Tip & How-To about Microsoft Office Outlook 2007: Windows
Outlook keeps restarting
When this happen do not reinstall the office on the existing copy of
outlook on your system. Kindly follow these steps:1 Uninstall the office completly .2.Locate the office folder and delete it from where ever located. you can search the folder (start>search>files and folder>type office
in the search box).3.If it does not let you delete the folder kindly restart the system
and try to delete the folder.4.Once uninstall and deleted the folder then restart the system, and
re-install the office with SP2.This will resolve the issue.
Microsoft Office Outlook 2007: Windows Logo
logged on and my email icon was missing as well as other icons. tried to start outlook and the message is simply cannot start outlook. cannot make google my home page as dell4me contiues to override any changes... tried system restore and the restore cannot work help
This issue may occur if you deploy Outlook 2003 with the Microsoft Office 2003 Custom Installation Wizard and specify a personal folder (.pst) file in the Windows Installer transform (MST file) by using the Default location for PST files path option. The problem occurs because you specify a file name instead of a folder path.
To resolve this issue for future installations of Office, use the Custom Installation Wizard to edit the MST file. To do this, follow these steps:
  1. On the Change Office User Settings page (page 10 of 24), expand Microsoft Outlook 2003, expand Miscellaneous, and then click PST Settings.
  2. In the right pane, double-click Default location for PST files, and then type the path that you want in the Default location for PST files box. For example, type %USERPROFILE%\Local Settings\Application Data\Microsoft\Outlook\.
  3. Click OK, and then follow the steps to complete the wizard. When you have corrected the MST file, deploy Office by using the correct MST file.
To resolve this issue for an existing installation of Outlook that is experiencing this problem, specify the .pst file by using the Mail icon in Control Panel.
Or If you are receiving and Err like
Error message when you start Outlook: "Unable to open the Outlook window," "No profile has been created," or "The list of Profiles cannot be loaded"Follow the step's below:This issue may occur on a computer that is running Windows XP if the Outlook.exe file was configured to open with the Windows program compatibility mode setting. When you set compatibility for Outlook to Windows 95 or to Windows 98/Windows Millennium Edition, Outlook displays this error message. This is because the location of the Outlook Profile information in the registry differs on a Windows XP-based computer.
To resolve this issue, follow these steps:
  1. Locate Outlook.exe.
    Outlook.exe is typically located in one of the following folders, depending on the version of Outlook that you are running:
    • Microsoft Office Outlook 2010 C:\Program Files\Microsoft Office\Office14
    • Microsoft Office Outlook 2007 C:\Program Files\Microsoft Office\Office12
    • Microsoft Office Outlook 2003 C:\Program Files\Microsoft Office\Office 11
    • Microsoft Outlook 2002 C:\Program Files\Microsoft Office\Office 10
    • Microsoft Outlook 2000 C:\Program Files\Microsoft Office\Office 9
  2. Right-click Outlook.exe, and then click Properties.
  3. On the Compatibility tab, click to clear the Run this program in compatibility mode for check box.
  4. Click OK.
  5. Try to start Outlook. If you receive error message again, use Method 2.
Regard's
Pcs365.8
Jun 16, 2010 | Microsoft Windows XP Home Edition
Hot sync error 8001 with MS outlook
Answers on Chapura PocketMirror errors, Chapura maintains a really good database of fixes for errors with their PocketMirror Outlook PIM conduits. Copied from the site: First, make sure you are running the latest version of PocketMirror version 3.1.7. To check which version you are currently running, please see Chapura FAQ PM089. If you are still receiving the same error after installing the latest version of PocketMirror then continue with the following steps. If Option 1 does not resolve the issue, then move onto Option 2 and so on: Option 1: Run the Outlook 2000/2002/2003 "Detect and Repair" utility (You will need the Office/Outlook CD-ROM). 1. In Outlook click "Help/Detect and Repair". 2. After the repair is complete, reboot your computer and synchronize your handheld. Option 2: If you are running Windows XP and this error is occurring, please perform the steps in Chapura FAQ PM198. Option 3: If this OLE error occurs ONLY when synchronizing with Outlook closed, then please see Chapura FAQ PM053 "Outlook Backup Add-in causes HotSync failure when Outlook is closed." Option 4: If you have a laptop computer and are running Windows 2000/Outlook 2000, this OLE error may be caused if your laptop goes into sleep/hibernate mode when Outlook is open. To fix this problem reboot your computer and try to synchronize your handheld again. In the future make sure Outlook is closed when your computer "hibernates". Option 5: Uninstall and reinstall 3rd party conduits such as the TakeNote, DayNotez, PocketQuicken, QuickWord, Quicksheet, etc. To check for these conduits: 1. Click on the HotSync Manager icon (circular red/blue arrows on the bottom right of your PC screen, see image.) Note: The HotSync Manager icon may be hidden on Windows XP, please click the round white arrow button (see image) to unhide the icon. HotSync Manager Icon Example 2. Click on "Custom". If you see any of the above mentioned program conduits listed in the "Custom" screen ABOVE the PocketMirror conduits (Outlook Calendar, Outlook Contacts, Outlook Tasks & Outlook Notes) then uninstall any of these 3rd party programs. To do this go to "Start/Settings/Control Panel" or "Start/Control Panel" and double-click on Add/Remove programs. Then reinstall these programs from the original source media. Option 6: If you are using Outlook 98/2000, please follow the steps in Chapura FAQ PM108 "How do I change Outlook from "Internet Only" to "Corporate/Workgroup" Mode?"
Sep 11, 2005 | Palm m125 Handheld
1,606 people viewed this tip
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
