Tip & How-To about Computers & Internet
Vista at it's best...
* Extra Menu options for files and Folders in Windows Vista:
1. Get an expanded shortcut menu When you work with files and folders in Windows Explorer, get in the habit of holding down Shift as you right-click an item. The screen shots here show the normal shortcut menus for a file and folder on top, with the Shift-enhanced shortcut menus below each one. Using this shortcut, you can add any file to the Start menu or the Quick Launch bar, open a Command Prompt window rooted in the selected folder, or copy the full path for a file or folder to the Clipboard.
* Run Performance Check in Windows Vista
2. Get a quick system checkup Windows Vista has no shortage of diagnostic tools. The System Health Report is one of the most useful. It takes input from the Performance and Reliability Monitor and turns it into a well-organized, information-packed report that does a good job of spotlighting potential problems. To run this report, open Control Panel, click System and Maintenance, and then click Performance Information and Tools. In the Tasks list along the left, click Advanced tools. The last item on the resulting list is Generate a system health report.
Each report gathers information for roughly 60 seconds, so it's easy to run several reports. To establish a baseline, run a report immediately after startup, with no programs running except those that start up automatically. You can run additional reports while you run particularly stressful programs to see whether the load is overtaxing your system.
* Make the blinking cursor easier to see
3. Make the blinking cursor easier to see The blinking cursor that indicates where you can type text is as thin as Kate Moss, which sometimes make for frustrating moments when you can't locate the blinking thing. So make it easier to see: Open Control Panel, type optimize visual display in the Search box, and click the shortcut to see the dialog box shown here. Bumping the size of the cursor from 1 to 2 makes a noticeable difference; going all the way to 11 would really make it impossible to miss.
* Make Security Center go away The Security Center icon
4. Make Security Center go away The Security Center icon in the notification area is a nag. There's just no other word for it. And if you're confident that your security settings are in order, you really don't need the nagging. To make Security Center disappear into the background, open its icon in Control Panel and click Change the way Security Center alerts me in the Tasks pane on the left. In the resulting dialog box, choose Don't notify me and don't display the icon (not recommended).
* Use the Mobility Center on a notebook
5. Use the Mobility Center on a notebook It's about time notebook users got an easy-to-access control panel for common configuration options. Vista's Mobility Center gives you the ability to quickly enable or disable an external monitor, enable or disable a wireless adapter, check your battery level, and much more. To configure your notebook so Mobility Center is always available, add its shortcut to the Startup group. To open or switch to Mobility Center, use its keyboard shortcut: Windows logo key+X.
Computers & Internet Logo
How do I find my Prefetch folder on Vista emachines computor
Prefetch folders on Vista are hidden and locked folders, it isn't easy to get into them but not imposable.
to unhide the prefetch folder......
Instructions
    • 1
    • Click on the "Start" menu.
    • 2
    • Scroll over to "Computer" and click.
    • 3
    • Click on the "Tools" menu and scroll down to "Folder Options."
    • 4
    • Click on the "View" tab. This will open a list of options that you can click to enable or unclick to disable.
    • 5
    • Scroll down to "Show hidden files and folders" to enable that option. You can also unclick "Hide extensions for known file types" and unclick "Hide protected operating system files" if you wish to unhide your files. Your hidden folders will now come up on a regular Windows search.
Now Microsoft hides the prefetch folders for a reason, the files in them may cause Vista to stop working if you are not sure of what your doing. In other words if you change or delete a needed file your going to be in trouble and vista may stop working all together, and if you change something you can cause Vista to do things that can harm or allow viruses into your machine.
So if your very very sure of what you are going to do and your really sure it is safe to do then this will help you find what you want, However I cannot stress the danger of messing up Vista by playing around with the files in the prefetch folders.
Good Luck!
Mar 14, 2013 | E-Machines eMachines Desktop PC
can not open itunes
Some times a newly installed version of iTunes for Windows will not open. Even though it may still shows as running in the Windows Task Manager(Ctrl+Alt+Delete-click Task Manager).
Resolution:
1. From the Start menu, click Computer.
2. In the Organize menu, click Folder and Search Options.
3. Click the View tab.
4. In the "Advanced settings" pane under "Hidden files and folders" make sure that the "Show hidden files and folders" option is selected. And Click OK.
5. Navigate to the following location by either typing it into the address bar, copying and pasting it into the address bar, or clicking through the folder hierarchy listed: C:\Program Data\Apple Computer\iTunes\SC Info
6. Right-click the SC Info.sidb file shown and on the shortcut menu, click Delete
7. Right-click the SC Info.sidd file shown and on the shortcut menu, click Delete.
8. Restart the computer and open iTunes.
*HOPE IT IS FIXED*
Oct 22, 2010 | Microsoft Windows Vista Ultimate Edition
Error 8E5E05F6: You can't sign in to Windows Live Messenger
Hi, If you are receiving Error 8e5e05f6 when you sign into Windows Live Messenger 2009, please try the following:
1. Enable Hidden Files and Folders:
1. A. Windows XP :
1. a.i. Click on “Start”, click “My Computer”
1. a.ii. On the “Tools” menu, click on “folder options”.
1.a.iii. On the “view” tab, locate “Advanced settings” and then follow these steps:
Check the option “Show Hidden files and folders”
Clear the option, “Hide protected operating system files check box”.
Clear the option, “Hide file extensions for know file types check box”.
1. a.iv. Click ok and close the window.
1.B. Windows Vista :
1.b.i. Click on “Start”, click “My Computer”
1.b.ii. In the Explorer window, click “Organize”
1.b.iii. Choose “Folder and Search Options”.
1.b.iv. In the folder options window, click on “View” tab
1.b.v. Select the option “Show hidden files and folders” click “ok”.
2. Delete Windows Live Contacts folder :
2. a. Click on “Start”; double click on “My computer”
2. b. Browse to the location
Windows XP:
C:\Documents and Settings\<Your Windows logon name>\Local settings\Application Data\Microsoft
Windows Vista:
C:\Users\<Your Windows logon name>\App Data\Local\Microsoft
2. c. Delete “Windows live contacts folder” completely.
Note: Ensure to exit Windows live Messenger from the task manager before deleting Windows live contacts cache folder, otherwise you will get an error prompting that you can’t delete the folder .
2. d. Try signing into Windows Live Messenger.
Sep 19, 2009 | Microsoft Windows Live Messanger
how do I fix Error 8E5E05F6
Try the following:
1. A. Windows XP :
Windows XP:
Windows Vista:
Sep 19, 2009 | Microsoft Windows Vista Home Premium with...
219 people viewed this tip
David Payne
David Payne
