Tip & How-To about Cameras
Digital camera batteries' Don't Notes
Olympus li-12b Battery can be only used on the designated equipment. Do not heat the battery or dropped into the fire. Do not put the battery with necklaces, hairpins, coins, or screws and other metal items together in pocket or bag, they should not be stored together with the battery with the above-mentioned items. Do not use sharp objects to pierce the battery. Do not break down the battery. Do not reverse the positive and negative when load the olympus li-10b battery. Do not put it near fire or into the car at temperature over 60'.Do not discharge under these circumstance. Do not put the battery into the water, do not make them wet. Do not weld the battery directly. Do not use olympus li-40b battery with serious wounds or deformation. Before use your new Olympus Li-42B battery, please read the operating instructions. Improper operation may lead to Olympus Li-42B battery heat increasing, fire, explosion, destruction or attenuation of battery capacity.
Cameras Logo
My Olympus charger for the LI 10B battery does not light and charge the battery. Can the charger be fixed or do I need to buy a new one? By the way, my camera is Olympus C5000. Thank you.
I would say that you need a new charger. Standard chargers that come with digital cameras will eventually deteriorate depending on how often you use it. However, it could also be a battery issue, as batteries eventually will die even if they are rechargeable. I would try the charger with a different battery and see if it works, and if not, then you will know that the problem is with the charger.
May 07, 2011 | Olympus Battery Li-10B Li-12B (D6102003)...
sir My camera's( olympus stylus-1000)batery is in trouble. could you please give some authorization service centers in Cochin , Kerala, india. Your"s faithfully subhash
"sir
My camera's( olympus stylus-1000)batery is in trouble."
Hah! I love that! Not making fun or nothing, but many people aren't as polite to put "Sir or Madam" before writing things down. Very polite. :D
As for your battery; it'd be easier just to buy a new battery pack from off the internet, as repairing a battery pack would be impossible, or cost as much as buying a new pack itself.
Nov 30, 2008 | Olympus LI-12B (200838)
Is the battery that comes with the camera rechargeable?
Yes, the battery that comes with the C-7000 can be recharged. This battery is the Olympus LI-12B Lithium Ion battery and it can be recharged using the LI-10C battery charger. Both the battery and charger are included with the camera.
Sep 04, 2005 | Olympus C-7000 Zoom Digital Camera
Type of battery
The Olympus LI-12B (supplied) or LI-10B lithium ion battery can be used with this camera. Do not use any other type of battery. The battery is not fully charged when the camera is purchased. Charge the battery using the supplied cradle before using the camera.
Sep 01, 2005 | Olympus i:robe IR-500 Digital Camera
150 people viewed this tip
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
