Tip & How-To about RIM BlackBerry? Tour 9630 Smartphone
BlackBerry Tour: How to hide or show programs
You may have several applications on your BlackBerry that you don't use very often. But you don't want to delete them, because one day you might decide you want them. The easy solution is to hide them, so you don't see them during regular use, but they're there if you ever need them.
To hide a program, highlight it with the trackball and click the BlackBerry button (the one that looks like a paw print). Then just select Hide from the menu, and that program will disappear from view.
If you later decide you want it back, click the BlackBerry button anywhere in the Home folder (or whichever folder that application was located in) and choose Show All from the menu. Hidden programs will show up, but they will look fainter than the other programs, as if they were faded or washed-out.
You can leave your BlackBerry set to Show All to see the hidden program, or you can "unhide" it so it's always visible. To do that, highlight the program and click the BlackBerry button, then select Hide again to remove the check mark. The program will be visible again.
Once you've made the program visible again, you can either uncheck Show All or leave it checked. Show All can not be applied to some folders and not others; if you select Show All in the Games folder, for example, hidden applications in all folders (including Home) will be visible.
The same procedure works for folders as well as applications, and it also will work for applications or subfolders that are located in another folder beside the Home folder.
RIM BlackBerry? Tour 9630 Smartphone Logo
My storm 9500 can't download any software I have tried several times keep on denying.
Add, update, or delete applications on your device
You can add, update, or delete applications on your BlackBerry® device using the Applications screen in the BlackBerry® Desktop Software.
When you connect your device to your computer, your device is scanned and the applications are listed in the Applications pane.
1. Connect your device to your computer.
2. In the BlackBerry Desktop Software, click Applications.
3. When your device applications are listed, do any of the following:
• To update an application, click the + icon beside the name of the application.
• To delete an application, click the x icon beside the name of the application.
• To install an application file (.alx) that is saved on your computer, click Import files to browse to it.
4. In the Application Summary pane, review your changes.
5. Click Apply.
Dec 03, 2010 | 123Renamer Quick Flash Player
Blackberry Pearl 8120 - sms, email and call log being deleted
On the Status screen of the BlackBerry smartphone, the File Free field indicates low ,if the device memory is full then these things will happen on your device,so to never have this problem delete unwanted applications.To delete run desktop manager and select application loader,select the applications that are not frequently used and remove them.Also keep the messages for a month or two because these mails will be there in your mail box.
Jul 20, 2009 | RIM BlackBerry Pearl 8120 Cellular Phone
blackberry curve 8320 camera
Take the battery cover off. Take your finger and press on the lens area (below the flash) you should hear a "snap". Don;t over do it though.
Jul 07, 2009 | AT&T Blackberry Curve 8300 Smartphone
I get this: App error 205 / reset - Hour glass keeps running. I removed the battery several times.
If it is application error then follow these steps: Warning: You should not install a version of BlackBerry Device Software that is earlier than the version installed on the BlackBerry smartphone. Doing so could cause the BlackBerry smartphone to malfunction. Before proceeding, make sure that the latest version of BlackBerry Device Software is installed on the computer by completing the following steps: Open BlackBerry Desktop Manager. Click Help. Select About Desktop Manager. Click the Device Software tab. Verify that the BlackBerry Device Software displayed is the latest version currently available from the wireless service provider. Warning: The following procedure will delete either all data, or all data and applications on the BlackBerry smartphone. Back up the BlackBerry smartphone data before proceeding. To perform a clean installation of the BlackBerry Device Software using BlackBerry Desktop Manager 4.1 to 4.3, complete the following steps: Connect the BlackBerry smartphone to the computer and open BlackBerry Desktop Manager. Double-click Application Loader. Click Next to start the installation process. Type your BlackBerry smartphone password, if prompted, and click OK. Select the check boxes next to the names of the applications you want to load, and then click Next. Click Advanced, and then select the check boxes beside Erase all application data and Erase all currently installed applications . Click Next. Select the check box next to Do not automatically backup the application data during the loading process (if prompted). Clear the check box next to Backup and restore applications installed wirelessly (if prompted). Click Next > Finish. When the process has completed, the message The loading operation was successful will appear. Click Close to return to BlackBerry Desktop Manager Note: BlackBerry Desktop Manager 4.3 will display the Delete all application data and Delete all currently installed applications check boxes in step 6 of the above procedure. To perform a clean installation of the BlackBerry Device Software using BlackBerry Desktop Manager 4.5 and 4.6, perform the following steps: Connect the BlackBerry smartphone to the computer and open BlackBerry Desktop Manager. Double-click Application Loader. Click Add/Remove Applications. Type your BlackBerry smartphone password and click OK. Select the check boxes next to the names of the applications you want to load. Click Settings, and then select the check boxes beside Delete all application data and Erase all currently installed applications. Click OK. Click Next > Finish. When the process has completed, the message The loading operation was successful will appear. Click Main Menu to return to BlackBerry Desktop Manager. Note: The Delete all application data and Delete all currently installed applications options are not available when using the Application Loader in BlackBerry Desktop Manager 4.5. A workaround for this issue is to use the Application Loader standalone file by performing the following steps: Open My Computer (or Computer in Windows® Vista?). Navigate to C:\Program Files\Common Files\Research In Motion\AppLoader. Run the Loader.exe file and follow steps 3 through 9 above to complete a clean installation of the BlackBerry Device Software.
May 26, 2009 | RIM Blackberry 8310 8320 8330 Curve 8100...
1,037 people viewed this tip
Top RIM Cell Phones Experts
Computer Repairing
Computer Repairing
Longtime User
Jason
Are you a RIM Cell Phone Expert? Answer questions, earn points and help others
