Tip & How-To about Office Equipment & Supplies
C5352 IN MINOLTA 350 PRINTER Cooling Fan Motor Failure
error code 5351
C5351 Power Supply Cooling Fan
Motor Failure
The Power Supply Cooling Fan Motor Lock signal
remains set to H for a set period of time while
the Power Supply Cooling Fan Motor is turning.
• The Power Supply Cooling Fan Motor Lock signal
remains set to L for a set period of time while
the Power Supply Cooling Fan Motor remains
stopped.
Jul 17, 2014 | Konica Minolta bizhub 350 All-In-One Laser...
konica minolta bizhub 350 error code c5352
Cooling fan check the rear of the machine. Looking at the back lower left side remove the rear panel top pane has to be removed also there is a filter with that fan due to age got stuck in the fan remove it blow out fan with air, tape the filter to the metal frame instead of putting it on the fan frame out or inside. or the fan is bad worse case the control board is bad$$$$
Jul 17, 2012 | Minolta bizhub 350 Black and White Copier
eroor c5352
Hi the error that you have is that the cooling fan motor may have failed check the motor and connectionsdo a m5 operation check to see if the motor is working if the motor is all working after checking then replace pwb-a board
Jan 20, 2011 | Minolta bizhub 350 Black and White Copier
c-5354
Cooling Fan Motor Failure. Can't tell you which one tho as the factory service manual shows C5351, C5352 and C5353 but does not list a service code C5354. If by chance it is one of the other codes then let me know and I can tell you which it is. Minolta's throw cooling fan codes sometimes. You can usually reset the code will "bumping" the machine and they will at least run ok until the motor stops in the "dead spot" again.
Good Luck and Thank You for using Fixya.
Jun 03, 2010 | Konica Minolta bizhub 350 All-In-One Laser...
194 people viewed this tip
k24674
jasbo
jasbo
