Tip & How-To about Cell Phones
Tata docomo internet settings
TATA DOCOMO SETTINGS
DIALING NO -> *99***1#
EXTRA INITIALIZING COMMAND -> AT+CGDCONT=1,"IP","TATA.DOCOMO.INTERNET"
ip address -> 010.124.094.007
PORT ADDRESS -> 8080
APN -> TATA.DOCOMO.INTERNET
Cell Phones Logo
i am not able to connect my samsung B7722 to PC internet using KIES software.
Tips for connecting Samsung B7722 1. Remove all other Modems if any and then restart 2. Check the ISP name and Dial up number 3.Use below command if you are failing at step" Registering your computer on network" AT+CGDCONT=1,"IP","uninor" or AT+CGDCONT=1,"IP","aircelgprs" Add this line in "Extra Initialization command" In the Modem properties. (Depending on the ISP provider)
May 14, 2011 | Samsung Modem Configuration Software...
i need tata docomo gprs setting (95 rs grps plan)
it is here
Create a WAP profile with following Settings: - Connection Name : DOCOMO (You may choose any name you like)
- Data Bearer : GPRS - Access Point Name : TATA.DOCOMO.INTERNET - Username
- Password
- Homepage
- Connection Security : Off - Session Mode : Permanent
In case of the WAP 2.0 compliant phones, the following extra settings need to be done:
- Under Options : Advanced Settings - Phone IP Address : Automatic - DNS Address : Automatic - Primary name server : 0.0.0.0 - Second name server : 0.0.0.0 - Proxy server address : None - Proxy port number : 0
If you do not have a Nokia and Sony Ericsson phone, you'll need to set your phone manually with these details. Setting Name DOCOMO (You may choose any name you like) Home page
Session mode Permanent Connection Security Off Data Bearer GPRS GPRS Access point TATA.DOCOMO.INTERNET IP address <blank> Authentication type Normal Logintype <blank> User name <blank> Password <blank>
Jan 08, 2011 | LG GT540 Cell Phone
I am using samsung gt-S5350 and tata docomo sim, I can access internet on my mobile but when i try to access internet through mobile on my lenevo laptop it gives "os error, remote device not connected" please help
Samsung PC Suite - Internet through mobile modem -Error 619 - Data Cable
Rectifying the error
1. Samsung USB modem driver (Download from Samsung ' Local Link)
2. Connect Your Samsung with a working Internet connection ( via )USB Cable
3. Samsung PC Studio or any other Samsung mobile drivers are not installed
Procedure
1. Connect your Samsung Star 3G to your PC and install the modem drivers that you have downloaded.
2. Goto Control Panel > Phone and Modem Options
3. Select the Modems tab. You will see Samsung mobile modem listed.
4. Select it and click on Properties.
5. Goto the Advanced tab and put the following in the box for Extra Initialization Commands:
+cgdcont=1,"IP","your_apn_name"
( or tye AT+CGDCONT=1, "IP', "apnname")
eg:- +cgdcont=1, "IP", "bsnlnet"
6. Hit OK and exit.
The next step is to create a dialler for your Samsung Star 3G mobile modem.
Error 619 solved
1. To create a dialler, Goto Control Panel>Network Connections
2. Hit Create a New Connection and proceed as follows (each sub-point is for each screen of the wizard):
2.1 Network Connection Type: Connect to the Internet
2.2 How do you want to connect to the Internet: Set up my connection manually
2.3 Select Connect using a dial-up modem
2.4 Select Modem-Samsung Mobile Modem
2.5 Type an ISP name according to your preference (could be anything)
2.6 Type*99# as the phone number ( or type *99*1*1# or *99***1# )
2.7 Leave Username, Password and Confirm Password fields blank
2.8 Hit Finish
That would complete the wizard and make a dial-up connection for you. Dial it and you will be connected to the Internet via your Samsung Star 3G phone modem without using Samsung PC Studio
Nov 01, 2010 | Samsung Modem Configuration Software...
I want to connect laptop for internet using with my samsung Champ GT-C3303. So I need PC suite for samsung Champ GT-C3303 mobile
you need to download samsung kies software.. and install it. then automatically the required drivers will also be installed.. then follow the instructions as below..
NOTE: following instructions are for tata docomo internet. names may vary depending on your mobile network.
you just connect with bluetooth or data cable and find out the modem then u goto control panel ->phone and modem option then dialing rules tab ->new -> country/religion fill India and area codeand then ok. and then goto same dialog box in modem tab n select modem click ->properties and then advance tab n fill in extra initialization commands: AT+CGDCONT=1,"IP","TATA.DOCOMO.INTERNET" and then ok.
goto control panel ->network connection ->create a new connection ->new connection wizard next ->choose connect to the internet ->next ->choose setup connection manually ->choose connect using to dial-up modem ->next ->isp name -tata ->next ->phone number- *99# ->next ->next ->finish
then you a dialing tata icon in the desktop and you r connect internet in your pc
Sep 17, 2010 | Samsung SGH-D900 Cellular Phone
MOBILE TO PC INTERNET CONNECT.
these r the steps:-
1. download & install pc suit
2. go to control panet/phone and modem
and click on modems select ur phone
click on properties and then change settings click on advanced & fill extra command which is:- AT+CGDCONT=1,"IP","tata.docomo.internet"
in" " u use access point of ur service provider
and exit
use control panel connections and use dial up connect use ur phones modem and dial no. is *99# dial this is connected
May 07, 2010 | Samsung SGH-L700 Cell Phone
2,984 people viewed this tip
Top Cell Phones Experts
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
