Tip & How-To about Cell Phones
Flashing motorola phones without a battrey
If you have a dead battery and you want to flash your Motorola phone and you cant do that cause your battery is dead . well i have a solution for you guys . all you need is all usb cable and Motorola rsd lite 3.7 or better now. OK no battery needed remove the battery , on the device hold down the # * buttons than plug in the usb while holding the # * and that should put the device on flash mode that hit start and let the phone flash itself and after its done passed flashing go ahead and insert your battery on the phone and let it charge by it self , easy trick and a tip for the flashing software guys ........good luck from ...rymi1982
Cell Phones Logo
dead prob.motorola c168
first check battery voltage on multimeter
3.60 to 4.20
or change battery
check battry connector
check shorting
check on off voltage 2.80v.
flash ur phone on software
then hardware fault check power supply
idrish 911
Oct 28, 2010 | Motorola Mobility C168 Cellular Phone
how to get flash mode off a phone
How to fix Motorola Flash Mode Of Death To do this you must have a fully charged batery, i know when your phone is stuck in flash mode you cant charge your battery so your gonna have to buy a new one or try to charge the battery i another phone.
First download Motorola RSD Lite 3.2 from here http://www.cpfxwireless.com/downloads
Then download the Monster flash file from here http://www.cpfxwireless.com/downloads (Same place i no)
Then extract your monster flash file, save it to somewhere on your computer.Plug in your phone when on motorola flash mode .Open RSD lite , find your monster flash file wherever you saved it then click on start. You can always use the Motorola Software update , but i already had the latest software on my phone so there was nothing to update
Jun 29, 2010 | Motorola Mobility MOTOKRZR K1 Cellular...
Blue screen for my motorola krzr and i cant get out of it
it seems that u have bricked your phone. you will need to google around how to flash your krzr. you will need a usb cable and alot of programs and alot of reading to study and understand about flashing.
visit this page for starters.
http://www.ehow.com/how_2003116_flash-update-software-on-moto-razr-slvr-krzr-etc.html
i hope this helps you.
Jan 26, 2009 | Motorola Mobility RAZR V3
death/dead/damages wont turn ON but battery is OK
It could be that the battery went dead while programming the phone....so you should take it to a mobile service center and have it check or diagnosed to determine what is further needed to get it working again.
Aug 27, 2008 | Cell Phones
MOTOROLA v360 death/dead damages wont turn ON
probably faulty firmware, or the battery blown.
if the firmware is faulty and cant usb connect, the fone is probably stuffed.
if battery blown, just buy new battery.
Aug 27, 2008 | Motorola Mobility V360 Cellular Phone
161 people viewed this tip
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
