Tip & How-To about Computers & Internet
Relax for a second__Enjoy this serve for you.!
Windoows 2000 Error Messages:
1.Enter any 11-digit prime number to continue.
2.Press any key to continue or any other key to quit.
3.Press any key except... no, No, NO, NOT THAT ONE!
4.Bad command or file name! Go stand in the corner.
5.This will end your Windoows session. Do you want to play another game?
6.Windoows message "Error saving file! Format drive now? (Y/Y)"
7.This is a message from God Gates "Rebooting the world. Please log off."
8.To "shut down" your system, type "WIN"
9.BREAKFAST.SYS halted... Cereal port not responding.
10.COFFEE.SYS missing... Insert cup in cup holder and press any key.
11.File not found. Should I fake it? (Y/N)
12.Bad or missing mouse. Spank the cat? (Y/N)
13.Runtime Error 6D at 417A32CF Incompetent User.
14.Error reading FAT record. Try the SKINNY one? (Y/N)
15.WinErr 16547 LPT1 not found. Use backup. (PENCIL & PAPER.SYS)
16.User Error. Replace user.
17.Windoows VirusScan 1.0 - "Windows found. Remove it? (Y/N)"'
18.Your hard drive has been scanned and all stolen software titles have been deleted. The police are on the way.
Computers & Internet Logo
how do i reprogram my speeddial numbers on jazz 4400?
Hello.
From NorStar Support:
To Program Personal Speed Dial Numbers: (Numbers 71 - 94 only.
1. Press the Feature button, then * 4
2. Enter the 2 digit code (71 - 94). that you want to assign to that phone number
3. Enter the telephone number, then press the OK softkey
4. Display will show: "Entry xx stored"
If the above doesn't work, try:
  1. Press [Feature] [*] [4]
  2. Enter a two-digit code from 71 to 94.
  3. Specify the external line by pressing a line button, a line pool button, or the intercom button. If you don't specify the external line, the system automatically chooses a line for the call.
  4. Dial the telephone number you want to program (up to 24 digits).
  5. Press [Hold].
  6. Record the code and number you have just programmed.
Hope this helps.
Feb 02, 2011 | NorStar Jazz Plus 4400 Corded Phone
Lost my manual and cannot remember how to get messages remotely
Since I have not idea what exact model you have this may or may not work... I hope it helps, as it is for a Uniden answering service phone.
Remotely Operating Your Answering Machine
Note: The answering machine will only playback messages for four minutes and then it returns to the command waiting mode.
To continue playing your messages, press [#] then [2] again within 15 seconds.
To operate from a remote location, use any touch-tone telephone and follow these steps:
1.) Call your telephone number and wait for the answering machine to answer
2.) During the greeting message, press [#] and enter your PIN code within 2 seconds;
How to enter a PIN
To play your messages from a remote location, you will need to enter a two-digit Personal Identification Number (PIN) or PIN Code.
Press the MENU soft key. Select the ANSW. SETUP menu, and then the SECURITY CODE submenu.
Enter a two-digit security code (00-99) using the number keypad [0-9].
Press the OK soft. You will hear a confirmation tone.
The answering machine announces the current time and the number of messages stored in memory.
You hear "To play incoming messages, press pound-two. For help, press pound-zero." You will hear a beep.
Enter a remote command within 15 seconds, each command there after must be entered within 2 seconds. You may select a command from the following:
# then 1 Repeat a Message
# then 2 Playback Messages
# then 3 Skipping a Message
# then 4 Deleting a Message
# then 5 Stop Operation
* # then 6 Answering Machine On
# then 7 Memo Record/Stop**
# then 8 Greeting Record/Stop**
# then 9 Answer Machine Off
# then 0 Help Guidance
Apr 27, 2009 | Uniden 5.8GHz Expandable Cordless Phone...
I have a problem with voice mail with a meridian hooked to NT5806DA-93. The system on voice mail every second pulse off so that only half of each message is played at a half second interval
Voicemail Features Norstar Common To Check Your Voicemail:
1. Press the Check Voicemail key or press the Feature button, then 981
2. Enter your password
3. From here you can listen to messages, change your greeting, change your password, etc.
To Leave a Message for Someone in Your Office:
1. Press the Leave Message key or Feature 980
2. Enter the mailbox number (extension number. of the person you want to leave a message for
3. The display will show the name of the mailbox owner, press OK
4. Leave message
To Access Your Voicemail box from Another Phone:
2. Press the OTHER softkey
3. At the LOG: prompt, enter your mailbox#(extension #. and your password all together followed by the "#" sign
4. Press the OK softkey
To Access Your Mailbox from Outside of the Office:
1. Call the main office number or your DID (if applicable.
2. If the call is answered by a receptionist, have them transfer you to your voicemail box
3. If the call is answered by the company greeting, or your personal greeting, Enter: * *
4. At the prompt, enter your mailbox #(extension #. and password all together
To Transfer Someone to a Voicemail Box:
1. Press the Transfer to Voicemail key or press the Feature button, then 986
2. Enter the mailbox # (extension#.
3. The display will show: Call Transferred
To Change Your Personal Greeting:
3. Press the ADMIN softkey
4. Press the GREET softkey
5. Press the REC softkey
6. Press the PRIME softkey
7. Press the YES softkey
8. At the tone, record your new greeting, press the OK softkey to end your recording and then the OK softkey again to accept the new recording
To Record Your Alternate Greeting (Used when on vacation or out of the office.:
5. Pres the REC softkey
6. Press the ALT softkey
8. At the tone, record your new greeting, press the OK softkey to end your recording, then the OK softkey again to accept the new recording.
9. You then need to have your voicemail box now play the Alternate Greeting, Press the GREET softkey
10. Press the ChOOSE softkey
11. Press ALT softkey
12. Display will show: "Accept msgs: Y", Press the OK softkey to have your voicemail box accept messages while your Alternate Greeting is turned on, or press the CHNG softkey to change the "Y" to an "N" if you do not want your voicemail box to accept messages.
13. When you return to the office, make sure you go back into your voicemail box and have it play the PRIME greeting
Norstar Voicemail Administrative Programming Programming must be done from any M7310, T7316, or M7324 model phone set.
To Log Into System Administration:
1. Enter Feature 983
2. The display will show "LOG", enter your login password
a. If your company extensions are 2 digits long enter "120000"
b. If your company extensions are 3 digits long enter "1020000"
c. If your company extensions are 4 digits long enter "10020000"
3. Press the softkey under "OK"
To Create a New Mailbox:
1. Log into system administration
2. Select the softkey under "MBOX"
3. Select the softkey under "ADD"
4. Enter the mailbox number (extension. you want to add
5. Mailbox type: Subscriber and then select "OK"
6. Extension: Usually the same as the mailbox number
7. Service Class: Enter 1
8. Name: Enter the name using the dial pad. Enter last name first, press "# #" to enter a comma, and then enter the first name. When spelling the name, press # to move to the next character
9. Directory: Y (Yes.
10. Message Waiting: Y (Yes.
11. Out dial: Pool, enter 1 and then OK
12. Accept: 1, select OK
To Delete a Mailbox:
1. Log into the system administration
3. Select the softkey under "DEL"
4. Enter the mailbox number (extension. you want to delete
5. Select the softkey under "Delete"
To Reset a Mailbox Password:
3. Select the softkey under "Chng"
4. Enter the mailbox number you want to reset the password for
5. The display shows "Reset Password"
6. Select the softkey under "RESET"
7. Press the release key
*The new password will be "0000", the system will ask the user to change this the first time they log into their mailbox using this password.
To Change the Name on a Mailbox:
4. Enter the mailbox number (extension. you want to change the name on
6. Select the softkey under "Next", keep hitting "Next" until the display shows the name
7. Select the softkey under "Chng" to enter a new name
8. Enter the name using the dial pad. Enter last name first, press "# #" to enter a comma and then enter the first name. When spelling the name, press "#" to move to the next character
9. Select the softkey under "Next" to save the change
10. Hit the release button
Apr 15, 2009 | NorStar Lands Phones
voicemail reset
Norstar Common Voicemail Features To Check Your Voicemail:
4. Leave message
took this from a guide i found, helped me out
Apr 30, 2008 | NorStar M7310 Corded Phone
resetting company voicemail
4. Leave message
took this from a guide i have, might help you guys out
Jan 07, 2008 | NorStar M7310 Corded Phone
154 people viewed this tip
David Payne
David Payne
