Tip & How-To about Office Equipment & Supplies
0x0xc18a0501 ink system failure C8180
NVM Reset :1. Unplug the power cord from the back of the HP All-in-One.
2. Wait for the unit to go to the sleep mode. Wait for 60 seconds.
3. Press and hold Print Photos & Photo Fix
buttons simultaneously on the control panel; keep them pressed and reconnect the power cord to the All-in-One.
4. Continue pressing the buttons until the display goes blank or Reset shows on the control panel display.
Worked for me.
Ink System Failure 0xc18a0501
1. Try to remove and reinstall the Ink Catridges. Be sure it is lock in place on the ink cartridge holder.
2. Turn off the Printer and unplug and replug the power adapter.
3. Uninstall and reinstall the printer driver.
Sep 24, 2009 | HP Office Equipment & Supplies
Ink System Failure with error code: 0xc05d1281
I had the same problem and took Guru NinaE advice....1. Unplug power cord from back of printer while it is on. 2. Wait for 60 seconds after it is in sleep mode. 3. Press and hold "Print Photos" and "Red Eye Removal" at the same time and while holding the two buttons down, plug in the power cord into the back of the printer. 4. The printer display should go blank or Reset might show up on the display. When this happens, touch the ON button and the printer will reset itself.
May 20, 2009 | HP Photosmart C8180 InkJet Printer
error message 222aO-reset power come on when I turn on printer. I have plugged and unplugged all cables and power sources.Any solutions to this?
hi,
the error message you encounter is new to me. however, you can try to partialy reset your printer.
1. while the unit is turn ON, unplug the power cord from the back of the printer
2. press and hold the # and 3 buttons together and dont release.
3. while holding the two buttons, plug-in back the power cord from the back of the printer.
4. wait for a couple of seconds, it will give you a message on the printer screen "PARTIAL NVM RESET".. when you see that message, you may release the two buttons.
5. in some cases, after you plug-in the power cord button frmo the back of the printer, the printer will become ONLINE.. and after 30 seconds it will automatically turn off. when that happens, just release the two buttons and press the power ON button to turn it ON.
6. after turning it ON, it will give you message "PARTIAL NVM reset".
note: after performing the steps, your printer will make some noise and it will eventually stops. then try to check if you still have that error message.
- adonscott -
HP TECH
Jun 29, 2008 | HP Officejet 5610 All-In-One InkJet...
chatters
i belive that your printer needs to be resetted. Just try the reset options which are for HP 6110xi.
POWER DRAIN:-Turn off the printer, Unplug the power cable from printer and from the wall outlet.Press and hold ON buton for 30-60 seconds.
PARTIAL RESET:-Unplug the printer power cable while its ON, press and hold # and 3 button and connect the Power cord while holding.Wait untill the ON light flashes, then release the buttons.
----(for below reset cartridges must be removed out)---------
SEMI_FULL RESET:-Unplug the printer power cable while its ON, press and hold # and 6 button and connect the Power cord while holding.Wait untill the ON light flashes,or wait for 20 seconds,hen release the button.If the printer goes off dont worry release the button and Push the ON button.
FULL NVM RESET:-Take the Ink Cartridges out, Unplug the printer power cable while its ON, press and hold OK and CANCEL button and connect the Power cord while holding the buttons.keep Holding the buttons until the printer goes off ,release the button and Push the ON button.
(Notes - resets will take a while)
Thank You
Feb 10, 2008 | HP OfficeJet 6110 All-In-One InkJet...
139 people viewed this tip
jasbo
jasbo
