Tip & How-To about Computers & Internet
HOW TO REPAIR MISSING OR DAMAGE FILES PLEASE NOTE THAT THIS APPLY TO BOTH LAPTOP AND DESKTOP COMPUTERS. Hi there if your computer has missing files or a file is corrupt and you need to repair the damage file, you can do this by using a recovery disk for the computer if you have one. If you do not have a recovery disk for the computer you can use the operating system disk to repair it, please follow these steps: insert the operating system disk into the CD/DVD drive, restart the computer, press F12 and choose boot from CD save and exit. While the computer is loading it will ask you to press any key to boot from CD, so you will press any key, a blue screen will appear while its loading, when it get to the first set of options you will press enter to continue. when it get to the second set of options it will ask you to install the operating system or repair it, choose repair and follow the steps from there, once you choose repair, the computer will go through different stages. The next step is to enter the keys for the operating system the computer will continue until it finish the repairs and this should solve the problem of missing files. But you should backup your files before doing this even though no files should be lost but its better to backup just in case something goes wrong. Backing up the file is always an important part of having a computer, you should also create a recovery CD and this can be done during the process of backing up your computer files. The back up files should be store on one or more DVDs or other storage device and this along with the recovery CD should be store in a safe and dry place. The purpose of the recovery CD is to repair damage or missing files on the computer and each computer require its own back up and recovery disk to repair the problem.
Computers & Internet Logo
I have a Toshiba Notebook L300 series. My Window Vista will not load fully. it states I need a file C:/windows\system32\systempropertiesprotection.exe. I have looked on line but found nothing.
Hi the file is missing if you have a recovery disk or the operating system CD you need to use it to repair your computer.Please follow these steps:use recovery disk for the computer if you have one. If you don't do not have a recovery disk for the computer you can use the operating system disk to repair it, please follow these steps: insert the operating system disk into the CD/DVD drive, restart the computer, press F12 and choose boot from CD save and exit. As the computer loading it will ask you to press any key to boot from CD, press any key, a blue screen will appear while its loading, when it get to the first set of options you will press enter to continue. when it get to the second set of options it will ask you to install the operating system or repair it, choose repair and follow the steps from there, once you choose repair, then computer will go through different stages. The next step is to enter the keys for the operating system the the computer will continue until it finish the repairs and this should solve the problem of missing files. But you should backup your files before doing this even though no file will be lost but its better to backup just in case something goes wrong. Backing up the file is always an important part of having a computer, you should also create a recovery CD and this can be done during the process of backing up your computer files. The back up files should be store on one or more DVDs and this along with the recovery CD should be store in a safe place and dry place. The purpose of the recovery CD is to repair damage or missing files from the computer and each computer require its own back up and recovery disk to repair the problem.
Jul 13, 2010 | Toshiba Computers & Internet
Computer will not boot up
This is because of either the system has shutdown while it was processing a windows file. sometimes repairing the OS or running a CHKDSK /R in the recovery console will fix this problem. if that doesnt help i recommend you change your HDD
Sep 16, 2009 | Dell Optiplex 740 Desktop Desktop Computer...
ntldr is missing press ctrl alt del to restart cant install o/s
This problem may occur if the basic input/output system (BIOS) on your computer is outdated, or if one or more of the following Windows boot files are missing or damaged: Ntldr
Ntdetect.com
Boot.ini To resolve this issue, verify that the BIOS on your computer is current, and then use one or more of the following methods, as appropriate to your situation, to repair the Windows 2000 startup environment.
Verify That the BIOS on the Computer Is Current loadTOCNode(3, 'summary'); Make sure that the latest revision for BIOS is installed on the computer. Contact the computer manufacturer to inquire about how to obtain, and then install the latest BIOS update that is available for the computer.
Method 1: Use a Boot Disk to Start the Computer loadTOCNode(3, 'summary');
  1. Create a Windows 2000 boot disk that contains the following files: Ntldr
    Ntdetect.com
    Boot.ini
    Ntbootdd.sys For more information about how to create a boot disk, click the following article numbers to view the articles in the Microsoft Knowledge Base: 301680 (http://support.microsoft.com/kb/301680/ ) How to create a boot disk for an NTFS or FAT partition in Windows 101668 (http://support.microsoft.com/kb/101668/ ) How to use a Windows boot disk to prevent boot failure
  2. Modify the Boot.ini file to point to the correct hard disk controller and to the correct volume for your Windows installation. For more information about how to create a boot disk, click the following article number to view the article in the Microsoft Knowledge Base: 311578 (http://support.microsoft.com/kb/311578/ ) How to edit the Boot.ini file in Windows 2000
  3. Insert the boot disk into the computer's floppy disk drive, and then restart the computer.
  4. Copy the Ntldr file, the Ntdetect.com file, and the Boot.ini file from the boot disk to the system partition of the local hard disk.
Method 2: Use the Recovery Console loadTOCNode(3, 'summary');
  1. Use the Windows 2000 Setup disks to restart the computer, or use the Windows 2000 CD-ROM to restart the computer.
  2. At the Welcome to Setup screen, press R to repair the Windows 2000 installation.
  3. Press C to repair the Windows 2000 installation by using the Recovery Console.
  4. Type the number that corresponds to the Windows installation that you want to repair, and then press ENTER. For example, type 1, and then press ENTER. For more information, click the following article number to view the article in the Microsoft Knowledge Base: 229716 (http://support.microsoft.com/kb/229716/ ) Description of the Windows Recovery Console
  5. Type the Administrator password, and then press ENTER.
  6. Type map, and then press ENTER. Note the drive letter that is assigned to the CD-ROM drive that contains the Windows 2000 CD-ROM.
  7. Type the following commands, pressing ENTER after you type each one, where drive is the drive letter that you typed in step 4 of "Method 2: Use the Recovery Console," of this article: copy drive:\i386\ntldr c:\
    copy drive:\i386\ntdetect.com c:\If you are prompted to overwrite the file, type y, and then press ENTER.
    NOTE: In these commands, there is a space between the ntldr and c:\, and between ntdetect.com and c:\.
  8. Type the following command, and then press ENTER: type c:\Boot.iniA list similar to the following list appears: [boot loader] timeout=30 default=multi(0)disk(0)rdisk(0)partition(1)\WINNT [operating systems] multi(0)disk(0)rdisk(0)partition(1)\WINNT="Microsoft Windows 2000 Professional" /fastdetect If you receive the following message, the Boot.ini file may be missing or damaged: The system cannot find the file or directory specified.
  9. If the Boot.ini file is missing or damaged, create a new one. To do so, follow these steps:
    1. Use a text editor, such as Notepad or Edit.com, to create a boot loader file similar to the following boot loader file: [boot loader] timeout=30 default=multi(0)disk(0)rdisk(0)partition(1)\WINNT [operating systems] multi(0)disk(0)rdisk(0)partition(1)\WINNT="Microsoft Windows 2000 Professional" /fastdetect For more information, click the following article number to view the article in the Microsoft Knowledge Base: 102873 (http://support.microsoft.com/kb/102873/ ) Boot.ini and ARC path naming conventions and usage 301680 (http://support.microsoft.com/kb/301680/ ) How to create a boot disk for an NTFS or FAT partition in Windows
    2. Save the file to a floppy disk as Boot.ini.
      NOTE: If you used Notepad to create the file, make sure that the .txt extension is not appended to the Boot.ini file name.
    3. Type the following command at the Recovery Console command prompt to copy the Boot.ini file from the floppy disk to the computer: copy a:\Boot.ini c:\
  10. Type exit, and then press ENTER. The computer restarts.
Jul 07, 2009 | Compaq Evo D500 PC Desktop
windows xp missing file and won't start up
Here's what I would do, because after reading around on that error message, it seems like you can't repair the problem.
I would find myself one of these: http://www.casecooler.com/3drto2dr.html
Take out your laptop's HD, hook it up to that convertor, slave it to a desktop, pull all your data that you don't want to lose to the desktop, put the laptop's HD back into the laptop, reformat/reinstall windows back onto the laptop, pull the HD back out of the laptop, hook it back up to that convertor, slave it back to the desktop, put your data back onto the laptop's HD, then put it back in the laptop.
That will leave you with a clean install that works on the laptop and you won't lose any data.
Nov 12, 2007 | Compaq Presario V4000 Notebook
394 people viewed this tip
David Payne
David Payne
