Tip & How-To about Cell Phones
Reseting htc shadow to factory setting
Press and hold the 2 soft keys on the top and hold down power button , after 3 seconds release power and keep holding down the 2 soft key wait for the screen says rebbot to factory settings press yes and that shoud do the trick for you and goes back from the factory settings default settings . good luck
rymi1982
Cell Phones Logo
I forgot my phone password for my HTC S621 that I haven't used in 2 years. Is there a way to reset it?
1. PRESS AND HOLD BOTH SOFT KEYS.
2. WHILE HOLDING DOWN SOFT KEYS, PRESS AND RELEASE THE POWER BUTTON, WAIT 3-5 SEC. (PHONE SHOULD POWER ITSELF ON BY DOING THIS)
3. RELEASE THE TWO KEYS SOFT KEYS.
4. WHEN SCREEN ON DASH LOOKS LIKE IT'S IN DOS FORMAT, PRESS SEND (GREEN ANSWER KEY)
or
With the phone on
Select Start> Accessories> Clear Storage> enter reset code default is 12345> Select YES.
May 24, 2011 | Cell Phones
my 6600 keeps on sending mms
Reset your sofwares :
*#7780# (*#rst0*) - This will soft reset your phone. It is different from *#7370# because all data, like contacts, calendar and notes, are not removed.
It will only reset the phone settings, such as profiles, themes and shortcuts.
The default lock code is 12345.(Read Method 3)
or try this(But it will fully format your phone)
Method 1:
Three Finger Reset for Nokia Phone
1. Switch off your Phone.
2. Hold down the following three keys, Green (call answer button) * (Star) Key, and Number '3' key.
3. While holding The Three buttons, press the power button for switch on the phone.
4. Wait for the message 'Formatting' to the screen On Your Mobile and release all keys when you see that message.
Method 2:
Hard Format of Nokia Mobile Phone
2. Now Press following key-*#7370#
3. Enter Default lock code is 12345.
4. While holding All of the buttons, press the power button for switch on the phone.
5. Wait for the message 'Formatting' to the screen On Your Mobile and release all keys when you see that message.
Method 3:
Soft Reset of Nokia Mobile Phone
1. Switch off your Nokia phone
2. Now Press following key sequence *#7780#
Please Note:
The formatting method will erase all of your Phone data.
Please take a backup before you Format.
Nov 05, 2010 | Nokia 6600
how to format the nokia n81
1. Switch off the phone.
2. Hold down the following three buttons: Green (call answer button, * button, and ‘3′ button.
3. While holding these buttons, press the power button and switch on the phone.
4. When the message ‘Formatting’ appears on the screen, release all of the buttons.
Method: 2 ( Hard Format)
Sep 04, 2010 | Nokia N81 Smartphone
lock code needed
There should not be a lock code.
Are you talking about a master reset?
1. PRESS AND HOLD BOTH SOFT KEYS. the buttons on the left and right of the middle joystick (the dash lines)
Apr 28, 2008 | T-Mobile Dash Smartphone
deleted camera from dash
I would back up any crucial information you have on your Dash and do a hard reset and when your Dash re-boots it should have all the original programs your phone came preinstalled with. it Dash Hard Reset
1. Select Start
2. Accessories
3. Clear Storage
4. Type 1234 in the box
5. Select YES. OR
- with the phone powered off
- press the two soft keys, yes the left and right soft keys which are the two dash keys labeled - -
- while keeping it pressed, press the power button down
- keep the power button pressed down for 1 - 2 seconds and then release the power button while still holding down the two soft keys. Keep holding down the soft keys until a black screen appears and prompts appear
- now release the soft keys and follow prompts
Apr 09, 2008 | T-Mobile Dash Smartphone
154 people viewed this tip
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
