Tip & How-To about Computers & Internet
How to fix the Windows 7 Network Connection Problem
On this short demonstration, I would like to present, how to fix the network connection problem in windows 7. As we know, many Windows 7 users are facing Network connection problem like;
"unidentified network" or "no internet access"
I don't mean this will work for all the users, but most users will definitely get benefit from this. There might be other fixes too, but I am only presenting the most common and the simplest method.
Before we begin, please disable the Internet Protocol Version 6"ipv6" (what we commonly use is Internet protocol version 4 "Ipv4") from your "Local Area Network Properties" if you don't need it (this is not totally implemented for home users, if you are sure you need it, no problem just leave it as it was). To do this, click on the "Local Area Network Status" click "Properties" and from the list below the "General" tab, uncheck (remove the tick mark) from the "Internet Protocol (Tcp/Ipv6)" or something like that, and click "Ok" and close it.
Also enable "dhcp" services, if otherwise you'll need to provide a static ip address, type in the ip address which was given by the Internet Service Provider (ISP) on the IP address box. This depends on the service provider from whom you get your connection. When you are done, click "Apply" and then "ok".
Now, let's proceed simply like this.
Start -> Run (in the text box)-> and type in "msconfig" (without qoutes)
The System Configuration Utility window will pop up, now click on the "Services" tab and from the services lists, locate "Id_String2.6844F930_1628_4223_B5CC_5BB94B87 9762", and disable it. (Remove the tick mark on the left hand side of the above mentioned "Id_String2.6844F930_1628_4223_B5CC_5BB94B87 9762" )
Click "Apply" and then "Ok". You'll need to restart your system for the changes to take effect.
Optional; You can also go to the "services" directly by typing "services.msc" in the run box. The only difference is that, you'll need to right click on the "Id_String2.6844F930_1628_4223_B5CC_5BB94B87 9762", sand select "disable" or "Stop". Restart your computer or you can try disabling and enabling the Network Adaptor. Now check your internet connection by dialing using your username and password or try connecting to the ISP.
If unfortunate, this doesn't work for you, you can also try the following methods;
Open the Network Adaptor Properties, click on the "configure" and then again "Advanced" and on the left pane, click "flow control" you'll see the value (which is set) on the right hand side of the dialog box, change the value to "rx & tx" (when you click over the value box, a drop down list will be displayed, select rx&tx from the list and click ok). Sometimes even small trick fixes the problem.
If anyone has come across this similar problem and have solved using another method, it'd be very much appreciated if he/she can add them as comments. Good luck to you all.
Computers & Internet Logo
Which service has to be active in order to access my network?
In order to access your network, you need to make sure that your router or modem is turned on and Internet is working. Additionally, you must ensure that network adapter on your computer is enabled.
To know how to connect to Internet, refer to the instructions mentioned on the links below:
http://windows.microsoft.com/en-in/windows/connect-internet#1TC=windows-7
http://www.wikihow.com/Connect-to-the-Internet-Wirelessly-in-Windows-7
In case you are facing issues connecting to Internet, refer to the link below for troubleshooting options:
http://windows.microsoft.com/en-in/windows/cant-connect-internet#1TC=windows-7
GuruAid.com
Jan 07, 2016 | Microsoft Windows 7 Professional Service...
I have windows 7 home prem and cannot connect says detects strong signal but limited access
Most likely, the access point is not connected to an internet gateway whatever that is at your place.
and since access points does not provide DHCP service by default (handing out IP information to connected clients), you get the limited access message.
In short, make sure the access point is connected to the router because the router is the once responsible for providing the DHCP service.
Feb 18, 2012 | ASUS WL-330 802.11b Wireless Access Point
How to network connect and activate windows 2007 & MAC X
Set up user accounts
Users connecting to Windows Sharing must have user accounts on the Mac OS X computer that is sharing. There is no guest access. Any person who already has an account on the Mac OS X computer can use his existing account. You must log in to the Mac OS X computer with an administrator account to set this up. The steps differ for new and existing users.
For new users
  1. From the Apple menu, choose System Preferences.
  2. From the View menu, choose Accounts.
  3. Click New User (10.2) or the "+" button (10.3 or later).
  4. Enter the Name and Short Name for the user who will log in from Windows.
    The user's short name is exactly how the user will enter their name when they log in to Windows Sharing. The short name is always lowercase.
    For users of Windows 98: If you log in to Windows 98 with a username, make sure it matches your Mac OS X account's short name. If you do not log in to Windows 98 with a username, you will need to create a new Windows 98 username that matches the account short name in Mac OS X. For more information on using Windows operating systems, please see Microsoft documentation or contact Microsoft for further assistance.
  5. Enter the user's password.
  6. 10.2 only: Click the checkbox for "Allow user to log in from Windows".
  7. 10.2 only: Click OK.
  8. Quit System Preferences.
If your Windows PC has is equipped with an Ethernet port, you can connect your PC and Macintosh using an Ethernet cable. By doing this, you are creating a small local network, consisting of just the two computers. Set up your Windows PC by turning on File Sharing. Refer to the instructions that came with your Windows PC if you're not sure how to do this.
To locate and connect to the Windows computer, you can use the sidebar in a Finder window. You need to know the workgroup name for the computer and the network name (called the "computer name") for the computer. To connect to the computer, you also need a user name and password and the name of the shared folder you want to access. If you don't have this information, contact the person who owns the computer or your network administrator.
If you cannot locate the Windows computer in the Network browser, you may be able to connect to it using the Connect To Server dialog in the Finder.
Make sure the Internet Connection Firewall is turned off, or if it's on make sure TCP port 445 is open to allow sharing connections.
To connect you Mac and Windows computers: step_1.gif
In the Finder, choose Go > "Connect to Server."
Type the network address for the computer in the Server Address text box using one of these formats:
smb://DNSname/sharename smb://IPaddress/sharename
Follow the onscreen instructions to type the workgroup name and a user name and password, and choose the shared folder you want to access.
Feb 23, 2011 | Computers & Internet
My D7160 cuts the bottom part off of every photo. How do I fix this?
HP Print Diagnostic Utility was created to help users troubleshoot and correct many common problems on Windows-based computers that can prevent printing.Follow the on-screen instructions to run the utility. Details and specifications File name: s.gif HPPDU.exe [1/1, 1.54M] System requirements: s.gif No additional prerequisites Released: s.gif 2010-08-13 Version: s.gif 3.0.0.013 Compatibility: s.gif Microsoft Windows Vista, Microsoft Windows Vista Home Premium (32-bit), Microsoft Windows Vista Home Basic (32-bit), Microsoft Windows Vista Business (32-bit), Microsoft Windows Vista Ultimate (32-bit), Microsoft Windows 7 (32-bit), Microsoft Windows 7 Home Basic (32-bit), Microsoft Windows 7 Home Premium (32-bit), Microsoft Windows 7 Professional (32-bit), Microsoft Windows 7 Enterprise (32-bit), Microsoft Windows 7 Ultimate (32-bit), Microsoft Windows 7 Home Basic (64-bit), Microsoft Windows 7 Home Premium (64-bit), Microsoft Windows 7 Professional (64-bit), Microsoft Windows 7 Enterprise (64-bit), Microsoft Windows 7 Ultimate (64-bit), Microsoft Windows 7 (64-bit), Microsoft Windows Vista (64-bit), Microsoft Windows Vista Home Basic (64-bit), Microsoft Windows Vista Home Premium (64-bit), Microsoft Windows Vista Business (64-bit), Microsoft Windows Vista Enterprise (64-bit), Microsoft Windows Vista Enterprise (32-bit), Microsoft Windows XP Fix/Enhancement: s.gif This version of the HP Print Diagnostic Utility provides an improved user interface in multiple languages, improved diagnostic and problem resolution capability, and support for usb and network connected devices.
Oct 27, 2010 | HP Photosmart D7160 InkJet Printer
3,129 people viewed this tip
David Payne
David Payne
