Tip & How-To about Televison & Video
How to make your dead remote control to work again?
If for any reason your remote has stopped working, simply try this method - take the batteries out of the control and leave it for 24 hrs.. try to put new batteries in and remote will be working again..
Televison & Video Logo
model #3217. Why doesn't remote work?
Try removing batteries and pressing all buttons in case one is stuck. Reinstall batteries and try again.
Apr 09, 2016 | Televison & Video
Spilled coffee on dish remote for pano sonic tv now remote won't work
Remove batteries and put remote in rice. Rice will help to remove moisture, wait 24 hrs and replace batteries. If still not working try again or contact company, remotes aren't that expensive.
Jun 11, 2014 | Televison & Video
remote control stops working
Sounds like it may simply be the batteries dying in your remote. Try putting a fresh set in to see if that helps at all.
Also be sure to check the battery terminal contacts inside the remote control's battery compartment as well to ensure there is no corrosion deposits which may cause intermittent faults. Clean / scrape off any rust or deposits with a flat head screwdriver or something similar until the metal contact is shiny again.
Good luck.
May 03, 2012 | LG 32LD550 32 in. LCD HDTV
The battery drains down in 48 hrs. I had a Ford mechanic look at it but he could not find out why it happens to my 1997 lincoln town car. Jim
I will try to help. First, find out if the Cruise Control was recalled for your car. Have a dealer run the Vin#. The bad ones never shut the power off.
Next, rear window defrost switches can short without the light indicator being lit up. This is a hard one to diagnose because it cycles every startup. Also bad ignition switches can leave the ignition on. Its silent and is not visible.
If none of the above, you have 2 ways to test the car.
Use OHMS or VOLTS. With volts you put the meter between 1 battery cable and the battery. You can short out something with this method. I favor the OHMS method, which you disconnect both battery cables and put the meter on the cables.
You will have to pull fuses with either method. Its time consuming but once you write down the fuse placement and size you will eventually disconnect the grounded fuse. Then trace the system, like a bad window switch or trunk pulldown.
May 19, 2010 | 1997 Lincoln Town Car
how do i reset harmony 628
The Simpliest way is to take out ur batteries for a 24 hrs or 48 hrs.It will reset itself to the original factory settings.Or follow ur manual
or go to there Website read the instructions.
Aug 19, 2009 | Logitech Harmony 628 LCD Remote Control
139 people viewed this tip
Top Televison & Video Experts
Electro Med Services...
