Tip & How-To about Computers & Internet
Improve system Performance In XP
  • Click Start button and click on Run option. In the Run box, type the command Rundll32.exe advapi32.dll,ProcessIdleTasks command and press Ok button
  • Here system will take some time to end the background idle tasks
    Computers & Internet Logo
    My wallpaper wont change, im usin lenovo g550
    your cache memory must be full ....
    1.clearing it will solve your prb
    1. Right click on desktop, New -> Shortcut
    2. Copy/paste this piece of code in the location box:%windir%\system32\rundll32.exe advapi32.dll,ProcessIdleTasks
    3. Save the file
    4. You are done!
    Jun 14, 2011 | Lenovo G550-29583AU Notebook
    my tune up utility says my prefetch folder is gone and it is important for my laptop to increase the start up..how will i solve this problem?..i didnt delete anythin in my laptop so i was wondering how this happened and what am i going to do about it?
    1. Make sure that the task scheduler is enabled. If you are un-sure, go to Start/Control Panel/Administrative Tools/ Click on Services/ Then in the list of services make sure the Task Scheduler is enabled & restart the service by clicking on Start. Close the Services Folder & go back to desktop.
    2. Then go to START/RUN/ and TYPE IN cmd (without the quotes) CLICK OK. This will bring up the DOS Command screen.
    3. You will need to copy and paste this entry in at the flashing cursor
     rundll32.exe advapi32.dll,ProcessIdleTasks (without quotes) and press ENTER.
    4. Now reboot three times and your Prefetch folder will be rebuilt. (It takes 3 reboots for the prefetch folder to work out what it needs)
    Feb 06, 2010 | Microsoft Windows Vista Home Premium with...
    cant clear memory sticks .2 MB plug in sticks onto which I've copied movies cant be cleared.
    Try this first, but if this doesn't work you can modify these settings in BIOS. I will give you specific instructions if this doesn't work. THIS TECHNIQUE DOES NOT REQUIRE A SYSTEM REBOOT
    Steps to follow:
    1. Locate an empty spot on your desktop, right click on your mouse and select – new shortcut.
    2. Type “%windir%\system32\rundll32.exe advapi32.dll,ProcessIdleTasks” without the quotations in the box and click next.
    3. Name your shortcut “XP Clear RAM,” and click finish…. All done!…
    Now, run it!!
    Ryan Frame
    Creative Energy Associates Technical Center
    Nov 08, 2009 | Computers & Internet
    acer won't go on standby
    To put the system in to hibernation from run menu:-
    1]Make sure that the system is hibernation enabled. To confirm that, Click the Start button, go to Run menu and type in Powercfg.cpl and click OK. In the Power Options Propertiesclick Hibernate tab and make sure that Enable hibernation option is checked. Click OK/Apply.
    2]Now Click the Start button, go to Run menu and type in %windir%\System32\rundll32.exe powrprof.dll,SetSuspendState and click OK.
    To put the system in to Stand by :-
    1]Make sure that the system is hibernation disabled. To confirm that, Click the Start button, go to Run menu and type in Powercfg.cpl and click OK. In the Power Options Propertiesclick Hibernate tab and make sure that Enable hibernation option is unchecked. Click OK/Apply.
    if you unning with XP you can try to solve here:
    http://support.microsoft.com/kb/907477
    Dec 24, 2008 | Acer Aspire T135 PC Desktop
    120 people viewed this tip
    David Payne
    David Payne
