Tip & How-To about Computers & Internet
Outlook restart in office 2007
When this happen do not reinstall the office. Kindly follow these steps: 1 Uninstall the office completly . 2.Locate the office folder and delete it from where ever located. you can search the folder (start>search>files and folder>type office in the search box). 3.If it does not let you delete the folder kindly restart the system and try to delete the folder. 4.Once uninstall and deleted the folder then restart the system, and re-install the office with SP2.This will resolve the issue.
Computers & Internet Logo
how can i fix error 1404 on microsoft office 1010
  1. If you receive the "Error 1404" error message, remove the registry subkey that is referred to in the error message. To do this, follow these steps:
    Warning If you use Registry Editor incorrectly, you may cause serious problems that may require you to reinstall your operating system. Microsoft cannot guarantee that you can solve problems that result from using Registry Editor incorrectly. Use Registry Editor at your own risk.
    1. Click Start, click Run, type regedt32 in the Open box, and then click OK.
    2. Locate the registry subkey that is referred to in the "Error 1404" error message. Make sure that you locate the exact registry subkey that is specified in the error message.
    3. Right-click the registry subkey that you located in the previous step, and then click Permissions.
    4. Under Group or user names, click Administrators, click to select the Full Control check box under Allow, and then click OK.
    5. Right-click the registry subkey, and then click Delete.
      When you are prompted to confirm the deletion, click Yes.
  2. Start Windows Explorer, and then locate the drive:\Winnt\Installer folder. In this folder location, drive is the hard disk where Windows is installed.
    Note This folder may be hidden. If the drive:\Winnt\Installer folder does not appear in Windows Explorer, follow these steps:
    1. On the Tools menu, click Folder Options, and then click the View tab.
    2. Under Advanced settings, click to select the Show hidden files and folderscheck box, and then click OK.
  3. Grant appropriate access permissions for the drive:\Winnt\Installer folder for the following groups: Administrators: Full Control
    SYSTEM: Full ControlTo do this, follow these steps:
    1. Right-click the drive:\Winnt\Installer folder, and then click Properties.
    2. Click the Security tab.
    3. In the Name list, click the appropriate user group or user name that you want to assign permissions for. For example, click Administrators.
    4. Under Allow, click to select the check box for the appropriate permission that you want to set, and then click OK. For example, click to select the Full Controlcheck box, and then click OK.
  4. Restart the computer.
  5. Insert the microsoft office CD into the CD or DVD drive, and then run the microsoft office Setup program.
  6. After the microsoft office Setup program has completed running, reinstall your antivirus software program.
Nov 10, 2010 | Microsoft Office 2003 Basic Edition...
Error code 8007007e
Unfortunately after reading around, it looks like you have to uninstall Windows Live Messenger then reinstall it.
Feb 15, 2010 | Microsoft Windows Live Messanger
162 people viewed this tip
David Payne
David Payne
