Tip & How-To about Office Equipment & Supplies
How to print a Test Page Configuration sheet in minolta 350
To print a Configuration page, perform the following:
1. While in Copy mode, press the Utility button.
2. On the LCD press Printer Settings.
3. Press Check Job Settings. Configuration page will print at this time.
the logo in my print job is color Green but its coming out in color blue. what is the problem
Check the yellow toner cartridge, printing a configuration page.
Configuration page
The Configuration page lists the current settings and properties of the printer. You can print a
Configuration page from the printer or HP Toolbox. To print the Configuration page from the printer,
complete the following steps.
1 Press the (LEFT ARROW) or the (RIGHT ARROW) buttons to select the Reports menu.
2 Press the button (SELECT).
3 Press the (LEFT ARROW) or the (RIGHT ARROW) buttons to select Config report.
4 Press the button (SELECT) to print the Configuration page.
Yellow print OK?
No? try print with another yellow toner cartridge (Q6002A).
Aug 10, 2011 | HP Color LaserJet 2600n Printer
please telme how can clean the nozell of a stylus cx6400
Please perform the following steps to ensure your printer is physically functioning.
1) Disconnect the printer cable that is connecting printer to the computer.
2) Turn the printer ON by holding down the POWER button for about 3 seconds.
3) Load A4 or LETTER size paper in the sheet feeder on the back of the printer. Press the SETUP button to enter Setup Mode.
4) Press the green button next to the LCD screen until you see NOZZLE CHECK is displayed, then press the COLOR button to print the nozzle check.
5) The printer will print a pattern displaying a number and a nozzle pattern with black & color. Examine the nozzle check pattern that has printed. Each staggered horizontal line and straight vertical line should be complete.
6) To exit the SETUP mode, simply press the COPY mode so that it is illuminated or the copy options appear in the LCD.
If the nozzle check pattern page doesn't print or if it prints with gaps or missing sections, the print head may need cleaning or the ink cartridge(s) may need to be replaced.
If the nozzle check pattern page prints correctly, the problem may be with your software settings, the interface cable, or your computer.
Jul 06, 2010 | Epson Stylus CX6400 All-In-One InkJet...
how to hard reset a 1312nfi
This reset will change user and network settings Before performing this reset it would be advisable to print some information pages to retain any settings that you might want to restore.
Configuration Page
Press Setup (wrench button) then arrow over to Reports, press OK, then arrow over to Configuration report, press OK.
Menu Structure
Press Setup (wrench button) then arrow over to Reports, press OK, then arrow over to Menu Structure, press OK.
Network Report
Press Setup (wrench button) then arrow over to Reports, press OK, then arrow over to Network Report, press OK.
After printing these reports it will be safe to perform an NVRAM initialization to hard reset the product. Follow these steps.
1. Turn the machine off.
2. Press and hold the right arrow and cancel (x button) while turning the machine on.
3. Release both buttons when Permanent storage init. is displayed.
Once finished resetting the machine will return to Ready.
Jun 16, 2010 | HP Laserjet CM 1312NFI Color Printer
Counter info print out
Hi Beadworker,
This information can be found by printing a configuration page from your printer. Follow these steps to print out a configuration page.
Printing a Configuration Page
You can print a configuration page from the printer’s control
panel. Use the configuration page to view the current settings,
to help troubleshoot problems, or to verify the installation of
optional accessories, such as memory or an optional tray.
To print a configuration page:
1 In ready mode, press the Menu button on the control
panel until you see “Information” on the bottom line of the
display.
2 Press the Enter button to access the menu.
3 Press the Enter button when “Configuration” displays
on the bottom line.
A configuration page prints out.
Oct 11, 2008 | Samsung CLP-510 Laser Printer
Print out counter info
Hi Beadworker,
display.
on the bottom line.
181 people viewed this tip
jasbo
jasbo
