Tip & How-To about Air Tools & Compressors
Tips on chosing air conditioners and why thy are not cooling
Some one was asking why their airconditioner is not getting cold. here are soome tips.
1. low on coolant
2. tubular temperature unit is not functioning.
3. temperature of room is beyond the capacity of the unit. overworking
the unit beyond its capacity
4. a unit should be working to cool the room. It is not good for the size of the unit in btu's to be to large or too small. It is better to over work than under work an air conditioner.
Air Tools & Compressors Logo
Why isn't it heating?
Because its an air conditioner, not a heater?
May 03, 2015 | Heating & Cooling
Unit motor runs OK, but I have standing water. Water is not draining from sink.
The trap has a clog.
Put bucket under trap.
Get out some old towels.
Remove 2 nuts on trap, and it falls loose.
Clean the tubular pipes and then re-assemble.
Read tips about tubular pipes under the sink:
http://www.fixya.com/support/r7929008-replace_garbage_disposal
Mar 02, 2011 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
05 dodge cummins,driving down roadway ,throttle will climb erratically for about 3-4 seconds when coming to a stop, it has electrical throttle connections ,no cables that i can see. When parked idling and hit throttle it over revs for 3-4 seconds also.
To retrieve OBDII Error codes from your Chrysler/Jeep/Dodge vehicle, do the following sequence with the key: ON-ACC-ON-ACC-ON and look at the odometer, that is where codes will be displayed. Here are the codes that you may/can get.
Ho2S = heated oxyen sensor, TP = throttle position, MAF = mass airflow, MAP = manifold absolute pressure, TC=turbocharger.
P0030 HO2S Heater Control Circuit Bank 1 Sensor 1
P0031 HO2S Heater Circuit Low Voltage Bank 1 Sensor 1
P0032 HO2S Heater Circuit High Voltage Bank 1 Sensor 1
P0036 HO2S Heater Control Circuit Bank 1 Sensor 2
P0037 HO2S Heater Circuit Low Voltage Bank 1 Sensor 2
P0038 HO2S Heater Circuit High Voltage Bank 1 Sensor 2
P0050 HO2S Heater Circuit Bank 2 Sensor 1
P0051 HO2S Heater Circuit Low Voltage Bank 2 Sensor 1
P0052 HO2S Heater Circuit High Voltage Bank 2 Sensor 1
P0056 HO2S Heater Circuit Bank 2 Sensor 2
P0057 HO2S Heater Circuit Low Voltage Bank 2 Sensor 2
P0058 HO2S Heater Circuit High Voltage Bank 2 Sensor 2
P0100 MAF Sensor Ckt. Insufficient Activity
P0101 Mass Air Flow (MAF) Sensor Performance
P0102 Mass Air Flow (MAF) Sensor Circuit Low Frequency
P0103 Mass Air Flow (MAF) Sensor Circuit High Frequency
P0104 Mass Air Flow Circuit Intermittent
P0105 MAP Sensor Circuit Insufficient Activity
P0106 Manifold Absolute Pressure (MAP) System Performance
P0107 Manifold Absolute Pressure (MAP) Sensor Circuit Low Voltage
P0108 Manifold Absolute Pressure (MAP) Sensor Circuit High Voltage
P0109 Manifold Absolute Pressure Circuit Intermittent
P0110 Intake Air Temperature (IAT) Sensor Circuit
P0111 Intake Air Temperature (IAT) Sensor Performance
P0112 Intake Air Temperature (IAT) Sensor Circuit Low Voltage
P0113 Intake Air Temperature (IAT) Sensor Circuit High Voltage
P0114 Intake Air Temperature Circuit Intermittent
P0115 Engine Coolant Temperature (ECT) Sensor Circuit
P0116 Engine Coolant Temperature (ECT) Sensor Performance
P0117 Engine Coolant Temperature (ECT) Sensor Circuit Low Voltage
P0118 Engine Coolant Temperature (ECT) Sensor Circuit High Voltage
P0119 Engine Coolant Temperature Circuit Intermittent
P0120 Throttle Position System Performance
P0121 Throttle Position Sensor Circuit Insufficient Activity
P0122 Throttle Position (TP) Sensor Circuit Low Voltage
P0123 Throttle Position (TP) Sensor Circuit High Voltage
P0124 Throttle Position Sensor 1 Circuit Intermittent
P0125 Engine Coolant Temperature (ECT) Insufficient for Closed Loop Fuel Control
P0126 Insufficient Engine Coolant Temperature for Stable Operation
P0128 Coolant Thermostat
P0130 HO2S Circuit Closed Loop (CL) Performance Bank 1 Sensor 1
P0131 HO2S Circuit Low Voltage Bank 1 Sensor 1
P0132 HO2S Circuit High Voltage Bank 1 Sensor 1
P0133 HO2S Slow Response Bank 1 Sensor 1
P0134 HO2S Circuit Insufficient Activity Bank 1 Sensor 1
P0135 HO2S Heater Performance Bank 1 Sensor 1
P0136 HO2S Circuit Bank 1 Sensor 2
P0137 HO2S Circuit Low Voltage Bank 1 Sensor 2
P0138 HO2S Circuit High Voltage Bank 1 Sensor 2
P0139 HO2S Slow Response Bank 1 Sensor 2
P0140 HO2S Circuit Insufficient Activity Bank 1 Sensor 2
P0141 HO2S Heater Performance Bank 1 Sensor 2
P0142 HO2S Circuit Bank 1 Sensor 3
P0143 HO2S Circuit Low Voltage Bank 1 Sensor 3
P0144 HO2S Circuit High Voltage Bank 1 Sensor 3
P0145 HO2S Circuit Bank 1 Sensor 2 Slow Response
P0146 HO2S Circuit Insufficient Activity Bank 1 Sensor 3
P0147 HO2S Heater Performance Bank 1 Sensor 3
P0150 HO2S Circuit Closed Loop (CL) Performance Bank 2 Sensor 1
P0150 HO2S Circuit Bank 2 Sensor 1
P0151 HO2S Circuit Low Voltage Bank 2 Sensor 1
P0152 HO2S Circuit High Voltage Bank 2 Sensor 1
P0153 HO2S Slow Response Bank 2 Sensor 1
P0154 HO2S Circuit Insufficient Activity Bank 2 Sensor 1
P0155 HO2S Heater Performance Bank 2 Sensor 1
P0156 HO2S Circuit Bank 2 Sensor 2
P0157 HO2S Circuit Low Voltage Bank 2 Sensor 2
P0158 HO2S Circuit High Voltage Bank 2 Sensor 2
P0159 HO2S Slow Response Bank 2 Sensor 2
P0160 HO2S Circuit Insufficient Activity Bank 2 Sensor 2
P0161 HO2S Heater Performance Bank 2 Sensor 2
P0162 HO2S Circuit Bank 2 Sensor 3
P0163 HO2S Circuit Bank 2 Sensor 3 Low Voltage
P0164 HO2S Circuit Bank 2 Sensor 3 High Voltage
P
Dec 18, 2010 | 2005 Dodge Ram 2500 Truck
my 93 mercury topaz idles high doing warm days, and idles low doing cold days,what could that be.
1) weak anti freeze 2) defective thermostate 3) out of range coolant temperature sending unit
Any of these or combination of these will give you the sympthoms you are experiencing
Mar 25, 2010 | 1993 Mercury Topaz
Heating System
The Engine Coolant Temperature (ECT) sensor is mounted in the intake manifold and sends engine temperature information to the ECM. The ECM supplies 5 volts to the coolant temperature sensor circuit. The sensor is a thermistor which changes internal resistance as temperature changes. When the sensor is cold (internal resistance high), the ECM monitors a high signal voltage which it interprets as a cold engine. As the sensor warms (internal resistance low), the ECM monitors a low signal voltage which it interprets as warm engine.
0900c1528008f125.jpgFig. 1: View of the Engine Coolant Temperature (ECT) sensor 0900c1528008f126.jpgFig. 2: Engine Coolant Temperature (ECT) sensor locationTESTING
See Figures 3 and 4
  1. Remove the ECT sensor from the vehicle.
  2. Immerse the tip of the sensor in container of water.
  3. Connect a digital ohmmeter to the two terminals of the sensor.
  4. Using a calibrated thermometer, compare the resistance of the sensor to the temperature of the water. Refer to the engine coolant sensor temperature vs. resistance illustration.
  5. Repeat the test at two other temperature points, heating or cooling the water as necessary.
  6. If the sensor does not meet specification, it must be replaced.
0900c1528008f120.jpgFig. 3: Intake Air Temperature (IAT) and Engine Coolant Temperature (ECT) sensor wiring diagram 0900c1528008f095.jpgFig. 4: ECT sensor temperature vs. resistance values
Oct 01, 2008 | 1993 GMC Sierra
726 people viewed this tip
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
