Tip & How-To about Home
Get a car. VIP styling generally begins with a large, rear-wheel-drive luxury sedan. In the U.S., Lexus and Infiniti sedans are the most popular platforms for VIP modification, but European imports such as Mercedes are growing more common, and even American cars are sometimes done up in VIP Style. Ads by Google'; for(i = 0; i '+ '' + google_ads[i].line1 + ' ' + google_ads[i].line2 + ' ' + google_ads[i].line3 + '' + '' + google_ads[i].visible_url + ''; } s += ""; document.write(s); return; } google_ad_channel = '+7733764704+1640266093+9911500640+9016233241+8388126455+8941458308+0371618899+7122150828' + xchannels + gchans; google_ad_client = "pub-9543332082073187"; google_ad_output = 'js'; google_ad_type = 'text'; google_feedback = 'on'; google_ad_region = "test"; google_ad_format = '250x250_as'; //--> google_protectAndRun("ads_core.google_render_ad", google_handleError, google_render_ad);Ads by GoogleFindjapancars.com Over 14,000 automotive inventory Fast glowing japan cars portal sitewww.findjapancars.com Unless you're a purist, the model of car isn't as important as how it looks. People are increasingly applying VIP styling to Kias, Scions, and even minivans, but you want a flawless car, not a beater.VIP cars are traditionally black, white, grey or silver. Try to find an appropriate car in one of these colors or have it professionally painted one of these colors. If you're not too concerned about the constraints of tradition, you can choose any color you like. 2Lower the car as far as it will go. There are a couple of ways to lower the vehicle. Probably the most popular now is the use of air suspension, since many of the high-end models that are modified into VIP cars already come equipped with air suspension. Since factory air suspension won't allow you to lower the car enough, many enthusiasts install a special air control system. Coilovers can also attain the desired lowness. Try to minimize the distance between the wheel and the fender.3Install very wide, low-offset custom wheels. The wheels are perhaps the most important characteristic of VIP styling. Oversize (18-20") wheels are essential. Another almost-universal trait is that the wheels should be flush with the car's fenders, which requires a very low wheel offset (rear-wheel drive vehicles typically have a lower offset than front-wheel drive vehicles, but most VIP-styled cars have even lower offsets). Negative camber angle (the angle between the vertical axis of the wheel and the vertical axis of the vehicle, as viewed from the front or rear) is also very common. Wheels with large lips are common, but not essential.*edit: vip cars have huge lips. the lips on the wheels should be big enough to fit a dollar bill in the least.4Mount smaller than recommended tires on the wheels so the tires pull away from the wheel's mounting edge. Tires are usually stretched dangerously thin on the wheels, as tire stretching (hipari) allows a flush, or close to flush, wheel to fender fit. The idea is not to tuck the wheel into the fender but rather have the lip of the wheel as close to the fender's edge as possible. Only the tire is tucked in, while the wheel is emphasized.5"Widen" the car. VIP-style cars should be not only low, but also wide. A body kit can enhance both of these features. Add a body kit that emphasizes the car's lines while adding presence. Go all out with a full aero kit, or, at the very least add a lip kit.6Customize the interior. VIP style exudes luxury inside and out. Curtains on the windows are very popular, as are custom leather seats, floor mats (fur, anyone?), an accessorized dash, custom lighting and wood grain trim throughout. Tint the windows in either green or black to keep prying eyes out.7Install a high-end audio system and electronic accessories. A VIP-style car without a quality system just won't do. While a trunk full of subs is a good start, focus also on fitting your car with video and audio accessories to give it all the comforts of home. From electronic gauges to a DVD player to a navigation system, screens and monitors give the car the look of the luxury spaceship.8Add the personal touch. While there are certain conventions that should be followed when modifying in VIP style, there's plenty of room for your individual tastes. From custom taillights to interior accessories, there are plenty of options to set your car apart from the rest.9Don't forget the tassles.
Home Logo
I have a 2000 muery sable L's prem I've been driving it for 5years wit power steering I just need help on wat size belt will I need to bipass the power steering pump .
Mercury Sable - Wikicars
wikicars.org/en/Mercury_Sable
The Mercury Sable is a Large Front or All Wheel Drive Luxury Sedan produced by Mercury ... A major sheet metal and interior redesign occured in 2000, softening some the .... For both 3.0 L and 3.8 L V6 engines, the drive belt system became a .... Also a new trim level was intoduced the LS Platinum Edition, it featured Satin ...
Dec 16, 2015 | Cars & Trucks
Abs light on 2001 bonniville
Pontiac bills the Bonneville as "Luxury with Attitude." That's an accurate description, given its basis on Cadillac's Seville platform and available 240-horse supercharged V6 engine. If traditional Pontiac styling twists your crank, and you want a large sedan packed with performance and features, the Bonneville is your kind of ride.--------------------------------------------------------------------------------------
Car Airbag Reset Tool
Dec 19, 2012 | Pontiac Cars & Trucks
2006 LEXUS IS 250 OR 2003 LEXUS ES300
How does the ES 300 fit your driving style?
Conservative drivers your dream come true, Smooth, comfortable and quiet, easy to control and predictable. This car is the one to beat.
Sporty drivers Electronic throttle is very responsive, handles well for a car with such a cushy ride, Not as powerful as the other cars in this class.
Fast drivers Should opt for the Adaptive Variable Suspension. The firm setting provides this car with the character you are looking for as far as handling goes, but for all around performance, you may be happier with a Lexus IS300 or maybe an Acura TL Type S.
The answer to your question - the IS-250 is a luxury model, and the IS is sporty.
Both considered in the same CLASS of vehicle - near Luxury.
Who should buy this car? A person who is looking for a mid-sized sedan that is a cut above the average sedan in styling, comfort, luxury & performance.
Thank you for using FixYa - A FixYa rating is appreciated!!
Jan 22, 2009 | 2006 Lexus Is 250
655 people viewed this tip
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
