Tip & How-To about Computers & Internet
How to Test Your Webcam Frames Per Second Performance
Have you ever wondered how many frames per second yourwebcam is sending? Choppy video, with out-of-sync audio, is typicallydue to low fps. Anything less than 8-10 fps is going to be noticeable.Now there is a free service that allows anyone to test their webcam fps. You don't have to download anything and you don't even have to register for an account. The service is called mailVU.com, and here's how to use it to measure your webcam performance.
Open any browser (Firefox, Chrome, IE, Safari, etc.) and go to http://mailVU.com. You will be prompted to allow access to your webcam. Select Allow.
You can now see yourself on the left side under LiveCamera. If you don't see yourself click on the drop down list ofcameras and select the one that works for you. On the Mac it istypically called USB Webcam.
Click the red Record buttonabove your image to start the recording session. After you click it thebutton will change to Stop and a notification will appear thatrecording is in process. When done click the red Stop button. To view your message simply click the green Play buttonabove your image. Your recording will now play in the right side windowwhile you still see yourself live in the left side Live Camera window.
Look under the Playback window and you will see your webcam fps performance!You can try this test as often as you like, from multiple locations,and with multiple webcams. Try it with different lighting and differentInternet connections (wired/wireless) to determine the best for yoursituation.
By using mailVU.com anyone can quickly and easily test their webcam fps performance. And asan added bonus it also tests your webcam video and audio quality. Ifyou like, you can also record and send free video mail right from thesite. Try it today for free!
Computers & Internet Logo
how to set frame per seconds rate in a camera (sony dsc w210)
The DSC-W210 shoots video at 30 frames per second.
Apr 27, 2012 | Sony Cameras
When I record a video using my Nikon Coolpix s4000, when I try to play it back the sound plays at normal speed but the picture is in slow motion! This happens everytime I record a video, is there anything I can do? Many Thanks
Look for a Menu then FPS (Frames per second) option.30 fps should solve your issue. sometimes in order to keep file size low the setting is slower causing this issue.Good Luck.
Jul 29, 2011 | Nikon Coolpix S4000 Digital Camera
my webcam is choppy
This sounds like a webcam fps (frames per second) issue. It can be caused by several factors from browser cache, to Internet connection, to power. Try this FPS test site. It describes the factors which influence webcam fps, provides recommendations on how to get the best performance, and has a free method to test your webcam fps. Best of luck!
Feb 04, 2011 | GE EasyCam Webcam
I just got my Xacti CS1 and after I shot a couple of test videos, I checked the playback. On the camera screen, playback is flawless, it's quite great, however, when I play the videos back on my macbook in quicktime player, the video is choppy. It will skip a couple of frames every second. It just freezes and then all of a sudden it's a completely different frame like the video was cut and spliced together. What's wrong?
http://us.sanyo.com/dynamic/product/Downloads/VPC-CS1_OM_English-6223243.pdf
p.60 of the manual describes different recording modes with lower resolutions (1280x720) pixels and lower frames per second (30fps).
I would choose from the menu to record in a lower resolution and lower fps mode so that the quicktime program can display the video at a good rate for you.
I don't know what kind of macbook you have, but usually such problems are due to the older macs not having enough speed to display high definition video with all its data all at once.
I used to have problems a few years ago, before i upgraded my hardware on PC's, with choppy video that was High Definition.
Jul 30, 2010 | Cameras
I converted an MP4 file to AVI and when i play the movie on quicktime the audio is out of sync and the movie plays like its on fast forward. i am trying to upload it on youtube and when i put it on youtube as an mp4, the audio was all out of sync i just want to get the damn thing on youtube!!!!
Hello.
Give this a try:
Download the latest version of AVI audio sync tool: YAAI_2.0.3.488.zip
from http://findfiles.com/list.php?string=YAAI_2.0.3.488.zip&db=Mirrors&match=All&search=
First of all, make a backup copy of your avi file (this is very important!).
Step 1. Unzip YAAI_2.0.3.488.zip file. Launch YAAI.exe , "Open AVI" dialog will appear.
Step 2. Find and open your AVI file.
Step 3. Click on "Sync Audio" tab. Small video player will pop up.
Step 4. Now, adjust audio delay or frame rate (FPS) using sliders or appropriate buttons.
Click Apply. Video player will start playing your file with changed settings automatically. You can adjust and apply these parameters several times to pick up necessary values for audio delay or FPS. So, try to experiment and to set appropriate audio delay or to change FPS (frames per second) settings for your avi file.
Step 5. Finally, close YAAI tool. When it asks the question: "Do you want to keep the changes?", click Yes.
Hope this helps.
Feb 02, 2010 | Computers & Internet
2,488 people viewed this tip
David Payne
David Payne
