Tip & How-To about Office Equipment & Supplies
Xerox 510 wide format only printer!, and not scanner!
The machine does not give me option to photocopy only as printer. The panel comes
March 22, 2004 release day
SE: OK
and does not leave the panel ready (does not load the system as it should be). Please I need your help, URGENT, to solve this problem. I would appreciate suggestions to solve it.
Andrea
Showing machine trouble, sevice call(c0500) pls help
If this is a printer/copier;
1-Turn the machine "OFF".
2-Press the "STOP" button on the basic panel.
3-Keep the button pressed and turn the machine "ON".
4-Do not release the button, until the machine warm up.
5-After few seconds Error code will remove and machine will reset.Basic menu will show no error on LCD screen.This means error code has been removed and photocopier machine is ready to use.
If not try reposting with model type ...
Mar 06, 2017 | Office Equipment & Supplies
Reset c0500
To reset Error codes C0500 and C0501, perform the following steps.
Aug 08, 2016 | Office Equipment & Supplies
how can i solve when it flashes on the panel
To reset Error codes C0500 and C0501, perform the following steps. 1-Turn the machine "OFF". 2-Press the "STOP" button on the basic panel. 3-Keep the button pressed and turn the machine "ON". 4-Do not release the button, until the machine warm up. 5-After few seconds Error code will remove and machine will reset.Basic menu will show no error on LCD screen.This means error code has been removed and photocopier machine is ready to use.
May 14, 2014 | Minolta DiALTA Di183 Copier
c0500
May 01, 2014 | Minolta Di3510f Bizhub Copier
ERORR C0500
Sep 26, 2013 | Konica Minolta Office Equipment & Supplies
281 people viewed this tip
jasbo
jasbo
