1 hard disk, it will be disk 0. So the command will be:
    select disk 0
    Finish by Enter key.
    6. Type list partition and press Enter key to show all available and created partition in the disk selected.
    7. Select the partition that wanted to be deleted by using the following command, followed by Enter key:
    select partition x
    where x is the number of the EISA based recovery partition to be removed and unlocked its space. Be careful with the number of this partition, as wrong number may get data wipes off.
    8. Finally, type in delete partition override and press Enter key.
    Once the partition has been deleted, exit from Diskpart, and now users can use the much familiar and much easier Disk Management tool in Windows (diskmgmt.msc) to manipulate the freed unallocated partition. Users can create a new volume (partition) with this space, or simply merge it to existing partition by extending the size of the existing partition.
    Nov 19, 2009 | Toshiba MK8025GAS 80 GB ATA-100 Hard Drive
    recovery partition full error
    Please go to Start + Run and type cmd
    Type chkdsk d: /F /X /R
    It will dismount and check for any errors after the system restarts
    follow the method to clean the disk space.
    ) Open Internet Explorer and click on Tools
    2) Click on Internet Options
    3) On the General Tab, in the middle of the screen, click on Delete Files
    4) You may also want to check the box "Delete all offline content"
    5) Click on OK and wait for the hourglass icon to stop after it deletes the temporary internet files
    6) You can now click on Delete Cookies and click OK to delete cookies that websites have placed on your hard drive. To clear the Internet History in IE:
    1) Open Internet Explorer and click on Tools
    3) On the General Tab, in the middle of the screen, click on Clear History
    4) Click OK
    To clean up other temporary files on your computer in Windows 98 or higher:
    1) Click Start, Programs (or All Programs), Accessories, System Tools, Disk Cleanup
    2) Choose the correct drive usually C:\
    3) Check the boxes in the list and delete the files
    Dec 10, 2008 | Gateway 2520915 Keyboard
    306 people viewed this tip
    David Payne
    David Payne
