Tip & How-To about Sony Playstation 3 (PS3) Console
Fix PS3 at Home - PS3 Problems
Hello there
Thanks for using FixYa.
Ok so if you have any of the following problems with your PS3 console, i will be able to help you:
1. No Display
2. Freeze up's
3. Hard Disk Corruption
4. Disk Read error
5. Red flashing lights
6. Yellow light of death
The best repair method to use is a PS3 reair guide, The problem now is finding the best one,
i use this website here it keeps me up to date with the best repair guides online today. PS3 Problems Gone
Sony Playstation 3 (PS3) Console Logo
Moved playstation to friends tv played fine. Connected back to my tv power lights come on but No sound or picture yet all cables are ok
You need to reset the display, follow these steps :
Step 1. Turn the PS3 off into standby (red light on)
Step 2. Press and hold the power button. It will beep when you first press it then beep again 5 seconds later. Release the power button when you hear this second beep.
Step 3. Wait for the PS3 to start up with normal display settings. If you are using HDMI make sure only the HDMI cable is connected when doing the above steps.
Hope this helps and thank you for using FixYa
Nov 14, 2010 | Sony Playstation 3 (PS3) Console
the playstation is comin on but i cant gat a picture on the tv why tried on different tv worked fine last nite
Ok, follow these simple steps and your PS3 should display properly on the TV.
Step 1. Turn your PS3 onto standby (red light on)
Step 2. Press and hold the power button. It will beep as soon as you press it then beep again 5 seconds later. Release the power button
Step 3. Wait for the PS3 to restart.
This resets your video resolution back to standard definition. You should now be able to setup your video settings correctly using the PS3.
Aug 15, 2010 | Sony Playstation 3 (PS3) Console
just changed tv's for my ps3, and it display
Do the following steps to solve your PS3 problem :
Step 2. Press and hold the power button. It will beep as soon as you press it and then about 5 seconds later it will beep again. Let go of the power button when you hear this second beep.
Step 3. Wait for your PS3 to start.
This solution basically resets the video output back to standard definition.
Jan 16, 2010 | Sony Playstation 3 (PS3) Console
no display on tv scart 2 or hdmi
Hello, what you need to do is reset the video display. Do this by following steps :-
Step 2. Press and hold the power button. It will beep once when you first press it, then again 5 seconds later. When you hear this second beep let go of the power button.
Step 3. Wait for your PS3 to start up.
Hope this helps and thanks for using FixYa
Dec 13, 2009 | Sony Playstation 3 (PS3) Console
699 people viewed this tip
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
