Tip & How-To about Computers & Internet
FCE to FLV/SWF converter, embed FCE project in webpage
One friend of mine is using Final Cut Express to edit your film footage and the final film will be uploaded to your website for viewing. He need to get the videos to FLV format for easily web viewing. Unfortunately, FCE doesn't export to FLV. Do you have this problem with my friends?
My advice is to use FCE to Flash converter. The FCE to FLV converter can meet your need to convert FCE exported movie to FLV/SWF and generate a HTML web page embedded with flash player so that you can easily upload movie exported from Final Cut Express to Youtube and insert your masterpiece created in FCE to your website.
Step1. Export Video from Final Cut Express
Export video from Final Cut Express. And the exported video is in the MOV format.
Step2. Launch the FCE to Flash converter
After download the FCE to Flash converter, double click its item to launch it. The interface is user-friendly, look like this:
Step3.add MOV files exported from FCE
Press "Add Video" button on the top of the interface and browse the pop-up directory, choose all mov files exported from FCE to import into the converter.
Step4. Add effect
Hit the "Effect" tab. Select a cool special effect for you flash.
Step5. Start FCE to Flash conversion
You just need to click the "Start" button and the FCE to Flash conversion will start automatically.
Knowledge on Final Cut Express
Final Cut Express(FCE) is a powerful and extensible video editing software designed by Apple Inc. The supported video formats by FCE is DV, HDV and AVCHD. The special feature is its ability to import iMovie 08 projects and use iMovie as a video library. Among three distinct tiers of video-editing software Apple offered (iMovie, FCE, FCP), iMovie catered to beginners, Final Cut Express mid-level video editing fans and Final Cut Pro pro-level editing people.
Next: How to convert videos to Flash, SWF, FLV on mac with video to Flash/FLV/SWF converter for mac.
Computers & Internet Logo
How to Export Movie from Final Cut Pro (FCP) to FLV? After editing your own movies on Final Cut Pro or Final Cut Express, you may want to put them on your website for presenting your introduction or promoting your services/products. For users with the older version of FCP, FCE or iMovie, it is easy to export FLV by choosing File > Export > Using QuickTime Conversion. However, if you could not find Flash FLV as output format from FCP/FCE/iMovie, you may need a FCP to FLV converter to get Flash videos. Aunsoft Video Converter for Mac is the best FCP to FLV converter for you to handle videos on iMac/MacBook Pro with Snow Leopard or Leopard. The Mac FCP to FLV converter supports loading .3gp, .m4v, .avi, .dv, .flc, .mp4 videos from FCP/FCE/iMovie and converts FCP movies to FLV as short film. Below are the steps to export Final Cut Pro movie to FLV with Aunsoft Video Converter for Mac. Step 1. Load Final Cut Pro movies to Aunsoft Video Converter for Mac. After exporting movies from Final Cut Pro, run Aunsoft Video Converter for Mac as the Mac FCP to FLV converter, and click the "Add" button to load FCP short films for conversion. Step 2. Choose FLV output format. Click the "Format" option and choose Flash Video > FLV-Flash Video Format(*.flv) as output format. This format is compatible to most machines. Step 3. Transcode FCP movies to FLV. Click the "Convert" button under the preview window, and the Mac FCP to FLV converter starts converting Final Cut Pro movies to FLV for playing on webpage. Tips: 1. After converting Final Cut Pro movies to FLV, you need Flash players to navigate the video playback on webpage. You can use free web players like JW player, Moyea PlayBox player and Flow player to present your short films on website. 2. You can set the video resolution of the FLV videos by clicking the "Settings" before conversion. 3. The above step-by-step guide with Aunsoft Video Converter for Mac also works for the movies exported from Final Cut Express and iMovie. In other words, you can also convert FCE movies to FLV, iMovie videos to FLV on Mac OS X.
Jul 22, 2010 | Cell Phones
Importing video from Xl1 canon into my Mac
you must use the third party software convert your video files format to final cut express support formats.such as dv,mp4,mov
if your video files is .tod format,you can use tod to final cut express converter.
http://www.fceconverter.com/tod-to-final-cut-express/
if it's .mod files format, you can use mod to final cut express converter
http://www.fceconverter.com/mod-to-final-cut-express/
Mar 27, 2008 | Sony Handycam DCR-TRV18 Mini DV Digital...
Get Final Cut Pro 5.04 to communicate with my XH A1
Many HDV cameras and decks are able to play and record DV as well as the higher-resolution HDV format. Additionally, many of these HDV devices will attempt to automatically change their settings to match the format of the tape that it's playing. Here are some tips for using these types of devices with Final Cut Pro / Final Cut Express.
Tip: Make explicit settings on your HDV device. Instead of using an "Auto" setting, make your own settings on your HDV device to keep the communication going between it and Final Cut Pro / Final Cut Express. This also helps Final Cut Pro / Final Cut Express keep things running smoothly with HDV devices that handle both DV-NTSC and DV-PAL.
For example, say you're using an HDV deck to capture footage from a tape that was recorded as DV-NTSC. Before capturing in Final Cut Pro / Final Cut Express, make sure that you set the deck to DV mode specifically—don't rely on Auto mode. With some devices, you may need to disconnect it from FireWire to change the mode.
For a common capture workflow, this sequence of steps can provide the best results:
  1. Quit Final Cut Pro / Final Cut Express if it's open.
  2. Insert your tape into your HDV deck or camcorder.
  3. Use the device's menus to set it to match the format that's recorded on the tape.
  4. Connect your HDV device to your computer with a FireWire cable.
  5. Open Final Cut Pro / Final Cut Express.
  6. Choose an Easy Setup for DV or HDV (whichever matches the format recorded on your tape).
  7. Proceed to Log and Capture.
Tip: Quit Final Cut Pro / Final Cut Express before changing modes. It's generally a good idea to quit Final Cut Pro / Final Cut Express before you change the mode on your device from DV to HDV, or from HDV to DV, and then re-open the application again.
Tip: Use an Easy Setup to play back non-default HDV format footage on your HDV device. You can use Final Cut Pro / Final Cut Express to make your HDV device play back footage in its non-default HDV format. For example, maybe you have a 1080i60 HDV device and want to play back footage that was recorded as 1080i50. Or perhaps you have a 1808i50 HDV device and you want to play back footage that was recorded as 1080i60. To do this, follow these steps:
  1. Connect your camera to your computer.
  2. In Final Cut Pro / Final Cut Express, choose an HDV preset Easy Setup that matches the format of the tape's footage (you don't need to restart Final Cut Pro / Final Cut Express).
  3. Your device's LCD display should automatically display a switch to 60 or 50, indicating the type of media that's being played.
Playing back non-default DV format footage on your HDV device You can also use your HDV device to play back footage in its non-default DV format too. For example, maybe you have a 1080i60 HDV device and want to play back footage that was recorded as DV-PAL. Or maybe you have a 1080i50 HDV device and want to play back footage that was recorded as DV-NTSC. If so, follow these steps:
  1. Make sure that your device is in DV/DVCAM mode.
  2. Put your device into Play/Pause mode, then open the Log and Capture window in Final Cut Pro / Final Cut Express.
  3. Make sure that your device's LCD (or other readout screen) displays the same format as your tape or Final Cut Pro / Final Cut Express will misinterpret what type of device you have.
Tip: Avoid recording both HDV and DV formats on the same tape. Use separate tapes whenever you want to record in a different format. If you need to record over existing footage in a different format (for example, you have a tape with DV-PAL on it, but you want to record over it with HDV 1080i50), it's a good idea to black and code the tape, or completely record over the old footage with contiguous recording in the new format. If the tape contains even a second of, say, DV in the middle of an HDV tape (or vice versa), it could cause unexpected results later when you try to capture video from that tape.
For more information, see HD and Broadcast Formats and the Final Cut Pro / Final Cut Express User Manual, available under the Final Cut Pro / Final Cut Express Help menu
Dec 04, 2007 | Canon XH A1 Mini DV Digital Camcorder
176 people viewed this tip
David Payne
David Payne
