Tip & How-To about Computers & Internet
System mechanic or professional failure code 323-a
This error comes usually on system with Service pack 3.
The reason why this message comes on the system is the service pack 3 is either currpted or not installed properly.
" The 323 error can occur when using the Standard Edition release of the 1.0 version of the Microsoft Systems Management Server program. It happens when the Systems Management Server is used with the non-U.S.
version of the Microsoft SQL Server version 4.21a. The 323 error appears in the Systems Management Server event log. It is logged because of a discrepancy in the settings for the two programs. The required time and date format for the Systems Management Server is different from the format used in the SQL Server. It may happen when the
French version of the SQL Server is installed on a U.S. version of Windows NT wherein French is the default language used for the SQL Server "
Do the steps to fix this problem:-
For windows XP :- ( If you have service pack 3 installed on your system )
1:- Remove the Service pack 3 from your computer :-
Click on start-->go to Computer--> Go to C drive ( Primary Drive )--> Go to windows -->
If you find some hiddens files find out $NtServicePackUninstall$ folder. If you do not find it Stop here.
If you do find it Do this:-
open $NtServicePackUninstall$ ---> open spuninst ---> double click on spuninst.exe
( Exact Path :- C:WINDOWS$NtServicePackUninstall$spuninstspuninst.exe )
Now follow the instructions and uninstall the service Pack 3. During the uninstallation of Service Pack 3
It might would prompt you that some files or services will be affected after uninstalling the Service Pack 3
Do you want to continue. So at this point DO click on yes and continue with the uninstallation.
If the uninstallation is succcessfull. Restart the computer and then try to install the system mechanic professional
or system mechanic again.
If the uninstallation of service pack 3 is unsucccessfull
Try this:-
Do a system restore and then try to uninstall the service pack 3 using the above steps.
If even then you are unsuccessfull then do this:-
Save your imporant files and documents on an external hard drive and Format the hard drive completely.
Now try and install the system mechanic professional or system mechanic. you will successsfully install it
for sure.
If the uninstallation of service pack 3 is succcessfull
Do this:-
Try to install the software now. If it works perfect. Else do this :-
install the windows installer 4.5 using the link below.
[ http://www.microsoft.com/downloads/details.aspx?FamilyID=5a58b56f-60b6-4412-95b9-54d056d6f9f4&displaylang=en ]
downlaod the executable file given below on this page:- ( WindowsXP-KB942288-v3-x86.exe )
After installing the windows installer try again to install the software. If it works perfect. Else
Try this :-
Now re-install the Service pack 3 again. using the below link:-
[ http://www.microsoft.com/downloads/details.aspx?FamilyId=5B33B5A8-5E76-401F-BE08-1E1555D4F3D4&displaylang=en ]
This may take a long time. But after installing the service Pack 3 again.
Install the software again. If it works perfect else
Do this :-
for sure.
If this does not work either call system mechanic people using the number 323-257-8888
For windows vista :-
Try to do windows Update and then try to install. If does not work then try to create a new user account and then
try. As some times the user account is also corrupted.
For windows 7 :-
Do windows update and then try installing the software if does not work then try
calling the system mechanic people using the number 323-257-8888
Note :-
( For windows 7 and vista we still are doing a research once we are done we will put that online.
In the mean while follow the instruction given above. )
Computers & Internet Logo
I just installed windows XP service pack 3, installshield errors
Hi, "I hope this will help you out with the problem! Try this Link: http://www.technospot.net/blogs/download-directx-10-for-windows-xp-from-alky-project/ "If this help? Feedback is appreciated, thanks paul7of9."
Feb 04, 2010 | InstallShield Update Service Version 3
error code 2329
It's a error message with Windows installer not for Itune.
Try to get latest windows installer from link below
http://www.microsoft.com/downloads/details.aspx?FamilyID=889482FC-5F56-4A38-B838-DE776FD4138C&displaylang=en
Supported Operating Systems: Windows 2000 Service Pack 3; Windows 2000 Service Pack 4; Windows Server 2003; Windows XP; Windows XP Service Pack 1; Windows XP Service Pack 2
Dec 28, 2008 | Computers & Internet
Windows XP Service Pack 3 (KB936929)
go onto the microsoft website and download it and click save instead of open(run) then install it from the instalation package
hope this helps :-)
Aug 07, 2008 | Microsoft Windows XP Home Edition with...
436 people viewed this tip
David Payne
David Payne
