Tip & How-To about Computers & Internet
C++ Source code for Celsius to Fahrenheit
#include
#include
#include
using namespace std;
int main(float nNumberofArgs, char* pszArgs[])
double celsius;
cout << "Enter the temperature in Celsius:";
cin >> celsius;
double factor;
factor = 212 - 32;
double fahrenheit;
fahrenheit = factor * celsius/100 + 32;
cout << "Fahrenheit value is:";
cout << fahrenheit << endl;
system("PAUSE");
return 0;
Computers & Internet Logo
write a program to sum of all even integer numbers
#include <iostream>
int main ()
int num = 0, i = 1, sum = 0;
cout << "Enter a positive integer: ";
cin >> num;
while (i <= num)
sum += i;
i++;
cout << "The sum is " << sum << endl;
return 0;
Oct 30, 2010 | Compaq Visual Fortran Professional Edition...
how to drop random letters on the screen using linked list
This is just an example for int you can use your logic for chars
#include <cstdlib>
#include <ctime>
#include <iostream>
int main() {
srand
(time(NULL));
cout
<< rand() % 10 + 1 << endl; //number between 1 and 10
return 0;
May 04, 2009 | Computers & Internet
how i make calculator by using source code in c++?
hi,
here is the code u looking for
#include <iostream.h>
float sub (float a, float b)
float dif;
dif=a - b;
return dif;
float addition (float c, float d)
float sum;
sum=c+d;
return sum;
float divi (float e, float f)
float quo;
quo = e/f;
return quo;
float multi (float f, float g)
float pro;
pro=f * g;
return pro;
int main ()
float a;
float b;
float opt;
cout << "Welcome to the calculator" << endl;
cout << "There are four options " << endl;
cout << "Option 1 is subtraction, Option 2 is addition, option 3 is division, and option 4 is multiplication " << endl;
cout << "Enter your option and two digits " << endl;
cin >> opt >> a >> b;
if (opt == 1)
float temp= sub (a, b);
cout << "Your difference is " << temp << endl;
else
if (opt==2)
float temp2= addition (a, b);
cout << "Your sum is " << temp2 << endl;
else
if (opt == 3)
float temp3= divi (a,b);
cout << "Your quotient is " << temp3 << endl;
else
if (opt == 4)
float temp4= multi (a,b);
cout << "Your product is " << temp4 << endl;
else
cout << "That function is not supported in calculator!" << endl;
cout << "Thank you for using calculator" << endl;
return 0;
Thanks!
Mar 19, 2009 | Microsoft Computers & Internet
HOW TO PROGRAM ARITHMETIC ALGORITHM( ADDITION)IN C++
above int main () you will want "using namespace std;" without quotes. Under that, "int main ()" without quotes, then a [ bracket to start the main function.
Please rate, thanks!
Mar 16, 2009 | Computers & Internet
c++ programs
An array is a series of elements of the same type placed in contiguous memory locations that can be individually referenced by adding an index to a unique identifier
Initializing arrays. When declaring a regular array of local scope (within a function, for example), if we do not specify otherwise, its elements will not be initialized to any value by default, so their content will be undetermined until we store some value in them. The elements of global and static arrays, on the other hand, are automatically initialized with their default values, which for all fundamental types this means they are filled with zeros
include <iostream>
int billy [] = {16, 2, 77, 40, 12071};
int n, result=0;
int main ()
for ( n=0 ; n<5 ; n++ )
result += billy[n];
cout << result;
return 0;
multidimensional array pseudo-multidimensional array #define WIDTH 5 #define HEIGHT 3 int jimmy [HEIGHT][WIDTH]; int n,m; int main () { for (n=0;n<HEIGHT;n++) for (m=0;m<WIDTH;m++) { jimmy[n][m]=(n+1)*(m+1); } return 0; } #define WIDTH 5 #define HEIGHT 3 int jimmy [HEIGHT * WIDTH]; int n,m; int main () { for (n=0;n<HEIGHT;n++) for (m=0;m<WIDTH;m++) { jimmy[n*WIDTH+m]=(n+1)*(m+1); } return 0; }
and now for trignometry
#include<iostream>
#include<cmath>
int main()
int factorial(int);
int n = 3, i = 1;
double x, x2, b, PI, r;
char choice;
//r = x * (PI / 180)
cout<<"Please enter an angle value => ";
cin>>x;
cout<<"Is the angle value in Degree or Radian?"<<endl;
cout<<"Type D if its in degree "<<endl;
cout<<"Type R if its in radian "<<endl;
cin>>choice;
if((choice = 'R')||(choice = 'r'))
do{
i++; n = 3; x2 = 0; b = x2;
if(i == 1)
x2 = x - (pow(x,n) /factorial(n));
n = n + 2;
else
x2 = (x2 + ((pow(x,n)) /(factorial(n))) - (pow(x,n+2)) / (factorial(n+2)));
n = n + 4;
}while(abs(b - x2) > 0.000001);
else
//convert it to r
r = x * PI /180;
//cout<<"error occured/n";
cout<<"sin(x) = "<<x2<<endl;
return 0;
Mar 24, 2008 | ArcMedia JavaScript Source Code 3000 Pro...
266 people viewed this tip
David Payne
David Payne
