Tip & How-To about Computers & Internet
Dvd Not Recognized /Itunes Registry Hack
Goto start type in regedit right click on it and run as administrator then goto hkey local machine click the + sign then goto then click on system then the + sign then goto current control set then click + sign then goto control click the + then goto class click the + sign then goto 4D and delete the upper and lower filters in that folder located on the right side of screen.
here is the comp[lete key.
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}
then navigate to this key
6D
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{6D807884-7D21-11CF-801C-08002BE10318}
then to this key
CE
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{CE5939AE-EBDE-11D0-B181-0000F8753EC4}
under each key delete the upper and lower filters from the folders once that is done close registry editor. then goto start control panel device manager goto dvd/cd rom click the + sign and right click on the dvd drive and delete and when the warning message comes up check the box underneath to delete the drivers for this device then close device manager and restart the notebook.
Computers & Internet Logo
I picked up this program called personal antivirus and I can't get rid of it.i looked in my programs and it's not even there.Any ideas?
go to start menu, then go to "run", then type regedit and hit enter.
Now you are in registry.
Find the HKEY LOCAL MACHINE and expand it, then find Software, and expand it. You should see your program here, right click and delete file.
Do the same with HKEY LOCAL USER
Also go to start menu, search , type program name. When found, right click and delete all files.
Oct 01, 2009 | HP Compaq Presario SR2180NX (RK548AA#ABA)...
cd drive not detected
Lets do this.
1. Close all programs
2.Click on Start, Run, and type REGEDIT and press Enter.
3.click HKEY LOCAL MACHINE - SYSTEM - Current control set - control - class - select {4D36E965-E325-11CE-BFC1-08002BE10318} - on the right hand side you'll find upper filters and lower filters entries - right click and delete both(Upper and lower filters) - restart your computer and hope this works for you,
Awaiting response.
Thanks..
Sep 08, 2009 | Acer Aspireā„¢ T180 PC Desktop
cd dvd rom not found
start
go to search
type: regedit
enter
find: hkey-local-machine/current control set/control/class/{4d35e965-e325-11ce-bfc1-08002be10318}
select upper and lower filter
right click
delete upper and lower filter
this work for vista operating systems
Feb 22, 2009 | Lenovo IdeaPad Y510 Notebook
optical drive not playing
This may not apply but it's worth a shot....
Click Start > Run
Type Regedit in the run box.
Open "HKEY LOCAL MACHINE > SYSTEM > CURRENT CONTROL SET > CONTROL > CLASS >
Look for keys called "Upper Filters" and "Lower Filters" and delete any values inside those keys, then restart the machine.
Note: If using Vista, be sure to right-click Regedit in the program list and choose "Run as Administrator", otherwise it won't let you change the values of the key.
Hope this helps,
Techneck09
Jun 10, 2008 | Dell Dimension 4700 PC Desktop
my cd rom drive is not appearing on my computer i have an equium a210
follow these steps
Click start
Click run
type regedit
keep clicking the plus sign next to
Hkey local machine>>System>>Current ControlSet>>Control>>Class
Under class click on the first folder that starts fro 4D and it would be like 4D36E965
Now at the right hand side you will see options like upper filters and lower filters just right click and delte them
If you dont see both of them no worries delete the one that you see .After this restart your system.and check
May 25, 2008 | Toshiba Computers & Internet
353 people viewed this tip
David Payne
David Payne
