Tip & How-To about Audio Players & Recorders
Many Mitsubishi projection TVs have bad control panel switches. These switches fail and lock up the TV's computer, disabling everything. If you can unhook the control panel, the TV will work fine with the remote. Remove the speaker grill. Pull on the sides, it should come loose with a little effort. Remove the access panel by removing the 4-6 screws using a philips screwdriver. Follow wires from control panel inside to the connector labeled "DZ". These will be the thinner wires, not the thick ones that go to the video jack. Unhook this connector and the TV should work with the remote. You can replace the switches, but the Mitsubishi buttons sometimes will just fail again. Using another brand of switch may be more reliable. Better to just use the remote and let the buttons be useless. Nobody uses these usually anyways. Some models will require you to unplug the TV for a minute, and then plug it back in and wait about 2 minutes before the TV will work again (reboot the microprocessor inside). The biggest issue with repairing your TV by unplugging the control panel like this, is that you no longer have the green LED on the front panel. Many Mitsubishi TVs will flash the green LED for about 90 seconds and then the TV is ready to turn on. Without this panel connected, you just have to remember that you need to wait 90 seconds after plugging in AC power before the TV will be functional. If this fix does not help resolve your "dead" set issue, you likely have a bad power supply or bad signal board. The way to know is to check the +5 volt standby line inside. You can check this on the same connector to the front control panel for an easy check, without opening up the back. Just check all the pins and one of them should have the +5 volt standby sending power to the switches. Use the outside of the video jack as your cold ground. Thanks and good luck!
Mitsubishi WD-52525 projection TV volume control
Check owner / operator manual for "panel lock" selection or
go through menu pages until you spot it........
This selection is made so guests or children cannot operate tv.
In case this suggestion fails, you might try hard reset = unplug
AC cord overnight,then try again...........T.
Nov 13, 2007 | Mitsubishi WD-52525 52" Rear Projection...
WS-55511 55in volume turns up by itself & can't switch devices
The remote is not the problem. The switch for volume up on the control panel has become leaky. Very common problem for this generation Mitsubishi. If you don't mind not having the control panel working you can disconnect it and the set will work just fine with the remote. To disconnect the control panel pull the speaker grill, it just snaps off, and remove the front access panel. Once that is done you'll see a cable going to the switches just disconnect it.
Nov 23, 2008 | Mitsubishi WS-55511 55" Rear Projection...
parental control/lock on Mitsubishi WS-55613
I can help you unlock your Mitsubishi HDTV V-Chip parental lock.
Please follow these steps to bypass the vchip or reset the V Chip password.
I hope that helps.
_______________________________________________
Reset Mitsubishi HDTV VChip Password
Bypass Mitsubishi HDTV Front Panel Lock
Aug 11, 2008 | Mitsubishi WS-55613 55" Rear Projection...
tv mitsubishi ws55311
Remove front lower speaker grill,then remove access panel =
unplug white connector ( goes to front controls )......Does the set
work now with remote ?...= bad tactil switch on front panel......T.
Apr 23, 2008 | Mitsubishi WS-55513 55" Rear Projection...
1,299 people viewed this tip
 Grubhead
Grubhead
