Tip & How-To about Computers & Internet
How to Connect Wi-Fi Connection
Laptop user must know how to set up. to connect toWi-Fi locations. Using Windows XP in this tutorial, we'll go throughthe steps for setting up a laptop to access a Wi-Fi network. Some Wi-Ficards can be set to automatically detect and connect to Wi-Fi networks,though it is still important to know how to manually set up your Wi-Ficard to connect to a wireless network.
  • Before you attempt to use any Wi-Fi network, find out what the SSID, Channel, Mode and WEP keys are. Some Wi-Fi locations do not require a WEP key. Many Wi-Fi providers have this information on their Web site or they'll give you the information when you purchase access.
  • Ensure you have a firewall program installed and running. This will protect your data.
  • Start up your laptop and look for the Wi-Fi network icon in the bottom right of the screen.
  • Click on the Wi-Fi Connection icon on bottom right of screen and you should see a window that indicates connection, strength and duration. Click onthe Properties tab
  • This window shows the type of networking card installed. Click on the Wireless Networks tab.
    Once the Wireless Network Connection Properties window is open, you will have two options depending on how you set up your laptop. If you do not see any networks listed in Preferred or Available networks,you will have to manually add the SSID. Click on Add. You will have toenter the SSID and WEP key (if required). Click OK and you should then see the network you just added in the Available Networks box.
    If you see the correct SSID showing in the Available Networks, then youn eed to click on Configure in order to enter the WEP key if that is required.
    In this window, enter the SSID for the Wi-Fi network you want to a ccess. Make sure you do not have CAPS lock or NUM lock while entering the information. If a Network key is required, click on "DataEncryption and then enter the Network key you have been provided with.Again make sure you do not have CAPS or NUM lock on. Click OK when entered. If you have entered the key incorrectly, a message will pop up and you will need to re-enter the key.
    Next go to Start - and where it says Connect To click on that and you should see choices similar to the graphic below. Click on WirelessNetwork Connection and it should work. Potential Problems & Their Solutions:
    Thereare occasions when the connection doesn't work. In these cases check your firewall software and make sure it allows you to connect to the Wi-Fi network. To check this, disable your firewall software and check the connection again. If you can connect with the firewall programd isabled, you will need to change your firewall settings. If your firewall program is not the problem, check the SSID and WEP key information that you entered. Both of these are case sensitive. If you had obtained SSID information from the Internet, check with someone in the establishment to see if the SSID has been changed.
    Computers & Internet Logo
    how to set up wireless printer on windows 7 net book
    I have just bought an epson sx435 wireless printer. I have set it up on my xp desktop with usb cable. How do I set it up to be wireless on xp
    and how to I set it up on my Acer Aspire one 522 netbook running windows 7.
    Home > Printer Wi-Fi Setup Setting up a Printer Wi-Fi Network Using the Control Panel Using the Wi-Fi Setup Wizard with LCD panel WPS setup You can set up a Wi-Fi network for your printer by using the printer's control panel. Using the Wi-Fi Setup Wizard with LCD panel If your printer has an LCD panel, you can use the Wi-Fi Setup Wizard to simplify manual setup. mark_no.gifNote: This setting is not available for all printers or may not be enabled. Make sure that the Wi-Fi is enabled on your computer in advance. Check the SSID and password for your network as these are required during Wi-Fi setup. If you do not know the SSID and password, check with your network administrator. For step by step information on setting up a Wi-Fi connection using the Wi-Fi Setup Wizard, click the following link. This feature is not available for all printers or may not be enabled.
    exlink.gif../p_body/panel/wizard/manual_01.htm
    Well to start with xp look at the following.
    http://support.epson-europe.com/onlineguides/en/sx430sx435w_nwg/html/index.htm
    May 30, 2012 | Computers & Internet
    my notebook cannot connect to the wireless router. its on my wifi but i cannot connect to the internet. it says dns server error
    Hi Dear Being able to connect to a wireless network or wi-fi hotspot is fundamental for mobile work and play. The step by step directions in the wi-fi tutorial below will help you set up your laptop so you can connect to a network wirelessly for Internet access or to share files with other computers on the network. Examples are given for Windows XP, Vista/7, and Mac.
    1. Find the wireless network icon on your computer (on Windows, you'll find an icon that looks like 2 computers in your taskbar on the bottom right; Macs will have a wireless symbol in the top right).
    2. View available wi-fi networks by either right-clicking the icon and selecting "View Available Wireless Networks" (Windows XP) or left-clicking the icon and selecting to "Connect or disconnect..." (Windows Vista). On Mac OS X and Windows 7, all you have to do is click on the wi-fi icon to see the list of available networks.
    3. Choose the network to connect to by clicking the "Connect" button (or just selecting it on Win7/Mac).
    4. Enter the security key -- if the wireless network is encrypted (with WEP, WPA or WPA2), you'll be prompted to enter the network password or passphrase. This will be stored for you for next time, so you'll only have to enter it once.
    5. On Windows 7, select the type of network this is -- Windows 7 automatically sets up security for different network location types (Home, Work, or Public).
    6. Start browsing or sharing! You should now be connected to the wi-fi network; open your browser and visit a website to confirm.
    Tips:
    1. Make sure you have a firewall and updated antivirus software especially if you're accessing a public wi-fi hotspot. Open or unsecured wireless networks are not safe at all.
    2. In Windows XP, make sure you have updated to SP3 so you have the latest WPA2 security drivers.
    3. Some wireless networks are set up to hide their SSID (or network name); if you don't find the wi-fi network in your list, ask someone at the establishment for the SSID information.
    4. If you are able to connect to the network but not the Internet, make sure your network adapter is set to automatically get its IP address from the router or try other wireless troubleshooting tips.
    5. If you can't find the wireless network icon, try going to your control panel (or system settings) and the network connections section then right-clicking on the Wireless Network Connection to "View Available Wireless Networks". If the wireless network you're looking for isn't in the list, you can manually add it by going to the wireless network connection properties as above and clicking on the selection to add a network. On Macs, click on the wireless icon, then "Join Another Network...". You'll have to enter the network name (SSID) and the security information (e.g., WPA password).
    Sep 20, 2011 | D-Link DIR-600 Router
    I have a laptop dell with vista windows, i want to make it wireless , using my wireless router ,how do it using the model of birght house step bystep. thank you.
    You need to configure your router.
    For that Connect your router to computer with ethernet cable then you can access it with following default link.
    http://192.168.0.1
    or
    http://192.168.1.1
    If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it.
    Then it ask for user name and password.
    Type user as "admin" and password as "admin" or "password" or blank.
    Then you can see configuration page of router.
    Click on WAN settings and set those settings as your internet service provider settings.
    Enable DHCP if you want to get ip from router.
    Clickon wireless settings enable wireless then enable WEP Security then add WEP code .It is your password to connect wi fi.Then save settings and restart router.
    Then you can connect your wi fi network with that code.
    Then in vista make sure wireless lan driver installed then right clickc on wi fi icon and click on view available wi fi then you can connect it.
    Let me know if you need further assistance.
    Thanks for using FixYa.
    May 05, 2010 | D-Link AirPlus DI-614+ Wireless Router
    Unable to connect two wireless laptop for internt sharing
    Make sure your computers are set to DHCP instead of static.
    Sep 04, 2009 | Dell Inspiron 6400 Notebook
    323 people viewed this tip
    David Payne
    David Payne
