Tip & How-To about Computers & Internet
USB DEVICE DOES NOT recognize
Issue:: USB DEVICE DOES NOT recognize
___________________________________
Manual Troubleshooting for this issue::
-Open device manager
-Right Click on USB Root Hub
-Choose Properties >>Selet Power Management
-Remove the Tick Mark Before "Allow the computer to turn off the power if device is not in use..."
-Do the same for all USB ROOT HUB
-Then Uninstall all USB ROOT HUB
-Restart your computer , USB device will be working.
Computers & Internet Logo
laptop not recognizing device when plugged into laptop how to fix
The computer is not recognizing the device because the appropriate software or driver is not installed on the device.
Most of the time when you connect a smartphone into a compatible laptop the device drivers or software automatically install, so the laptop may recognize the smartphone.
Here are some possibilities as to why the device is not recognized.
1) The USB port is bad.
2) The USB port is not activated
3) One of the devices does not support the other
Here are a few possible troubleshooting solutions:
1) Go to the smartphone manufactures website and download and install the updated device driver and software then plug in the device to see if it is recognized.
2) (if Windows OS) Go to the Device Manager to see if the device is showing up when it's plugged in. If you see the device in device manager right click the device and choose to update the driver.
3) (if Windows OS) Additionally, in device manager you can check your device's USB ports to see if there is an issue with the ports that may be resulting in the smartphone not being recognized. You can choose to re-enable the USB ports or update the software for the USB ports.
Hopes that helps resolve your issues.
Open Device Manager Windows Help
Nov 07, 2015 | Acer Computers & Internet
driver download
If your computer does not recognize the USB device, first try method 1 to work around this issue. Method 1: Initiate recognition of the USB device by using Device Manager To initiate recognition of the USB device by using Device Manager, follow these steps: Click Start, click Run, type Devmgmt.msc, and then click OK. The Device Manager window opens. Click to select your computer as the location for the scan. On the Action menu, click Scan for hardware changes. Windows XP recognizes the new device. Close the Device Manager window. If this method resolves the issue, you are finished. If this method does not resolve the issue, go to method 2. Method 2: Disable power management of the USB hub Note If you perform the following procedure, you may also reduce the battery life on a portable computer. Use this method if method 1 does not work. To disable power management of the USB hub, follow these steps: Click Start, click Run, type Devmgmt.msc, and then click OK. The Device Manager window opens. Expand Universal Serial Bus controllers. Right-click a USB Root Hub in the list, and then click Properties. The USB Root Hub Properties dialog box is displayed. Click the Power Management tab. Click to clear the Allow the computer to turn off this device to save power check box, and then click OK. Repeat steps 3 through 6 for each USB Root Hub in the list. On the Action menu, click Scan for hardware changes. Windows XP recognizes the new device. Close the Device Manager window. If this method does not resolve the issue, go to method 3. Method 3: Restart the computer To initiate recognition of the USB device, first unplug the USB device and restart the computer. Then, wait five to ten seconds before you plug the USB device into the computer or hub. Windows XP recognizes the new device. If this method does not resolve the issue, you might want to review the articles in the "Similar Problems and Solutions" section, or contact Support. For information about how to contact Support, visit the following Microsoft Web site: http://support.microsoft.com/contactus Back to the top ' Give Feedback
Nov 11, 2013 | Targus AMW05US Mouse
i cant see the pic on pc
I'm sorry that the Camera is not recognized by the Computer. Unfortunately, knowing the Operating System is the key element in providing troubleshooting the PC connection. However, I will give you the troubleshooting steps which is general for the compatible Operating Systems for the Camera:
The compatible Operating Systems are as follows:
Windows XP Windows 2000 Professional Windows Vista Mac OS X
Please follow the below troubleshooting steps below if your Computer is installed with any of the above mentioned Operating System. Please note that other Operating Systems are not compatible with your Camera. Please make sure that the connections are secure. Prior to making any adjustments, first ensure you've firmly connected your Camera's USB cable into the USB port on your PC. Power off and disconnect your Camera from your computer. Restart your computer. After your computer is rebooted, connect your camera to your computer using the USB cable provided. Note: Connect your camera to an alternate USB port, preferably on the back of your computer. Select MTP instead of default PC from the USB select screen appears on the LCD screen after connect the Camera to the Computer. If the issue persists, please check the Device Manager driver conflicts by following the steps: Connect the camera to the computer with the USB cable. Turn on the camera. Open the Device Manager of the operating system.
Windows 2000 - Right-click the My Computer icon, left-click Properties , left-click the Device Manager tab. XP: Right-click the My Computer icon, left-click Properties , left-click the Hardware tab, left-click the Device Manager button. Windows Vista: Click the Start button, click Control Panel , click System and Maintenance , click the Device Manager button. Windows 7: Click the Start button, click Control Panel , click Hardware and Sound , under Devices and Printers , click Device Manager. You may try the steps before give up even if the Operating System is Windows 7 as it supports many cameras with default driver. In the Device Manager window, at the left of Universal Serial Bus controllers , click the PLUS (+) symbol. Under Universal Serial Bus controllers , right-click Sony DSC or USB Mass Storage Device to display the drop-down menu. In the drop-down menu, click Uninstall or Remove. In the Confirm Device Removal dialog box, click the OK button. Restart the computer. Follow any on-screen instructions to complete reinstallation of the USB driver.
If the issue persists, reset the Camera by removing the battery for more than one minutes and check the operation. I hope following the above troubleshooting steps should definitely resolve the issue. If you require any further assistance, please get back to me with the exact Operating System, I can definitely help you with this. If a PC connection is not recognized by a Computer, most probably it will not be a hardware issue. Thanks for understanding.
Apr 10, 2011 | Sony Cyber-shot DSC-S750 Digital Camera
272 people viewed this tip
David Payne
David Payne
