I can tell you that the blower motor is removed from the engine compartment. The battery is disconnected, The windshield washer reservoir is removed. The ECM is removed. The cover on top the blower motor is removed. Lastly the blower motor is removed. This should cover your question but if you need more information please write back and let me know.
You can't do do anything with that page as the link is expired or it may be removed. The main reason behind it was that it may be removed by author. If it contains illigal things it may removed from site owner.
Have you removed the Brake Line? If not: this must be removed in order to remove the cylinder. Use a flare-nut wrench. If you have removed the Brake Lines and Bolts, tap lightly with rubber mallet to loosen.
For AS 3680,
Removed screen.
1. Open the door on the back to remove the wireless antena cables.
2. Open the power cover (remove 2 scews on the power cover).
3. removed keyboard.
4, remove 4 scews (silver scews) that make screen attched the the laptop body.
5. that's all you can remove the lcd now.
For opening the body,
1. Removed all screw on the back, include 1 screw (small scew) under hard drive.
2. removed 3 screws under keyboard
3. removed 1 scew on top side (close to power port), this scews held uppercase and lower case.
4. removed lcd lid cable from board (close to power port)
5. now you can separate upperbody from lowerbody.
6. removed 2 scews from motherboard.
7. removed modem cable, speaker cable, mic cable from the back.
8. that's all, you can removed motherboard+power board.
