Tip & How-To about Computers & Internet
Unable to run executable files (. Exe) on windows platform
It may happen that only executable files aren’t eager open properly: either you have the dialog box "Open With", it opens with notepad or another program.
This problem may be due to a error made on your PC. If this is not the case, then it is necessarily a virus, follow this tip to disinfect your PC.
To correct the problem, follow these steps:
First Solution This solution is valid for XP and 2000 versions.
  • Go to Control Panel and then Folder Options.
  • Select the File Type tab and then click New
  • Type in EXE file extension and click OK
  • The EXE extension is automatically selected, then click Restore
  • Close the dialog box
Second solution This solution works for all versions of Windows
  • Click on Start> All Programs> Accessories> Notepad
  • Select the text below> copy and paste it into Notepad
Windows Registry Editor Version 5.00
[HKEY_CLASSES_ROOT\exefile]
"EditFlags"=hex:d8,07,00,00
@="Application"
[HKEY_CLASSES_ROOT\exefile\shell]
[HKEY_CLASSES_ROOT\exefile\shell\open]
"EditFlags"=hex:00,00,00,00
[HKEY_CLASSES_ROOT\exefile\shell\open\command]
@="\"%1\" %*"
[HKEY_CLASSES_ROOT\exefile\shellex]
[HKEY_CLASSES_ROOT\exefile\shellex\PropertySheetHandlers]
[HKEY_CLASSES_ROOT\exefile\shellex\PropertySheetHandlers\{86F19A00-42A0-1069-A2E9-08002B30¬309D}]
[HKEY_CLASSES_ROOT\exefile\DefaultIcon]
@="%1"
  • Then click on File> Save As ...
  • Select All files Type
  • Give a name for the file and add the. Reg
  • Click on Save
  • Close the notebook and then right-click the file. REG> Merge
  • Click YES and OK
Computers & Internet Logo
how do I change my outlook.com emails from opening in notepad (which is gobbly ****)
SOLUTION 1:
Save the file in your computer and open it with MS Word.
SOLUTION 2:
You can change the program that starts when you open a file of a certain type.
Follow the steps:
1) In My Computer or Windows Explorer, click the Tools menu, click Folder Options, and then click the File Types tab.
2) In the Registered file types list, click the file type you want to open with a different program, and then click Change.
3) In the Open With dialog box, select the program you want to use, and then click OK.
4) Click OK in the Folder Options dialog box.
Oct 15, 2014 | Computers & Internet
Add Specific Folders to the Open Dialog Box
I could not find this string in XP Pro SP3 and thougthts?
Mar 17, 2008 | HP Pavilion a1410n (ER890AA) PC Desktop
Wolfenstein 2 exe executes Notepad
check the association if is set that notepad should open the .exe file and get a new copy of this game the try again .
Nov 27, 2009 | Computers & Internet
Out of Office Responder
Hi Lalita, are you using outlook express in XP? If so, there is no one click solution. Firstly you have to create a new notepad document, open this in START>Programs>Accessories>Notepad. With this open, type the message you would like to be forwarded when you are out of the office. When you are happy with it, save it in your my documents folder as 'outofoffice'. You should now have the file 'outofoffice.txt' in your mydocuments folder. Next go into outlook express, goto Tools>message rules>Mail...>. A four part dialog box should appear. Under "1. Select Conditions for your rule" scroll to the bottom of the list and add a check mark to "For all messages". Under "2. Select Actions for your rule", check off "Reply with message". Under "3. Rule description" the follow items will now be listed: Apply this rule after the message arrives For all messages Reply with message You will see that 'meesage' is underlined, click on it, a dialog will open, make sure is 'my documents' folder, in 'files of type' drop down choose *.txt. (nearly there promise!) Your file 'outofoffice.txt' should appear, click it then click open. in rule description call it something like 'when out of office' and click ok. The rule dialog should now be there, the box will be ticked, that means you auto responder is turned ON. To turn off uncheck this box, and check it when you leave the office. If you close it, to find the rule again, just navigate to tools>message rules>mail..> and will show you the dialog again to turn it on and off. I hope that was reasonably clear, if not or you don't have outlook express leave a comment and I will try and help you further, otherwise Lalita, I hope this has helped! Si :)
Sep 26, 2007 | Microsoft Office Standard for PC
194 people viewed this tip
David Payne
David Payne
