Tip & How-To about Televison & Video
CLEANING FILTERS IN A PANASONIC DLP
THIS TIP WILL BE BASED ON A PANASONIC DLP MODEL PT-52LCX65-K
MANY OWNERS OF PANASONIC DLP S RECIEVE A ERROR MESSAGE THE TEMP LED WILL FLASH 5 TIMES EVERY 5 SECONDES .THIS INDICATES A CLOGGED AIR FILTER .It is important to take in consideration before starting that even after cleaning the tv and the filters problem can comeback if such is the case this indicates a more sever problem .
So lets get started first we must tack off the backcover
Televison & Video Logo
Where is the air filter on a Panasonic PT-52LCX65 Projection TV
THE AIR FILTERS ARE INSIDE THE ENGINE YOU MUST TAKE APART MANY PIECES LET A REPAIR CENTER DO THIS!!
Apr 25, 2010 | Panasonic PT-52LCX65 44" HDTV
Panasonic projection TV does not turn on.
Power LED flashes orange 1 x 5 secs. = 1 of 3 fans stopped. TEMP LED flashes 1 x 5 secs, = Temperature error. Lamp LED flashes 1 x 5 secs. = lamp ballast error. (check lamp 1st.)
Hope this helps.
Apr 18, 2010 | Televison & Video
The TV cannot turned on. The lamp indicator flashes 1 in 5 second
Your owners manual should tell you the blinking code for "needs a lamp". A dlp that age is about due for a lamp. So even if its not the lamp it won't hurt to have one on hand
Apr 09, 2009 | Televison & Video
colored spots on dlp tv screen
coloue spots on screen. how do you fix with screwdriver?
Jul 22, 2008 | Panasonic PT-52LCX65 44" HDTV
Panasonic 52lcx65 52in projection tv
I have the same TV had the same problem while under Warranty Panasonic tech replaced the lamp
Apr 15, 2008 | Panasonic PT-52LCX65 44" HDTV
175 people viewed this tip
Top Televison & Video Experts
Electro Med Services...
