Tip & How-To about Air Tools & Compressors
Worn Out Hand Tools and Drill Bits..........
Greetings,
I don't know about you but I am sick and tired of paying for drill bits that wear out afetr they are used a few times and then have to be re bought.
I refuse, and here is what i decided to do to keep the money in my pocket and not their's.
First I bought myself a nice little electric Sears bench grinder. then I read about sharpening the drill bits on the grinder, after quite a few experimental tries I now have the angle of gring down to a science and my drill bits are sharp and ready to go everyday all day.
Also I fond my chisels need sharpening and my straight blade screw drivers as well so I do them all, of course wearing protective clothing and safety eye googles.
How about preserving those expensive pneumatic hand tools you have, they get abused also, much more then you think.
even after you bleed out the water and moisture from you air compressor and air lines using a water seperator the air tools still need this very important item to keep it working right and ready everyday....it is called putting just a few drops of air tool iol into the air inlet side of the tools and running them with a rag placed over the exhaust ports catching the dirty spent oil coming out the end. Keeps them clean and well oiled for long life and durability.
Air Tools & Compressors Logo
Why Power Tool batteries can't charge to 100%?
Batteries wear down over time. The cells inside them don't work as well at holding a charge compared to when they were brand new. So after using them for a while they begin to last a shorter amount of time.
Lithium Ion batteries last longer and don't wear out as quickly. NiMH batteries are next in reliability. And NiCad have their own issues.
Aug 13, 2012 | Drills
is it necessary to replace all 4 tires at the same time? Only 2 were worn to an unsafe condition.
You do not have to replace all 4 timres at the same time. It is most advantageous to put the NEW tires on the front of the vehicle and have an alignment done at the same time. Tire wear is always cause by steering and suspension components. Have them inspect your front end before the alignment is done. They will check bearings, bushings and rod ends for wear. Don't be cheap if you see that the components are worn. (They will show you!) Worn suspension parts can cause a new set of tires to go bad in a few weeks if the wear is extensive.
Thanks for choosing FixYa,
Kelly
Sep 13, 2011 | 2008 Ford Taurus X
Don't know how to attach a screw on to my corded Skil 3/s drill. Is there a special bit for this purpose?
Hi auntygamma,
Welcome to fixya!
Yes, you need to use a bit with all drills. They come in different sizes and shapes. If you don't have any bits to put into your drill, an all purpose kit would be nice to have. You can find them at your local hardware store or online.
Check out this webpage: http://www.toolup.com/dewalt_dw2163_37-piece-screwdriving-set-with-tough-case.aspx
Copy and paste this entire web address into your browser and a page with one of the kits on it will open up for you. You don't have to buy a kit with lots of bits, you can pick up just one or two bits that you would use the most at the hardware store. The most used bits would be the #1 and #2 Phillips bits and a couple of different sizes of flat bladed bits. A few drill bits might come in handy too.
The drill that you have has a keyless chuck. This means you don't need any special tools to put in a bit or change one. If you look at the chuck, you'll see that the ridged part has two sections. If you hold the back section with your left hand, you can turn the front section to either open the chuck or close it to put bits in.
I don't know if this was clear or not, but if you have any problems or more questions about this, please be sure to reply back. I'll be glad to help you.
Thanks,
Handie Andie
Aug 14, 2011 | Craftsman 3/8" Corded Drill
Trying to get the drill bit out and I don't know how???? What do I do to get it out? I want to use a different bit.
put your hand around the nose of the drill and turn counter clock wise until the bit falls out. then put another one in and turn clock wise to tighten it.
Jun 11, 2011 | Dewalt & 14.4V Xrp Hammer Drill
hammer drills Features
There are a few features you may want to pay attention to include: A Depth Rod mounted to the drill lets you know when the bit reaches the desired depth; Variable Speed Selection allows you to adjust the drill for specific jobs. Use high speed for small holes and low speed for large holes; Reverse can retrieve a hopelessly stuck bit; Removable Side Handles give the operator better control in normal use, and can be removed in confined spaces.
Aug 27, 2008 | Makita LXT202 BHP451 18 Volt Hammer Drill...
1,185 people viewed this tip
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
