Tip & How-To about Cell Phones
How to sync music to your phone from your computer
Plug your phone into your computer. Your computer's going to say "found new hardware" and if it works out right, it'll find the correct device driver to support your phone and you won't have any problems. Open the program, for example Windows Media Player, where you have all of your music. You need to have all of your songs saved in a folder. On the Sync List, right click it and insert the folder you saved. Under the songs, you'll see "Start Sync". Click it. If it doesn't start to sync, go to your phone and look under "Music & Tones". Look through your options & you'll see one that says "Sync Music". Click it. This should get your music sync'd with your phone.
Cell Phones Logo
HP dvd420i drivers for windows 7.
windows 7 should automatically search for and find the correct drivers
Click start control panel administration tools computer management device manager scroll down cd-dvd rom drives you might see a yellow question /exclamation mark ? ! or a red X right click to update driver
you might have to physically unplug the leads for this cd/dvd restart your computer then plug them back this should activate the found new hardware wizard
if you are still unable to locate drivers for windows7
http://download.cnet.com/slimdrivers-free/3000-18513_4-75279940.html
it might take some time being a freeware driver solution
note: it will find all of your outdated drivers
this is a free driver solutions
they will automatically search for and find the correct driver
hope it helps
Apr 11, 2012 | HP Q2133A dvd420i CD-RW DVD-RW Internal...
wireless adapter not found please plug-in the DWA-120
After uninstalling it completely from the computer. When you plug in the adapter alone. You must get the "Found New Hardware" wizard. And nothing else apart from this. Only then it is correct. If nothing comes up at all, the device is dead or your version of USB might USB 1.0 or USB 1.1 which at times has issues. But if you see that wizard coming up, unplug the adapter and insert CD and run setup and walk through it.
Anyway, i ll recommend that you try this adapter on other NEW computer(laptop or desktop), just to check.
I feel that this adapter would work on a new computer, maybe your computer's hardware specifications are old to support this device.
copy.pngfavicon.icofavicon.ico
Jan 22, 2010 | D-Link WUA-2340 (ASKU55774) Wireless...
my mobilemate that i have used before .
this is happening due to driver fault
first try it on different usb ports otherwise
right click on my computer > proporties>device manager goto usb controller find device with exclamation mark...right click it and click remove to remove it...now use cd you've got or search internet for correct drivers
restart the pc
now connect your device ..in the found new hardware, manually(not automatically) give the location of drivers you've downloaded and go....
May 15, 2009 | SanDisk MobileMate SD+ 5-in-1 USB 2.0 Card...
can't reconise my dvdrw rom drive
check in bios settings your dvd is found or not reset your bios load optimal defaults.
Mar 10, 2009 | Acer Aspire 5610 Notebook
computer wont recognize sansa fuze
STOP EVERYTHING ALL YOU HAVE TO DO IS TURN OFF YOUE SANDISK, THEN plug it in!!.
Feb 01, 2009 | SanDisk Sansa Fuze MP3 Player
108 people viewed this tip
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
