Tip & How-To about Computers & Internet
Two must know usability tips for Mac Laptop users
Here are two general usability tips that every Mac laptop owner must know about. How to simulate a right click with your trackpad, and scrolling through documents much like a scrollwheel. I have long assumed these were common knowledge, but I’ve heard enough complaints and wishes and had to demonstrate them to enough people to prove otherwise. So if you don’t know about these two trackpad features, then you do now, and once you start using them, it’s impossible to go without.
  • Right Click with Trackpad - Hold two fingers on the trackpad while you use the click button
  • Scroll through pages a la Scroll Wheel with trackpad - Place two fingers on the trackpad and move them up to scroll up, and down to scroll down. Works horizontally as well.
If these features aren’t working for you, they are probably disabled. Here is how to activate them:
Note: Several of our readers have pointed out that these tips are not compatible with some older PowerBook and iBook models. However, a program called iScroll2 enables the scrolling ability on these models. Get iScroll2 here. Thanks to all who pointed this out!
To activate these options (assuming they are turned off), go to Apple menu -> System Preferences. Navigate to the ‘Keyboard & Mouse’ preference pane under Hardware. Click the Trackpad tab. Under Trackpad gestures, be sure that “Use two fingers to scroll” and ‘Place two fingers on trackpad and click button for secondary click’ are checked, as shown in the screenshot below. Enjoy
Computers & Internet Logo
how do i scroll on a mac
Simply use the Up & Down keyboard arrows
Sep 23, 2015 | Computers & Internet
the touchpad on my laptop won't click, it scrolls up and down, side to side just fine
Go to the Apple icon menu (top left) > System Preferences > Trackpad click on the check box next to "Clicking"
This will let you just tap on the trackpad with one finger instead of pressing down on the trackpad to click on something
This is also were you can check the "Tap trackpad using two fingers for secondary click" (ie kind of like right clicking on something)
Jan 22, 2011 | Apple MacBook Air
New MacBook Pro, getting use to it, has Snow Leopard. For some reason at times when using the mouse it zooms out, making everything smaller. What's up?
Click the Apple menu (upper left corner). Click System Preferences. Click Mouse. Un-check "Zoom using scroll wheel while holding control." See if that fixes the problem. I assume you're using the mouse, not the trackpad. If you're using the trackpad, click Trackpad in System Preferences instead. Un-check "Pinch open and closed" under Two fingers.
Good luck. Let us know if this solves your problem.
* If you find this information helpful, please rate my solutions and recommend me. Thanks! *
Apr 29, 2010 | Apple 13-inch MacBook - Intel 2.0GHz Intel...
Tap feature on MAcbook 2.4Ghz 2GB
I am running mac OS 10.5.5 and Win XP using parallels.  You need to make sure the system preferences in the mac OS to allow two fingers for secondary click using the trackpad. This allows you to right click in Win XP.
I find using two fingers and clicking the button works more reliably in windows xp.  I usually have to try two finger tapping a few times.
To right click by tapping: Go to System Preferences and choose Keyboard & Mouse.  Select "Clicking" and "Tap trackpad using two fingers for secondary click". This allows you to tap the trackpad with two fingers side by side to get the "right click" effect.  You can also right click without tapping with this setting.
To right click without tapping:
Go to System Preferences and choose Keyboard & Mouse.  Select "For secondary clicks, place two fingers on the trackpad then click the button". This allows you to right click by placing two fingers on the trackpad and then clicking the mouse button. 0acf97a.png
Oct 23, 2008 | Apple MacBook 13"White /2.0Ghz Intel Core2...
macbook trackpad tapping
Check in system preferences under keyboard and mouse in the trackpad section. You'll probably find that the trackpad taping will become annoying when typing but you can also enable two finger scrolling there - which you're should probably have.
Jun 20, 2008 | Apple MacBook 13"White /2.0Ghz Intel Core2...
157 people viewed this tip
David Payne
David Payne
