Tip & How-To about Computers & Internet
Solution to cannot delete file / folder error
Many times you need to delete some annoying file, but you cannot, as it is being used by some unknown application in your PC or some access permissions are set on the file, which prevent you to delete it. The easiest solution for these was to restart the PC & then try to delete it. But with Unlocker in your hand, you won't need to restart anymore in such situations. For the situations like these, Unlocker is the solution. It not only tells which process is using the file / folder, but also unlock the handles locked by the process, which actually are preventing the actions on the file. The result of this is you can do whatever operations you want on those files. You must have seen these Windows error messages many times. Now you can take care of these error in seconds. * Cannot delete folder: It is being used by another person or program * Cannot delete file: Access is denied * There has been a sharing violation. * The source or destination file may be in use. * The file is in use by another program or user. * Make sure the disk is not full or write-protected and that the file is not currently in use. No more of these annoying errors. Simply right-click the folder or file and select Unlocker. If the folder or file is locked, a window listing of lockers will appear. Simply click Unlock All and you are done. You can download Unlocker from here LINK Have a look at this video to know how to use Unlocker Note : Some antivirus protections may detect some contents of installer as adware. But i assure you that Unlocker is clean & a must have tool for every computer.
Computers & Internet Logo
alot of bmp files and unknown apps on my computer.
just reformate your pc and save all pics or eriplacible stuff but not programmes or exe/application files
Oct 06, 2009 | Compaq Presario 5000 PC Desktop
Undelete records from access table
ou can try to use third party Access recovery utility to restore your lost and damaged data from .mdb files. For more details about this software:-
Access File Recovery
Apr 17, 2009 | Microsoft Access 2000 (077-01277) for PC
What does Windows Vista error 0x00000005 mean?
Applications that are reading file allocation table (FAT) based storage devices at the time of a resume may receive the following error message from the file system: ERROR_ACCESS_DENIED (0x00000005) This occurs although the file has appropriate sharing and access permission.
Examples of storage media that frequently use the FAT file system on Pocket PC 2002 are the PCMCIA PC Card ATA, the Compact Flash (CF) Storage Card, and the Secure Digital (SD) Memory Card.
This behavior is observed when using Pocket PC 2002 Adaptation Kit Update 4 (AKU4) and later.
RESOLUTION:
Applications can handle this situation by detecting the specific error code while reading a storage card file, and then retrying for a short period until the device is ready. The following is an example C code fragment that demonstrates this concept: while ( !WriteFile( hFile, achBuffer, dwBytesRequested, &dwBytesReturned, 0 ) &&
( ERROR_ACCESS_DENIED == GetLastError() ) )
// Access Denied: Maybe the file system is not ready yet.
tries++;
if ( tries > 4 )
break;
Sleep(500);
// It has been a few seconds. The file cannot be accessed.
You can use the same approach for other programming languages. For applications that access the storage card through middleware libraries that do not provide direct access to the file system, you may have to implement transactional or block verification methods to get reliable data transfer across a suspend resume.
Mar 09, 2009 | Microsoft Windows Vista Home Premium with...
332 people viewed this tip
David Payne
David Payne
