Tip & How-To about Cell Phones
Always keep your bluetooth disabled.
Keep your bluetooth disabled, and enable it only when you need it.
This is a safety tip to keep your phone away from bluetooth virus!
Cell Phones Logo
i got n97mini, it keep ask me to pair with a bluetooth gps device
Your Garmin has Bluetooth handsfree activated, it's nothing to do with navigation. All that's happening is that it's sensing that your n97 has Bluetooth turned on and so your Garmin is asking whether you wish to pair the devices.
Paired or not, your Garmin still uses it's own internal GPS navigation and does not utilise the navigation built into your n97.
If you already use your own preferred handsfree device then just go into the Garmin's menu to turn off Bluetooth. If you don't already have handsfree then I strongly suggest that you pair your phone to the Garmin and use the facility to remain safe and legal.
If you wish to disable Bluetooth on the Garmin then on most models, starting from the homepage, you press "tools", "settings", "Bluetooth" and then click on "Bluutooth enabled" and toggle it to "disabled".
I hope that this answers your question, you can let me know by rating my answer. If not then please add a comment instead to more clearly explain what your problem is and I will try again.
Mar 29, 2010 | Nokia N97 mini Smartphone
notebook: acer aspire 4720z bluetooth malfunction when switching it on my bluetooth keep appearing on my screen ''Bluetooth Enabled'' and then ''Bluetooth Disabled'' and i canot stop it even i switch it off same it still appearing in my screen .. please help me about this
Ether you got a stuck key or your bluetooth card is malfuctioning. The bluetooth is inside the computer generally underneath you need to open up the campartment and take it out. Also what you can do is go into the device manager from windows and disable the device there.
Thanks
Feb 18, 2010 | Acer Aspire 4720 Notebook
connecting bluetooth to blackberry
Hi. You didn't say which Blackberry you have. I'll assume you know who to open "Options" (if not, please let me know what model you are using and I'll give you more specific instructions.
To connect your headset, start on your Blackberry.
Open "Options"
Open "Bluetooth"
Open menu within Bluetooth
If not already on, click "Enable Bluetooth"
Open Bluetooth menu again.
Open "Options".
Turn "Discoverable" to "Yes"
Now to your headset.
Start with your headset turned off.
Press and hold down the silver call control button.
After 6-10 seconds, the light will flash blue, then it will flash red, then blue.
Release the buton when you see the red/blue.
Back to your Blackberry.
Again open "Options"
"Bluetooth"
Open the Bluetooth menu.
Click on "Add Device".
Your Blackberry will search for your headset.
If you are prompted for a Passkey, use 0000 (that's 4 zeros).
After a short time, your headset will appear on your Blackberry.
It is now ready to use.
Make sure you go back into Bluetooth Options and change "Discoverable" back to "No".
A tip: If you will not be using your headset for a while, "Disable" Bluetooth to save battery life.
Hope that helps!
May 25, 2008 | Plantronics Bluetooth Headset 610 Wireless...
bluetooth
Try charging your battery.
Dec 25, 2007 | Garmin nuvi 350 GPS Receiver
bluetooth
in this h.set BT automatically switches off after few seconds if not in use.it protects ur h.set from viruses.
u can increase this period from BT settings in h.set
Oct 09, 2007 | Motorola Mobility RAZR V3i Cellular Phone
130 people viewed this tip
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
