Tip & How-To about Microsoft Windows XP Home Edition
Restore Windows XP to Previous Working State
You can recover the windows critical components and return your computer to earlier state without loss of personal data using windows XP built-in system restore feature. With new programs being installed, viruses infecting and spy ware creates problem in your browsers it is not unusual for your computer to suddenly stop behaving correctly. So you can perform the windows recovery process and return your computer to earlier state within a minute.
Follow the given steps to run System Restore wizard:
To use this feature, you will need to be logged into your computer with administrative rights:
  • First click on Start button.
    >>All programs.
    >>Accessories.
    >>System Tools.
    >>Then click on System Restore.
Now a "Welcome to System Restore" wizard will start, first read the detail instruction on left side of the page.
On right side of the page, click on "Restore my computer to an earlier time" check box under "To begin, select the task that you want to perform" area and then click on Next button
On the "Select a Restore Point" page, click on bold date option, but try to use a restore date as close as possible to a time just before the problem started then click on Next button
Now a next page will appear with title "Confirm Restore Point Selection", to restore your computer to this date and time then click on Next button to start the restore process.
Now system restore process recover the previous windows settings and your computer
will restart with "Restoration Complete" message, click Ok button to finish the process.
Microsoft Windows XP Home Edition Logo
where is the reset button
If you mean how do you return to factory condition, press F11 just before it boots and follow the prompts.
Recovering your computer without recovery discs
Creating recovery discs (or USB storage device solution)
Ordering recovery discs from HP in the United States and Canada
Finding recovery discs from other Web sites
Contacting Support
HP recovery discs can be used to return a computer's software configuration to its original condition. HP provides a recovery solution on the hard drive, but it is still a good idea to keep recovery discs stored in a safe place in the event of a hard drive failure. Use the sections in this document to obtain a recovery solution that works best for you.
NOTE:HP computers designed for commercial use, such as Workstations or Pro series, use "Operating System" or "HP Restore Plus" DVDs. To order these types of discs, go to the HP Replacement Part Store . Recovering your computer without recovery discs You may not need recovery discs to recover the software on your computer. HP provides a recovery solution on a separate area of the hard drive. If the hard drive is still functional, you can still perform an HP system recovery from the hard drive as long as the recovery information has not been destroyed or corrupted.
To do a software recovery from the hard drive, turn on the computer and repeatedly press the F11 key until "Windows is loading files..." displays on the screen. If your computer originally came with Windows XP or earlier, press F10 to enter recovery instead of F11.
  • graphic.php?im=im_e58rok73o1nlhbzFeedback
  • Dec 21, 2013 | HP Pavilion dv6000z Notebook
    Serial ref WO01099133 VY1243000817 VOY64 Will not start up - contaiminated system 32\Drivers
    spacer.gif How to troubleshoot Windows XP startup problems, spacer.gif spacer.gif spacer.gif
    splash_icon_quick_poll.gif CHECKLIST ib_right_arrow.gif How to troubleshoot Windows XP startup problems
    One of the most common troubleshooting issues in Windows XP is the failure of a system to start up properly. These failures can be caused by a number of issues, including poorly written or malicious software, faulty device drivers, hardware incompatibilities, corrupt or missing system files and incorrect system configurations. Determining the source of the startup problem, and fixing it, is easier if you use a methodical, step-by-step approach.
    If the system will not start in Normal Mode or Safe Mode
    A Windows XP system that will not start in Normal or Safe Mode is not a good sign and may be the result of corrupt or missing system files, a corrupt registry, hardware drivers or failed services. Your first step is to press F8 during Startup and select the Last Known Good Configuration option from the Windows Advanced Options Menu. If Windows boots normally, check the event logs and hardware manager for clues as to what may have caused the failure. You may also want to check the Add/Remove Programs menu for any new applications that may have contributed to the failure.
    If the Last Known Good Configuration fails, the next step is to start the Recovery Console by booting from the Windows XP Startup CD and pressing "R" to repair when the "Welcome to System Setup" screen appears, then press "C" to start the Recovery Console. The Recovery Console is a command line utility that can be used to identify and solve a number of issues in the event that Windows cannot start, including starting and stopping services and drivers. If you receive an error on startup stating that a system file is missing or corrupt, Recovery Console can be used to replace those files as well. For a list of available commands, simply type HELP at the command prompt. For more detailed information about the Recovery Console, check out Microsoft Knowledge Base article 307654.
    If you are unable to determine if a driver or service is responsible for the startup failure, you should run the Checkdisk utility from the Recovery Console by typing CHKDSK at the command prompt. This utility scans your hard drive and checks for problems with the disk or file system, which may result in corrupt or missing system files. You should also check the system CMOS and BIOS settings for configuration errors or corrupt data. Note: CMOS and BIOS data corruption can occur as a result of a dead or weak internal battery. Check your motherboard documentation for details.
    If you are still unable to determine the cause of startup failure at this point, you have the following options:
    1. Use System Restore to return your critical system files and some program files from a previous restore point. I've had mixed results with System Restore, but at this point, it is still worth a shot. System Restore can be activated from the Recovery Console. The advantage of using System Restore is that your personal files located in My Documents will not be overwritten or deleted. More information can be found in Microsoft Knowledge Base article 306084.
    2. Restore from a backup tape: While this method will recover your system, you will lose any data stored on your workstation that was created after the system was backed up. This method will also not help you identify the root cause of the startup failure, which may occur again.
    3. Perform an in-place upgrade (reinstallation): This process reinstalls the operating system but may result in data loss if not done correctly. The advantage is that it should return the workstation to a bootable state in which important files can be copied. Applications, service packs and system updates may need to be reinstalled for the system to function properly. For more information, see Microsoft Knowledge Base article 315341.
    4. Perform a parallel installation: A parallel installation involves creating a second Windows XP installation on the same workstation, either in a new folder or on a secondary (slaved) hard drive. The advantage of this approach is that it allows data to be recovered on the primary drive, assuming disk failure was not the cause of the startup issue. After any critical data is recovered, the original installation can be restored from backup source and updated with the new files.
    Jul 30, 2008 | Evesham Computers & Internet
    \windows\system32\winload.exe missing or corrupt 0xc000000f
    ":\windows\system32\winload.exe " Status: 0xc000000f This error message states a missing or corrupt Winload.exe file, due to which the booting process of the system halts and the data stored in the hard drive becomes inaccessible. Cause: Following are the causes for the corruption in Winload.exe: Software or hardware issues. Corrupt Boot Configuration Data (BCD). Incompatible partition. Resolution: To resolve the above issue, consider the measures below: To fix the corrupted Winload.exe file, use the Windows Recovery Environment. To do so, use the Startup Repair option in the System Recovery Options dialogue box and choose the operating system to repair. Using the Windows Recovery Environment will restore the system to a particular point, which will get the system to an appropriate working state. In most cases, the above measures will help you to resolve the issues related to Winload.exe. But, if the problem persists, then you will need re-install Windows. But, a clean re-install of the Windows operating system deletes all the data stored. In these situations, to recover your data completely, it isrecommended to use a high quality Windows Data Recovery Software. The Windows Data Recovery application incorporate advanced scanning algorithms to ensure quick and comprehensive recovery of your data. Stellar Phoenix Windows Data Recovery v4.1 is the most appropriate utility that recovers your lost, deleted or inaccessible data accurately. The Windows Data Recoveryapplication offers highly intuitive graphical user interface, that makes it easy to use and understand without any prior technical understanding. This recovery tool is fully competent to recover data from FAT16, FAT32, VFAT, NTFS and NTFS5 file system based disks. The read-only software is compatible with Windows 7 RCI, Vista, XP, 2003 and 2000.
    Jan 16, 2013 | Acer Aspire 5610-4648 Notebook
    unable to login to the computer, the password is unknown. what should I do has windows 7
    Recommend you two most popular password recovery tools.The average person will use it first and many case proved that they can perfectly reset the windows vista password.
    Ophcrack(500M)
    Ophcrack is one of the most popular free Windows password cracker based on rainbow tables. It can help you reset Windows password less than 14 characters. Once you forgot Windows 7 password, it is a good choice to download the version compatible with Window 7. However, many Windows users failed to recover Windows password as its large ISO file which is more than 496MB.
    Download:http://ophcrack.sourceforge.net/download.php
    Windows Password Rescuer(34.3M)
    Windows Password Rescuer is a highly appreciated Windows password recovery toolkit, especially designed for novice or new beginners. With this tool, you can get instant access to locked computer without the old password and computer skills. Prepare a bootable CD/DVD or USB flash drive and follow these 4 steps with less than 5 minutes.
    Step 1: Download Windows Password Rescuer Professional and install it in any available computer
    Download: http://www.daossoft.com/download.html
    Step 2: Burn a bootable CD/DVD or USB flash drive
    Step 3: BIOS settings of your locked computer to make it boot from CD/DVD or USB flash drive
    Step 4: Reset Windows 7 password successfully
    Sep 28, 2011 | Acer Aspire M3400 PC Desktop
    897 people viewed this tip
    Top Microsoft Computers & Internet Experts
    micky dee
    Piyal Perera
    Piyal Perera
    Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
