Tip & How-To about Computers & Internet
How to Fix Issue When Add Remove Control Panel is Blank or Won't Open
To correct the problems with Internet Explorer (especially since it was a version installed with Windows 2000), I used a cool little program in my arsenal called IEFix. Follow these steps to correct the issue:
1) Download IEFix to your desktop and unzip it
2) Double-click on the file to open it
3) Click Apply to fix any Internet Explorer errors
4) After running IEFix, reboot your computer.
in my case, this completely fixed the problem with a blank Add Remove Control Panel. However, there are some instances where other fixes are needed. In these cases, follow the steps below to troubleshoot this problem and solve it.
1) To rule out any spyware or viruses causing the issue, you should run a thorough scan of your system using your favorite antivirus and spyware programs. If you dont currently use an antivirus or spyware removal program you should. You can refer to my page on Essential Tools to download this type of software.
2) Next, run a check for any missing or corrupted Windows files by clicking on Start, Run, and typing sfc /scannow and pressing Enter. The system will scan Windows for any problem core files and ask for your Windows installation CD to replace any problem files.
3) You may want to try to register the control panel file by clicking on Start, Run and typing REGSVR32 APPWIZ.CPL and pressing Enter. This will re-register the program with Windows.
4) If you are still having problems, then I would run IEFix and correct any Internet Explorer issues.
There is a Microsoft Support Article for Windows 98 and NT concerning an issue where not all programs will be shown in the Add/Remove Control Panel. The problem happens when a display name or uninstall key is greater than 63 characters.
Hopefully, these suggestions will fix any issues that you may experience with the Add or Remove Programs applet in the Control Panel.
Computers & Internet Logo
Order Number:246889. I have not received my answer. Problem is a DLL ERROR ~ not printer. littlecaesar@atc.cc My problem is a script error (IE frame.dll error) Please give answer by email promptly !!
  1. Restart your computer unless you've already done so. The ieframe.dll error might be a fluke and a simple restart could clear it up completely.
  2. Install the latest version of Internet Explorer. No matter if you're missing ieframe.dll or if you're receiving a browser error message about it, reinstalling or updating to the latest version of Internet Explorer has resolved many user's issues with ieframe.dll.
  3. Using Visual Basic 6? If so, change the reference for Microsoft Internet Controls from the existing ieframe.dll to shdocvw.ocx. Save your project and then reopen it.
  4. Restart your router, switch, cable/DSL modem and anything else that's used to communicate to the Internet or other computers on your network. There may be an issue in one of these pieces of hardware that a simple restart could solve.
  5. Scan your entire computer for viruses. Sometimes, the ieframe.dll error will show up when your computer is infected with certain kinds of viruses. Use your antivirus software to do a complete system scan for virus infections.
  6. Disable Windows Firewall in Windows XP if you have another firewall installed. Running two firewall applications at the same time can cause problems so if you have a firewall program installed like ZoneAlarm, Norton Personal Firewall, Comodo Firewall, etc., then you should not be running Windows's built-in firewall simultaneously.
    Note: Even if you're positive that the Windows firewall is disabled, check again. Some Microsoft security updates have been known to re-enable the firewall automatically even if you have an existing firewall enabled in another security software program.
  7. Update all non-Microsoft firewall and other security software on your computer. Certain security updates from Microsoft have been known to cause issues with security software from other vendors that those vendors are responsible for resolving. Check their websites for updates or service packs and install any that are available.
    Note: If you're already running a fully updated version of your security software, try uninstalling and then reinstalling the software instead. A clean installation may stop that nagging ieframe.dll error message.
  8. Install any available Windows updates. It is true that some previous updates from Microsoft may actually cause some ieframe.dll errors, but installing more recent updates, especially those to the Windows Update software itself, may help resolve the problem.
  9. Clear the temporary Internet files in Internet Explorer 7. Some ieframe.dll issues may have to do with problems accessing existing temporary Internet files.
  10. Increase the frequency that Internet Explorer 7 checks for new versions of web pages. If the default setting is too infrequent and there are issues with certain pages, you may see ieframe.dll and related errors.
  11. Disable Internet Explorer 7 add-ons one by one. One of your installed add-ons might be causing the ieframe.dll issue. Selectively disabling them will show you which one, if any, is causing problems.
  12. Set Internet Explorer 7 security options back to their default levels. Some programs, even some updates from Microsoft, will sometimes make automatic changes to your Internet Explorer 7 security settings.
    Incorrect or overprotective security settings can sometimes cause ieframe.dll issues. Returning these settings to their default levels may correct your issue.
  13. Move the IE7 Temporary Internet Files Folder to its Default Location in Windows XP. If the Temporary Internet Files folder in Internet Explorer 7 has been moved from its original location, plus both Protected Mode and the Phishing Filter are enabled, the ieframe.dll error will occur.
  14. Disable the Phishing Filter in Internet Explorer 7. This isn't a great long term solution if you don't have another phishing filter installed, but disabling IE7's phishing filter has been known to correct ieframe.dll issues in some situations.
  15. Disable Protected Mode in Internet Explorer 7. The Protected Mode feature in Internet Explorer 7 can, in some very specific situations, be involved in generating an ieframe.dll error message.
Dec 12, 2010 | Microsoft Windows® Vista 64-bit Business...
For All XP user Don't Use IE 7.0 & higher version
Just watch out for spyware, as even the latest updated version of IE 6 is vulnerable to spyware automatically installing itself.  I suggest using Opera, Firefox or Chrome to be totally clear of spyware.
Oct 14, 2008 | Microsoft Windows XP Home Edition
//ieframe.dll/dnserror.htm
There are many possible causes for the error you are getting. try these steps.
Still having the issue try the fix at this link HERE
Apr 16, 2010 | Dell Inspiron E1505 Notebook
None of the Microsoft suggestions correct error #0x80072F8F and allow me to get updates
search for updates manually. especially for installer 3.1 install it and restart your computer. Check Services and make sure windows automatic update service is set to automatic and started. Check time and Date and download the latest version of internet explorer from microsoft site. Install it and it will automatically update many root certificates for your windows. Set the security setting of internet explorer to default level and finally try to use update application of windows. It should work.
Sep 07, 2009 | HP Pavilion 510c PC Desktop
fix script page error
re-install the program internet explorer.
or go to ( On your computer ) Start/all programs/accesories/system tools/system information.
From there you should have an option to repair internet explorer.
Mike @ Compurepair.
Feb 22, 2008 | Computers & Internet
113 people viewed this tip
David Payne
David Payne
