Tip & How-To about Computers & Internet
How to check the wireless settings on your Linksys router
Do you need to know the wireless settings configured in your Linksys wireless router? This tip will you do this, I will show you how this can be done.
First, why do we need to know the wireless setting of your router?
Here are a few reasons why we need to know all of these:
  • We need to know the wireless settings if we wan to add a computer to the wireless network that you already have.
  • If we want to add a wireless devices like, wireless gaming adapters for your gaming system like Xbox.
  • You will also need to know the wireless settings of your network if you want your mobiles phones and other gadgets (iPhone, iPod touch, iPad,etc.) to get online through your wireless network.
What are the things we need to verify off of your router setup page? Here they are:
  • SSID - Wireless Network Name
  • Channel
  • Type of Security
  • Security code or password if there is one enabled.
Here are the steps on how this can be done:
  1. In your computer that is connected to the router, open your browser and type or copy and paste this link to the address bar http://192.168.1.1then hit return.
  2. A login box will pop-up asking for a user name and password. Just leave the user name field blank and type admin in the password field.
    Note:
    admin is the default password, if you can't login using the default password, you might have likely changed it during the initial configuration of your router.
  3. Once you are in the router Setup page, click on the tab at the top that says Wireless. In this page, you can get the following information.
    • Wireless Network Mode - This setting will allow you to choose if you want different types of wireless connection can be accepted by the router, you can choose B, G or Mixed. I recommend you leave it to Mixed.
    • Wireless Network Name / SSID - This is the field where you can put in the name you want for your network.The name you will set here will the name that your router will be broadcasting. By default your router uses the name "linksys". Imagine if the rest of your neighbors has the same brand of router.
    • Wireless Channel - This is the channel or frequency your router is operating on. This can be changed if you are having intermittent issues with your wireless network.
    • Wireless SSID Broadcast - This is one setting that is worth checking. If this is disabled, your router is still operating but the name of your network will be hidden. It's recommended to leave it enabled.
  4. Then click on the sub-tab under the Wireless tab that says Wireless Security. In this page, you will be able to verify the following information about your wireless network security.
    • Security Mode - By default this is set to Disabled. And these are the common security type used or enabled in a small office, home office netowrk.
    • WEP (Wired Equivalent Privacy) - If this is the type of security that is enabled in your router, you need to look for the "Default Transmit Key" or "Default Tx Key" this will tell you what key you need to use from the list of keys available. See image below for reference.
    • WPA Personal (WI-FI Protected Access) - if this the security that you will see, you need to take note of the "WPA Shared Key" this is the password for your wireless netowrk. You can change this any time, and it should be a minimum of 8 characters. Note: If you change your password for the wireless, you wireless computer and other wireless devices that were able to connect fine prior to changing the password, may need to be reconfigured or reconnect and use the new password.
    I hope that this will help you readers out there. Thank you for dropping by.
Computers & Internet Logo
my router is not showing interface menu and logos
Try resetting the Linksys.
To reset the Linksys back to the default settings - Press and hold the pinhole RESET button at the back of the router with the power ON for 20 secs. then release the RESET button.
To connect to your wireless router, the router's wireless settings needs to be configured with the SSID, encryption etc. and also the wireless cards in all the laptops/computers needs to be configured with these router's wireless settings. Then the laptops/desktop computers can communicate with your wireless router.
Connect a LAN cable from the Linksys to the LAN port on your computer.
Open a browser and enter the Linksys configuration URL
http://192.168.1.1
The default login = admin
The default PW = admin
You can protect your router by changing the default admin PW (write it down and put it in a safe place)
Go to the wireless configuration and set up the SSID and WPA or WPA2 encryption to protect your wireless network and Internet from unauthorized access.
Now apply these settings to the wireless card in your laptop/computer.
To secure your wireless network from unauthorized access, please click on this link and follow my instructions :- http://www.fixya.com/support/r3559128-wireless_router_security
Jan 28, 2013 | Linksys Wireless-G WRT54G Router
Don't know how to lock my linksys router
http://192.168.1.1
Dec 04, 2012 | Linksys Computers & Internet
linksys router unidentified network....receiving full signals but showing unidentified network ...i hv checked SSID and key both are correctly entered....
Try resetting the router and then configure it again.
http://192.168.1.1
Go to the wireless configuration and set up the SSID and WPA or WPA2 encryption.
Oct 15, 2012 | Linksys WRT160N Wireless Router
connecting new linksys n to our brother mfc685cw wireless printer. Printer will not read new linksys n router
For isolation purposes, you may want to test the printer through the Linksys router via Ethernet cable and see if you can print if it is wired to the router. From there, configure the wireless printer to match the settings on your Linksys router. Once done, try printing again wirelessly.
Tips:
1. Make sure that they are on the same LAN segment. By default the IP address of the Linksys router is 192.168.1.1. so you may want to configure your printer using 192.168.1.2 for them to communicate.
2. Make sure that the wireless settings on the Linksys router match the wireless settings on your wireless printer. Check the SSID/Wireless Network Name and Wireless Security. All wireless settings should be the same for them to communicate wirelessly.
Jul 12, 2009 | Linksys WRT160N Wireless Router
4,226 people viewed this tip
David Payne
David Payne
