Tip & How-To about Heating & Cooling
How to Build a Sawbuck for Cutting Firewood
Select the size. Design the permanent sawbuck to be 6 vertical 2x4's (38 mm x 89 mm) or 2x6s (38 mm x 140mm) of about 4 feet (1.22 meters) long and 4 horizontal 2x6's 5 feet (1.52 meters) long using 3.5 inch (8.89 cm) wood screws or nails. (See "Tips" for information on making a demo/prototype version instead.)
* Cut the "V" form portion at an angle as shown
* Place the middle of the "X" a little taller for use with a chainsaw rather than for a bow saw, if you prefer.
Design the sawbuck/sawhorse as shown in the illustrations. Tailor the design as you desire or require.
Use suitable boards for your project. Nominal 2X6s or 2X4s of pine (southern yellow or lodgepole or white), or spruce will be fine.
  • Decide the taller height that you think you may want, namely, cut the "X" pieces about 48 inches (1.22 meters) long.
  • Adjust the height according to what feels right to you.
Consider starting with one (the first) "X" temporarily attached together with two nails/screws to see how tall and wide that you want to make it. Take it apart and angle-cut and trim the angle of the "V" as shown in the photo above. This angled cutting of the "V" will make it less top-heaUse this as your pattern for the rest. Feature: the "V" part allows you to nestle and cut two or more narrow poles or tree limbs (around 3 to 8 feet (91.44 cm x 44 meters) in length) with a chainsaw, to make your firewood quickly.vy.
Design the sawbuck lower if you are using a smaller "X" sawbuck with a hand "bow-saw". Make the sawbuck about only 20-24" (50.8 cm x 60.9 cm) high to the center. This will allow the user to put a foot on top of the poles or the split wood being cut, when it is that low (as illustrated).
Design a wide, heavily braced base to give you more stability for the power of a chainsaw.
Caution: A lightweight sawbuck might lead to an injury if it falls over while cutting. Don't use a smaller sawbuck for chainsaw work.
Make the sawbuck fold if wished. One way to connect the sawbuck together is to use one big bolt of about a 4 inch (10.16 cm) long, and 1/2 inch (12.7 mm) in diameter. Put it in the exact same placement at the center of each "X", using extra-large washers, so that it can be clamped together and loosened to fold for storage. Consider screwing on a leg spacer-brace on each "X". Then unscrew the end spacer-brace to allow the "X" to fold. To build a non-folding sawbuck, simply connect the "X" forms together, and use 4 to 6 nails/screws driven permanently into about the center of each "X".
Heating & Cooling Logo
fan making noise.
Most all fans can be replaced with ease. There are 4 mounting screws included with a new purchase. I suggest Amazon.com or Newegg.com. Most fan sizes are available and all sizes are in mm. The most common sizes are 120mm and 140mm.
Jan 21, 2014 | Gateway SX2800-01 PC Desktop
where can i buy a compaq presario power supply
Almost any standard ATX psu will fit this model, 86mm x 150 mm x 140 mm I would think. (PSUs come in standard sizes, most are ATX with depths into the case of 140mm upwards. Your old PSU s 140mm deep, so I should get one that also that deep. Higher powered ones can be can be as deep as 180 mm which wouldn't fit in your computer). It would be better if you bought a good brand one such as Antec, Corsair Silverstone, Seasonic, even an a Zalman or Akasa to name but a few, of at least equivalent power (it does not matter if it is a higher rated power, your computer will only take what it needs). Be certain that the PSU has enough of the correct type of connectors for your PC - Molex 4 pin power, minimolex for floppy if you use that, and SATApower if you have those, and 4 pin (I think for your pc) "P4" connector for your mainboard/CPU, and a 20+4 (20 pin with detachable 4 pin section for 24 pin m/b) pin motherboard connector. Be certain that it will accept the correct input voltage for your location (many will accept 90-240V ac now). You might try to get a second hand one.
12.April.2014
Jan 15, 2013 | HP Compaq Presario SR1750NX PC Desktop
How should I pick the right TV size?
In general, for best image quality and bestexperience you need 32 inches TV for every three meters. For example if in yourliving room your distance from the screen is 6 meters the recommended foryou is 64 inches. I've attached a table with exact s and ranges for yourconvenience Screen Viewing distance range 26" 3.25 - 5.5 feet 32" 4.0 - 6.66 feet 37" 4.63 - 7.71 feet 40" 5.0 - 8.33 feet 42" 5.25 - 8.75 feet 46" 5.75 - 9.5 feet 50" 6.25 - 10.5 feet 52" 6.5 - 10.8 feet 55" 6.9 - 11.5 feet 58" 7.25 - 12 feet 65" 8.13 - 13.5 feet 70" 8.75 - 14.75 feet
Jul 29, 2012 | Furniture
3.05x3.92 (metric) what is this in feet and inches
3.05 meters = 10.007 ft, or 120.08 in
3.92 meters = 12.86 ft, or 154.33 in
3.05 meters x 3.92 meters = 10.007 ft x 12.86 ft = 128.69 ft^2 (feet squared)
= 120.08 in x 154.33 in = 18531.946 in^2 (inches squared)
if you meant millimeters then
3.05 mm = .01 ft, or .12 in
3.92 mm = .01286 ft, or .15433 in
3.05 meters x 3.92 meters = .01 ft x .01286 ft = .0001286 ft^2 (feet squared)
= .12 in x .15433 in = .018531946 in^2 (inches squared)
1 meter = 3.2808399 feet
1 meter = 39.3700787 in
1 millimeter = 0.0032808399 feet
1 millimeter = 0.0393700787 inches
Jun 19, 2011 | Office Equipment & Supplies
how do you adjust a headlight from pointing up to the right height
VERTICAL AIM ADJUSTMENT
1. Park the vehicle on a level surface approximately 7.6 meters (25 feet)
from a vertical wall or screen directly in front of it.
2. Measure the height from the
center of your headlamp to the
ground and mark a 2.4 meter (8
foot) horizontal reference line on
the vertical wall or screen at this
height (a piece of masking tape
works well). The center of the lamp
is marked by a 3.0 mm circle on the
headlamp lens.
3. Turn on the low beam headlamps to illuminate the wall or screen and
open the hood.
4. On the wall or screen you will
observe a light pattern with a
distinct horizontal edge of high
intensity light with a slight angle
towards the right. If this edge is not
at the horizontal reference line, the
beam will need to be adjusted.
5. Locate the vertical adjuster on
each headlamp, then use a 4 mm
socket/wrench to turn the adjuster
either counterclockwise (to adjust
down) or clockwise (to adjust up)
aligning the upper edge of the light
pattern up to the horizontal line
6. HORIZONTAL AIM IS NOT
REQUIRED FOR THIS VEHICLE
AND IS NON-ADJUSTABLE.
Mar 09, 2010 | 2002 Ford Explorer
1,554 people viewed this tip
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
