Tip & How-To about Televison & Video
How to fix convergence problems for RCA chassis ITC222.
Your projection TV looks like you are watching 3D video and none of the colored beams are aligned. You go to the menu to set the convergence and find that the convergence adjustment menu is missing. What is causing this?
Basically you need three parts which will be installed in the area of the flyback transformer. An electrolytic capacitor, a fuse and a diode. This circuit supplies dc power for the convergence circuit and without it the convergence circuit will not work. Without convergence correction your unit will look like it is in 3D and you will have red and blue shadows around all text, etc.
You need to get a kit at http://www.tvrepairworld.com/rca_repair_kits . You want the one labeled ITC222 and ITC222A convergence option missing repair kit. It comes with very good instructions and appropriate schematics to make the repair possible by anyone. In addition there are videos available on the parts website to help with the repair.
This kit will fix the problem with the missing convergence menu but may not fix all the problems with the miss-convergence in the unit. If it does not solve all the problems go to my tip at http://www.fixya.com/support/r6396176-projection_tv_troubleshooting which will help with further troubleshooting. You could also have problems with the convergence board, which may have blown out the power supply for the circuit in the first place.
Thanks for using FixYa and for the great rating.
hardrocko
Televison & Video Logo
Hooked up PS3 to system and when watching DVD's the right side of the picture is blurry and appears doubled, like an old 3D movie without the red and blue glasses. When watching TV everything looks fine.
All projection TV sets have two very common problems. One is convergence ( 3D/Warped video or dead set) the other is CRT fluid ( Dull Video). Here are more details and solutions for both.
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. In some cases the TV will also not show any video. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
69189a5.pngSOLUTION
You can get the correct parts, step by step photo instruction guides, and support from www.TvRepairKits.com or click here
Jan 20, 2011 | Mitsubishi WS-65809 65" Rear Projection...
when i turn it on, it gets a blue looking shadow color and the letters and numbers look like you're watching a 3D picture without glasses
projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Here are more details and solutions for both.
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
  • Screen looks 3D
69189a5.pngSOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jan 18, 2011 | Hitachi 60DX10B 60" Rear Projection...
color convergence lines not aligned
All projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Here are more details and solutions for both.
  • Screen looks 3D
69189a5.pngSOLUTION
Jan 02, 2011 | Hitachi 46F500 46" Rear Projection...
color convergence and color looks 3d
•Screen looks 3D
•Colors don't line up
•One or more colors can't be adjusted when using the convergence menu.
•Screen is bowed or warped.
•TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some photos of convergence problems
fcabb43.pngCONVERGENCE SOLUTION
You can see some more examples and find a fix using this link on Fixya - CLICK HERE
Aug 24, 2010 | Sony KP43T75GRAY 43" Rear Projection...
out of focus
•Screen looks 3D
Mar 06, 2009 | Toshiba 56HM66 56" Projection HDTV
1,399 people viewed this tip
Top Televison & Video Experts
Electro Med Services...
