Tip & How-To about Garden
Adgusting your carberator
Turn both screws slightley
Garden Logo
need instruction on how to adjust carberator
Adjusting carbs on chainsaws is not to be taken on lightly, there will normally be three screws, an L screw, an H screw, and an idle scre, the L screw will increase the fuel mixture from idle to half throttle ( they are fuel screws not air screws ) the H screw will adjust from half throttle to maximum revs, start with a base setting of between one turn and one and a half turns out, start the saw and warm through, allow it to idle, if need be increase the idle screw to get an idle, turn the L screw in slowley, the revs will increase as the mixture leans off, it will reach a point where it starts to die, now back it off a quarter of a turn, blip the throttle, the saw should pick up clean, if it has a flat spot increase the L screw slightley, now set the idle so it idles without the chain moving on the bar, now screw the H screw in to get full revs, be aware this should be set with an engine rev counter, do not exceed the manufacturersmax revs, hobby saws normally run at about 12500 rpm with an idle speed of 3000 rpm.
Oct 26, 2011 | Garden
how do I get the back off of the flat panel case??
after removing all screws--take a small flat screwdrive arround edges to unclip it all the way arround--youtube often has videos of how to dissasemble products--almost forgot u gotta turn screwdriver slightley til it pops-keep going around til all pops do not pry too hard
Sep 18, 2009 | ViewSonic N2751W 27 in. LCD Television
broken belt on Kenmore stackable # 417.99570140
replacement belts are v shaped or groved they stretch slightley turn the power off take the back off put new belt on the moter first then on the pulley slightley turn the pully and the belt will pull itself on to the pully itself if you guide it on
Jun 27, 2009 | Kenmore 98702 Stacked Washer/Dryer
door panel removable
Well you should not need a diagram First look for screws or little caps in the trim look under the arm rest / take out the screw / then take of mirror cover/ than pull out bottom of door panel and slightley around edges look cor screws with cover on the side or retainerswith little pins in the middle then pull form the bottom upward and then disconnect the wiring on door and you should have your door off/ Please rate my response Thank you very much
Jan 28, 2009 | 2002 Toyota Celica
Audio shorting out
sounds like a bad connection on the audio output Ic or in the audieo curcuitry
Apr 05, 2006 | Panasonic PV-C2780 27 in. TV/VCR Combo
219 people viewed this tip
Top Garden Experts
Dennis Key
Dennis Key
john h
