Tip & How-To about Computers & Internet
How to remove autorun.inf virus from drives
1.Go to run and type cmd and click on the Enter button.
2. type cd
3. type attrib -r -h -s autorun.inf (to make the viruses visible)
4. type del autorun.inf (the actual deletion of the viruses)
5. now type d: and press enter for d: drive partition. Now repeat steps three and four. Similarly repeat step 5 for all your hard disk partition.
Restart your system and your trouble will be fixed.
Pleasure.
Computers & Internet Logo
i for all you!! i ned know how to remov shortcut virus in my pen driver?plz someone help me plz...thankyou zener- from mozambique
Use antivirus software like avast ,microsoft security essentials and scan your pendrive to remove your virus ..If you want to remove virus manually then FOllow these instruction
1)click start
2)then go to run
3)and type "cmd" in the text box without quotes
4)command prompt will appear
5)press enter
6)type "cd\" and then press enter to get into the root directory
7)Now assume that your pen drive has drive letter G type g: and followed by enter then
8)Type "attrib -h -r -s autorun.inf" and press enter. This will look for autorun.inf in the selected Drive.
9)Type "del autorun.inf" and press enter. This will delete autorun.inf virus from the selected Drive.
If this doesnt work and if you have newfolder.exe virus then try the software called SRT tools to remove it.
I hope this will help you .if it does do rate my answer
Thank you for using fixya
regards
lalith
Mar 15, 2011 | Online Computers & Internet
whenever i used to insert chip drive with chip it is showing autorun.inf virus
How to remove autorun.inf in your flash drive or hard disk
Sometimes for virus or trojan horse you may difficulties opening your drives. Your autorun.inf is infected if you find any abnormal language when you right-click on a drive. This autorun.inf file is hidden and you will not see the file even though you select to show your all files from Folder Options.
1. Goto Start --> Run and type cmd then click OK.
2. If you want to remove the infected file from drive C: then type C: then press Enter.
3. Type "autorun.inf" and press Enter.
4. Type "del autorun.inf" then press Enter. The file is in the drive but not showing or you can't delete it now.
5. Now type "attrib autorun.inf -s -h -r" and press Enter.
6. Now delete the file by typing "del autorun.inf" and press Enter.
7. Restart the computer.
Good Luck!
Mar 02, 2011 | Computers & Internet
D drive not open.
If it happens to you that you are not able to open the drives by double click, then your system may be infected with virus. When this virus infects your windows, it automatically creates a autorun.inf in the root directory of each drive. This autorun.inf file is usually hidden, read only and is a system file. This virus also disables folder option. This is not a major problem and can be fixed by deleting autorun.inf file.
  1. Open Start > Run. Now type cmd and press enter. Command prompt window will open.
  2. Type cd/
  3. Type attrib -r -h -s autorun.inf
  4. Now type del autorun.inf
  5. Now type d: and press enter for d: drive partition and repeat steps 3 and 4.
  6. Repeat step 5 for all your hard disk drives.
  7. Restart your computer.
Jul 30, 2010 | Symantec Norton Antivirus 2009 1-User -...
Error : em8tqm.cmd
may be it cause virus praveen
go to start button and click run
and type cmd
then type
cd\ and press enter
then type
attrib -r space -h space -s space autorun.inf then enter
ex: 1. attrib -r -h -s autorun.inf enter
2. del autorun,inf enter
after that go to d: and press enter
Apr 08, 2009 | Microsoft Windows XP Professional for PC
comp drives not opening
this is because of autorun.inf file.
so run the following command-
go to run > type cmd >then type
cd\
attrib -r -s -h autorun.inf
del autorun.inf
d:
del autorun.inf
just execute the same command for all of ur physcal drives
and finally shut down ur computer
then open ur comp,now u can open ur drives by double click.
Mar 01, 2008 | Computers & Internet
165 people viewed this tip
David Payne
David Payne
