Tip & How-To about Computers & Internet
Windows 7
Get Quick Launch toolbar back
  1. Right-click the taskbar, choose Toolbars / New Toolbar
  2. In the folder selection dialog, enter the following string and hit OK:
    %userprofile%\AppData\Roaming\Microsoft\Internet Explorer\Quick Launch
  3. Turn off the "lock the taskbar" setting, and right-click on the divider. Make sure that "Show text" and "Show title" are disabled and the view is set to "small icons".
  4. Use the dividers to rearrange the toolbar ordering to choice, and then lock the taskbar again
have fun
Computers & Internet Logo
Get back the Quick Launch bar Windows 7's new taskbar functions as a program launcher as well as task switcher. As a result, the old Quick Launch bar, the area on the left side of the taskbar that contained shortcuts for frequently used programs, has been banished. However, if you really miss the little applet, you can add it back. Here's how to do it: 1. Right-click the taskbar and choose Toolbars --> New Toolbar. 2 . You'll be asked to select a folder for where the new toolbar should live. In the Folder text box at the bottom of the dialog box, enter this text: %userprofile%\AppData\Roaming\Microsoft\Internet Explorer\Quick Launch After you do that, click Select Folder. A link for the Quick Launch bar will be added to the taskbar. It will be on the right of the taskbar, just to the left of the Notification area. It's not particularly useful docked all the way to the right with no application icons showing, so we're going to have to do a bit of work on it to make it useful. Right-click the taskbar and, in the pop-up menu, remove the check next to "Lock the taskbar." Now right-click Quick Launch and remove the checks next to Show Text and Show Title. Once you've done that, drag the vertical triple dotted line next to the Quick Launch bar to the left until you expose its icons. To prevent further changes, right-click the taskbar and check Lock the taskbar. You can now use the Quick Launch bar as you could in Windows XP and Vista, including adding icons to it and deleting them.
Jan 12, 2010 | Computers & Internet
147 people viewed this tip
David Payne
David Payne
