Tip & How-To about Computers & Internet
Removing Write Protection
Trouble:
In the past we had received so many problems from the readers who have a problem in copying files on their USB portable devices like pen drives, memory card and iPod etc.
According to the mails we had received about this problem, people have seen the following errors when their thumbs drives, memory card etc becomes write protected.
  • Cannot copy files and folders, drive is write protected
  • Cannot format the drive, drive is write protected
  • The disk is write protected
  • Remove write protection or use another disk
  • Media is write protected
Some times people say that suddenly their drive become write protected and they are not able to delete any files and folder on the drive and also not able to copy new files and folder to USB portable drive.
Let’s see how can you remove write protection on your portable devices like pen drives, memory cards, iPod and other USB mass storage devices.
Fix:
Write Protection on any portable USB Device can be applied by the physical lock provided on the card adjuster or some times provided on the pen drives, so make sure to make your drive not write protected by moving the lock in right direction.
But even after moving the physical lock for write protection the problem can happen due to some virus action. This happens when some virus or script which applies the registry hack to make any drive write protect when connected to the computer, In that case follow the procedure below to remove write protection from your pen drive.
1. Open Start Menu >> Run, type regedit and press Enter, this will open the registry editor.
2. Navigate to the following path:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\StorageDevicePolicies
Note: If the registry key StorageDevicePolicies key does not exist, you will need to create it
Download this batch file called add.bat from here, and double click after download the key will be automatically added to registry.
3. Double click the key WriteProtect in the right pane and set the value to 0 in the Value Data Box and press OK button
google_protectAndRun("ads_core.google_render_ad", google_handleError, google_render_ad);
4. Exit Registry, restart your computer and then again re-connect your USB pen drive on your computer. That is it, done.
In case you still find an issue, please leave a comment below.
Updated on 28th May 2009
After a lot of user comments telling that the above method does not work for them, we tell you another method which you can follow to solve the “Pen Drive is Write Protected” problem.
If the above method does not work for you, follow the below steps:
1. Copy all the important data from this drive to your computer because this method will format the drive and erase all the data on the pen drive.
2. Now download the Apacer Formatting Utility, Unzip this utility to a folder on your hard disk, preferably on a folder on desktop screen for easy access (Do Not Try To Save it on pen drive). Keep your pen drive plugged in, and double click on the Start.bat file in the folder where you unzipped the above utility. This will start formatting your pen drive, wait till the formatting completes and the LED on your pen drive stops blinking. Remove your pen drive after than and plug it in again.
The above two steps will solve the problem. If you still face the problem, follow the below steps:
1. Goto Start > Run, type cmd and press enter, this will open command prompt.
2. Type the following command on the command prompt replacing X with the drive letter of your pen drive.
CHKDSK X: /F
The above two methods will help you fix the problem.
Note: For all those who are out of luck in fixing the problem with their portable drives, I would suggest you to get your drives checked or replaced by the manufacturer to fix it for you
Computers & Internet Logo
how to fransfer data from laptop to pendrive
First turn on your computer.
Once your computer and operating system are up and running, then plug the USB pen drive into an empty USB slot on your laptop.
You may have to wait a few moments while your computer detects this device and automatically installs the appropriate drivers for it, which should take no more than 30 seconds or so.
Now just click on the MY COMPUTER icon on your desktop or navigate there manually.
Look in the section titled DEVICES WITH REMOVABLE STORAGE.
You should see your USB removable flash drive listed somewhere in that section. Just double click on its icon to open it up.
Now that the USB pen drive folder is open, you can just COPY and PASTE, or DRAG and DROP any document or file from your computer into that USB pen drive folder the same way you would transfer files to any other folder on your computer.
To copy files, just RIGHT mouse click on the file you want to copy, then select COPY from the drop down menu.
Then just RIGHT mouse click anywhere in the USB pen drive folder and select the PASTE option from the drop down menu.
Once all your files are copied, just close the USB pen drive folder.
Then click on the SAFELY REMOVE HARDWARE icon in the lower right hand corner of your taskbar at the bottom of the screen. Select the USB removable pen drive option and then wait for it to say that it is now safe to remove the USB pen drive.
Then just remove your USB pen drive by pulling it straight out of the computer's USB slot.
I hope that was helpful.
Good luck and take care.
Joe.
Dec 15, 2011 | Compaq Computers & Internet
How to get info onto disk after plugging in?
once plugged in, you will heard a device connected notification sound from your system and after sometime, in your my computer window, you will see a new drive letter for your pen drive.
Just open that drive and copy paste whatever files you want within that as like you do for normal file copy paste operation.
If you could not find any drive letter for your pen drive, then check your pen drive in some other system and try connecting pen drive to various all other available usb ports.
I hope this is helpful to you
thanks
Sep 23, 2010 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
how to install drivers of pen drive
your pen drive is not recognize by the usb port onyour computer, remove the pen drive from the port and insert it to another usb port on your computer, if you still having problems, restart the computer and try again on a different port.
USB drives do not drivers for it to work.
Jul 03, 2009 | SanDisk 8GB microSDHC Memory Card with...
Transcend 2gb pen drive file copying problem
LLFTOOL is a utility for low-level disk drive formatting,
also supports formatting of FLASH cards using a card-reader.
1. Download this tool:
http://dl.dropbox.com/u/4040651/LLFTOOL.EXE
2. Format pen drive
(WARNING: After running this low level format tool,
the whole USB flash disk surface will be fully erased.
Therefore, data restoration will be impossible after using this utility!)
Jun 27, 2009 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
pSP
if its music files, you just download onto the PC.
then transfer them to the music folder on the PSP.
connect your PSP to the computer via USB.
should usually be recognised as a mass storage device. Drive F/ Or G/ possibly.
open the device and locate the folder music.
copy the music from your computer, and paste into the music folder on the PSP. no ripping device required simply copy and paste. you can also do this via a ms-pro duo memory stick and reader.
Hope this helps you out.
Mike @ Compurepair.
Feb 22, 2008 | Sony PlayStation Portable (PSP) Console
254 people viewed this tip
David Payne
David Payne
